Drop Down Show and Hide Dates
Feb 05, 2018 Feb 05, 2018
I am creating a form for our payroll department where a user will select the start date of a payroll period. The list of dates in the drop down box is large so I used http://www.acroscript.net/pdf/demos/comboPopulateTest.pdf to create the box. What I need to do is hide any dates that are old so the user selects a future date. All of the searches I have come across relate to dependent drop down boxes and cannot find any scripts to "filter" dates. Any help will greatly be appreciated. Solely using Acrobat XI.
Thank you
PDF forms
647
What happens if the user selects a date and then opens the file later on? If you refresh the list of options each time it is opened you will delete any value that was selected in the past.
Thank you. The form will be saved as read only so hopefully that will not be a problem
Unless you flatten your file, or add a condition not to update the field's options list when it is set as read-only, it will be.
That's George Johnson's PDF for filling a combobox with items from a pasted list.
Why don't you create a script for filling the dropdown with a list of relevant dates?
Here is a script that starts with today and goes for 30 days. Make sure you change the dropdown field name "DateList" to match the one on your form.
var aDateList = [];
var nToday = (new Date).getDate();
var dtItem;
for(var i=0;i<30;i++)
  dtItem = new Date;
  dtItem.setDate(nToday + i);
  aDateList.push(util.printd("mm/dd/yyyy", dtItem));
this.getField("DateList").setItems(aDateList);
Thom Parker - Software Developer at PDFScripting
Use the Acrobat JavaScript Reference early and often
The dates will be 14 days apart. I used George Johnson's PDF because I was using dates calculated in Excel i.e. 14 days apart--using payroll dates e.g. 2/16/18. Thank you
easy enough to do. Just use this variation, it generates 10 dates 14 days apart, starting with today. If you put this script at the document level it will recreate the date list every time the document is opened, so it will always be current.
var aDateList = [];
var dtItem;
for(var i=0;i<10;i++)
  dtItem = new Date;
  dtItem.setDate(nToday + i*14);
Feb 06, 2018 Feb 06, 2018
Thank you for the reply. This is a fine script to add days from today, however, the pay periods are set with the next future one starting on 2/16/2018 then 3/2/2018 etc. On 2/17/2018 I need the first visible date to be 3/2/2018.
Well, the point of the script is to show how consecutive dates are created. All you have to do is modify the start point and the increment to whatever is needed.
Say for example the start date is in a form field. Then the script would parse the date out of the field.
Say for example the start date format was mm/dd/yyyy.
Here's a modified script to use a random start date.
var aDateList = [];
var dtItem = util.scand("mm/dd/yyyy",this.getField("StartDate"));
if(dtItem)
          dtItem.setDate(dtItem.getDate() + 14);
Feb 09, 2018 Feb 09, 2018
Thank you very much for the script. I'm obviously not familiar with java script. The above is setting the first date 14 days from today. The getDate() seems to be getting in the way. I am using:
var aDateList = [];
var dtItem = util.scand("mm/dd/yyyy",this.getField("2/2/2018"));
if(dtItem)
You are correct. I write this stuff pretty fast. So Here's quick change to make sure it starts with the date in the input field.
BTW: the getField is for gettting an actual field on the form, its not a way to specify a date. "StartDate" is a field name, not a placeholder for adding a date.
  1. var aDateList = [util.printd("mm/dd/yyyy", dtItem)];
  2. if(dtItem)
    1. var dtItem = util.scand("mm/dd/yyyy",this.getField("StartDate"));
  3.      for(var i=0;i<10;i++)
  4.      {
  5.           dtItem.setDate(dtItem.getDate() + 14);
  6.           aDateList.push(util.printd("mm/dd/yyyy", dtItem));
  7.      }
  8. }
  9. this.getField("DateList").setItems(aDateList);
