hello everybody,
I have a technical question.
I design a lot of wedding albums and i have a lot of templates but still it takes me a lot of time to design an album.
Does anyone know a way or a feature or a program that i can use to make my work more efficient and at the same save the pictures' quality?
thanks
Depending on the nature of your page layouts you might be better off efficiency-wise doing them in Indesign.
What are your ultimate-output-needs? Do you use a print-provider and what do they require – pdfs, jpgs, …?
Saving time is what templates are all about. You select images for your album pagers a folder for each page images. Then you populate your page templates for each page with an automated Photoshop process. I would not think there is anything anything available the would automatically select which photo should be in an album select which templates to use and order the images for the pages and order the populated page for the album. I would think the family would want some say in which pictures should be in the album. If you use a good cameras and lighting you would only keep good high quality images. There should be no problem with image quality.
