It has happened twice now in the last hour.
I have an In and Out set on the timeline. When I try to move or paste a clip outside of that (past the Out point), it is crashing the program.
I offer this on a hunch:
when you take a clip and give it in and out points and put it in the timeline, the clip in source is still the one you got from a bin. You can go and select new points and create a second edit from that “master” clip. But if you have double clicked an edit in the timeline, that goes up into the source viewer but it is that “edited clip from the timeline”. If you attempt to move the edit points now, it will change that clip in the timeline. If you want more selections from that master clip then better to right click it in timeline and select reveal in project. There might be more efficient ways....
I will look into this - thanks for the suggestion!
