I experienced a problem with adobe Elements 12 not loading ...
So I reinstalled it afresh ...but same problem ...please advise upon a solution
[serial number removed by moderator - don't post in public forum]
Please post Photoshop Elements related queries over at
Moved to to the PSE community.
And please don’t tell the whole world your serial number. You’ve probably lost it forever now.
What happens when you try to open the program? Are you having difficulty with editor and/or organizer? Any error messages? Windows or Mac?
the first time, I got the screen with choices and I chose Edit, A line streamed across it,, but did not open the editor, Now nothing opens, Got icon on bottom bar saying it is An Adobe application manager. When I hover on it it says Photoshop Elements 12, but if I click on it it checks for updates. Concerned if I uninstall and try to reinstall if won't take my information.
sorry windows 10
Hi fredm,
Thanks for posting in Adobe forums.
I understand you are facing issue in loading Elements 12.
Could you please try the following steps:
- Go to location
C:\Program Files (x86)\Common Files\Adobe\
- Rename "SLCache" to "SLCache.old"
- Go to location
C:\ProgramData\Adobe\
-Rename "SLStore" to "SLStore.old"
If inside C:\ you do not find "ProgramData" folder then it means it is hidden then to open it
- Open "Run" command
- Type %ProgramData% inside Run command
- Hit "Enter"
Open Adobe Elements & give it some time to open (30 seconds approx)
- It should ask you to activate the product
- Sign in with your Adobe ID
- Enter your serial number & activate the product
Hope this helps
Happy Editing
Regards
Dhananjay
Checking for updates is good, and normal. What happens next?
I click on the shortcut and the adobe icon on the lower bar has a message photoshop elements 12 and then a box that says Quit and a yes or no choice, I've tried clicking on both, nothing happens
