Hello I have a big problem.
My GPU dont works. I cant use it for rendering (OpenCL)
I have a Asus ROG Strix RX 470. And i5-6600k
It must work my GPU is good 😕 I have all 2018 versions. I mean PePro2018, AE 2018, MEncoder 2018...
I've just buyed 32GB of RAM for AE... I'm a student I dont have much money and I dont want to spend again a bunch of money for a CUDA graphics card...
I dont understand why it shouldnt work with my RX 470.
There's no reason why it shouldnt work...
[And I still dont understand why AE is using only CPU for the most rendering... we have 2018 guys.. but thats now another topic..]
does anyone have any ideas?
I already tried this tutorial:
HowTo Enable OpenCL for AMD Cards in Premiere Pro CC 2017 - YouTube
I think it worked only in 2017. Adobe removed this trick in 2018, and thats also very sad and unfair
For systems with multipls GPUs, the solution is to Disable OPENCL support for the INTEL GPU in the registry
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\OpenCL\Vendors
It will show AMD and Intel. Set the intel dll to 1 to disable
I was looking for a solution for two years and found it this week!
Unfortunately, in all versions of After Effects you're permanently stuck with CPU-only rendering if you're not using an Nvidia GPU. In addition, the Ray-Tracer GPU feature has been depreciated by Adobe, in favor of a mostly CPU-only version of the Cinema4D renderer. (This means that although it's been updated to permit some newer Nvidia GPUs to use it, no new features are being added.)
So, should I get a Nvidia GPU? Would it be worth?
Because ,,Mercury Playback Engine'' would benefit from it. How much would be the benefit?
That all depends on what effects and features you use in your workflow. Do you do much scaling or frame rate changes? What media?
I use much animations and keyframes. Also much transitions. In Full HD always. (Im speaking about after effects)
In Premiere Pro I just cut everything together. I do mainly everything in AE.
What do you mean with ,,what media''?
Also one problem is that ,,Mercury Playback Engine'' doesnt works with my GPU in the Adobe Media Encoder. And that costs a lot of render time 😕
In a CMD window run "GPUSniffer.exe" Here is an example from my system.
It will tell us something about your RX 470
He you go!
(i already tried deactivating my Intel Graphics/GPU in BIOS, and in Windows, I still cant use my RX470)
Well that looks good. If you really want to see your GPU working in Premiere try running my Premiere Pro BenchMark (PPBM)
You should be able to see 99% GPU Loading in GPU-Z on the Sensors Tab on the MPEG2-DVD Timeline export with GPU acceleration (Step 2)
What do you see in Premiere when you go to File/Project Settings/General
Here is my CUDA verification, you should see your OpenCL option
Thats the problem that I also have in Media Encoder and After Effects, there isnt listened the option ,,OpenCL'' 😕
That doesn't look good, especially since you currently have both the integrated Intel HD graphics and the discrete GPU enabled, which in Premiere causes major conflicts with one another. And since Premiere does not currently permit the selection of the GPU being used, that means that as long as you fail to disable the integrated Intel HD Graphics in your system's BIOS / EFI, the Premiere MPE renderer is semi-permanently locked to the integrated Intel graphics.
EDIT: I saw that you already tried that. The only to properly disable that Intel GPU is to not only do what you did, but also completely disconnect everything from the motherboard's video (DVI, HDMI, DisplayPort) outs, and (if necessary) completely uninstall the video drivers and software for the Intel IGP.
Hope this helps,
Randall
Randall,
Thanks for that info. I guess then that even if the OP had an nVidia card it would not make any difference.
Bill
Anybody has been able to solve this?
OpenCL works perfect on 2017, but not on 2018. How is this possible? I has to installed both.
thats also my problem I think. I dont checked OpenCL on 2017, but on 2018 it definitely doesnt works
Running MEdia encoder 2017 give me the option to use my graphics card. Even After Effects and Premiere let me select it, but Media Encoder 2018 wont let me select my graphics card and only lets me use the software renderer.
2018 is really making me upset because everything worked fine and used my graphics card until I upgraded. Premiere will randomly not recognize it and I've updated the drivers to the most recent drivers multiple times.
Beyond aggravating.
-Neil
Neil,
Have you tried the GPU-Z trick. Install GPU-Z and when you do set it to run when you open Windows If it is running before you start Premiere it should stop the intermittent problem
Thanks Bill. I tried that and does nothing. It is something with Premier 2018. At the moment I have 2017 and 2018 installed in the same computer. If I open 2017, I can select the OpenCL and it is fine. But in 2018, I can select the OpenCL and there are plugins that I can't use.
well I cry why is adobe doing this to us
Here you can see Premier Pro CC 2017 and 2018. Both installed in the same machine and running at the same time. AdobeSupport​ Please fix this.
Hello,
In Windows/system32 rename/delete this file:
amdocl64.dll
also i think for 2018 they put this amdocl12cl64.dll
Just rename and OpenCl Mercury will be available. (might not actualy use your GPU but option will be there) I noticed it still uses my Intel GPU not my AMD
/J
Now there is a real simple but brilliant solution!
Hey
Thanks for your response
I was just wondering if you could please tell me if I have followed your instructions Correctly
cheers
Yes, setting intel dll to 1 will disable it..
It has worked for me 100%
Didn't seem to work, oh well I'll have to use intel UHD graphics
Simply doing that without restarting your system won't do.
