I have an input pdf file which is using type3 fonts. The glyph definitions contain inline images and flate decode filter applied on them.
My moto is parse the glyphs to postscript. Does i need to remove the filter from the data manually or just take the binary data as is to postscript. I have read postscript support flate decode filters.Here is the sample glyph definition:
32 0 obj
/Length 342
stream
37 0 4 -52 33 -1 d1
0.01 0 0 0.01 0 0 concat
gsave 2900 0 0 -5100 400 -100 concat
BI
/IM true
/W 29
/H 51
/BPC 1
/D[1
0]
/F/Fl
/DP<</Predictor 15
/Columns 29>>
ID xœ=Ì¡
Â`ÅñÿeÂLθ n`0>Ù`ñ
f[¦DŒF_ÁhC1ì%Ä)¶o.¢Ÿ"†ßá†s®àì]^ÏŠÅS³tFËÂÚ3sç'Æi èÐÇ:j‹¹¨åìOTÿ ª•ÉÙÕÅŸ¨‡¹Ó$°ÆΚWèÁ!¯Cê
÷0&f µtðV ©Ë÷iôíتÄ~Ø•Œöí&´« +ro#Ê‚ûÏÅùlßG'
EI gRestore
endstream
endobj
Here is what i am trying in postscript
/g21 {
37 0 4 -52 33 -1 setcachedevice
gsave
[0.01 0 0 0.01 0 0] concat
gsave
[2900 0 0 -5100 400 -100] concat
[ xœ…ѱNÃ0à3©p'l` ¢abä*‰'@‚W`KP¡00öQ`d@ ¨CWž€u`‰štj4Ü]@ /ù¤œíÿ| ÂìÊüå7úŠ‰V'‚ª¦zò¡9à*´º
m1Õ`ñ—íü‹‡½Gù@ãÝAVxc¥Ž®"6oFܬJHÃB3(æod¾…xFP†o$!v±Ã»·0—gØY÷J$û„`´#zÊ
Oí¼œÑ¸é`Ê}ü…ñ.Z¯›cF4\¡*O¤ÑPÒYòî¦/éG‘qÑç¼2>öq<Üœ<
B˜5‚²¢ºÎ/èqUTUàoÓ9͔Π܉ä²z ‡S×ÛÙC(PA²š7èT¾ŽCGÈRaLéåksnˆÃ0z<zø:ž=
/ImageType 1
/Width 29
/Height 51
/ImageMatrix [29 0 0 -51 0 51]
/BitsPerComponent 1
/Decode [1 0]
/DataSource { 2 copy get exch 1 add exch }
<</Predictor 15
/Columns 29
/FlateDecode filter
imagemask
pop pop
gRestore
gRestore
} def
The only problem i think is in representing data of image. any suggestions how can i parse it correctly.
This forum is meant for discussion of Adobe's Acrobat products, and you aren't likely to get discussion from people who are PDF experts and PostScript programmers. You can try this forum - PostScript Programming . Doesn't look like it will work, the data source must be reusable and you have an unparseable array. Long way off.
