After the last update the Mercury playback engine GPU acceleration(openCL) show my clips and rendered files as collored stripes and not as video-clips. Why??
Have you checked for a possible update available for your GPU driver?
Neil
Thank you. Yes and there is non.
Kim
If you switch to software only ... does monitor play correctly?
Neil
Yes if I switch it works
Issue is with your GPU probably then, have you tried rolling back the driver as Ann suggested?
Neil
Does this mean go back to an older driver?
Yes ... try the driver previous to the one you're using.
Neil
Might need to roll back a driver.
Please post computer specs and media used (please be specific)
