Hi Andrea,
Do you get the dialog to browse your hard drive for the image
or topic, or does RH hang immediately upon your clicking the option
to import and the Browse dialog never appears?
If the second case is happening, have you recently used a
dual monitor configuration, including using a projector? It's
possible that the Browse window is in fact opening, just off your
screen. You can correct this by going back to that configuration
and doing an import, moving everything on to the correct screen,
then switch back to the single monitor so that things show up
there.
I don't think it's possible to move dialog boxes with the
same controls as full windows, but you could try it.
See
Rick's response in another thread. I use that
forceWindowVisible utility myself, and it works for pulling dialog
boxes back into view.
Hope this helps,
Ben
