I have After Effects 2018 (Version 15) and the latest Media Encoder 2018 (Version 12) installed.
When I add to Media encoder queue from AE 2018, it does not link. Same when I try to add a project inside the Media Encoder.
The error that is shown is "Could not connect to Adobe After Effects. Please verify that Adobe After Effects and Adobe Dynamic Link components are installed"
Moving to Adobe Media Encoder (AME)ā
Hi jobingeorgejacob,
Sorry for the inconvenience. It seems like an issue with the installation. Please uninstall & reinstall Adobe Media Encoder.
Vidya.
Can you please confirm if the issue that you were facing has been resolved or not?
Kulpreet Singh
I have the same problem!!!
same here,
not resolved.
Any solutions on this issue. It started doing this for me after new updates.
Same here. As soon as I updated AE I got the error. Playing with preferences checkboxes does nothing. This has been an issue since 20012 apparently? Nice job, adobe.
it is necessary to reinstall or update also
I had same problems million times. Sometime link works good, sometimes it take 3-4 minutes and sometimes it don't work at least. Restart computer helps me. We don't have another software except Adobe =( It like a MS Windows. Don't work good, but everybody use it.
ditto same issue
AME 12.0.1
AE 15.0.1
Is someone from Adobe going to respond to this? It seems like a fairly common problem. I've uninstalled and reinstalled and still have the same problem. I also ran the Adobe CC cleaner, as suggested in another post.
I used the CC installer to install both AE and the AME so I know they are both the same versions.
Any suggestions would be appreciated!
ch
Same problem for the 6 month. The programs is updating t newer versions, but problems is still unresolved Oo
I ran into this problem last summer (June, 2017). The Adobe folks came up with this, which worked for me:
I looked into this further and find out this problem happens when the following conditions are both met.
- AE Preferences > General > "Show Start Screen at Startup" is disabled
- AE Preferences > New Project > "New Project loads template" is enabled
I changed one (or both, I don't remember) settings and it's worked peachy for me since.
didnt work for me
Same issue, was fine till I updated 09-04-2018. Have uninstalled both AME & AE, reinstalled. still didn't work.
Same here... but I have seen this problem since media encoder has been released. I don't get why they moved all the good containers and codecs features from the render queue to this garbage app...at least they should have let us the option to render our videos with the software we want! Right now my workflow is: render a .mov with animation codec in AE, then import the .mov in ME to render my .mp4 with H265... what a wast of time! We use to be able to render those directly with AE but not anymore. Thanks to the broken ME dynamic link...
The same case here, after update...
HARDWARE: iMac (Retina 5K, 27-inch, Late 2015)
SOFTWARE: Mac OS Mojave
Adobe app updates to:
1. After Effects CC 2019 16.0.0
2. Media Encoder CC 2019 13.0
Export from AE to AME didn't work!
Sometimes it's work when I try when I export Composition from AE "Render Queue" using button "Queue in AME"
but only when I have AME App closed. After that the Dynamic Links still didn't work.
Everytime I try close application I only see the same error:
Process: Adobe Media Encoder CC 2019 [1001]
Path: /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/MacOS/Adobe Media Encoder CC 2019
Identifier: com.adobe.ame.application.CC13
Version: 13.0.203 (13.0.203)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Media Encoder CC 2019 [1001]
User ID: 501
Date/Time: 2018-10-22 16:03:30.827 +0200
OS Version: Mac OS X 10.14 (18A391)
Report Version: 12
Anonymous UUID: BD390E2C-8B07-B8E1-A2BF-80F1FA44586B
Sleep/Wake UUID: 924F7A28-235C-477F-9715-6DEFF2B2A062
Time Awake Since Boot: 4700 seconds
Time Since Wake: 840 seconds
System Integrity Protection: enabled
Crashed Thread: 15
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1001]
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff7654cade madvise + 10
1 libsystem_malloc.dylib 0x00007fff765cbe2d mvm_madvise_free + 87
2 libsystem_malloc.dylib 0x00007fff765cbd44 tiny_free_scan_madvise_free + 577
3 libsystem_malloc.dylib 0x00007fff765c2f91 tiny_free_no_lock + 2120
4 libsystem_malloc.dylib 0x00007fff765c2631 free_tiny + 483
5 com.adobe.GPUFoundation.framework 0x000000010f6ffb27 std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 87
6 com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
7 com.adobe.GPUFoundation.framework 0x000000010f6ffaf1 std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 33
8 com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
9 com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
10 com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
11 com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
12 com.adobe.GPUFoundation.framework 0x000000010f6fd666 GF::DeviceModuleManagerCommon::ResetDiscoveredModulesCache() + 70
13 com.adobe.GPUFoundation.framework 0x000000010f6f2a10 GF::Device::DestroyContext(bool) + 576
14 com.adobe.GPUFoundation.framework 0x000000010f6fc5a2 GF::Terminate() + 98
15 FLT.dylib 0x000000013d007bff FLT_Death() + 271
16 com.adobe.aelib.framework 0x00000001399ae938 aelib::TerminateIterator::operator--() + 504
17 com.adobe.aelib.framework 0x00000001399a91f8 Terminate + 40
18 com.adobe.dvacore.framework 0x000000010075f966 dvacore::config::lazyloader::Terminate(char const*) + 1398
19 com.adobe.ame.application.CC13 0x000000010004eb3e AME::app::AMEAppInitializer::~AMEAppInitializer() + 78
20 com.adobe.ame.application.CC13 0x000000010002ae2d AME::app::AMEApp::TerminateApplication() + 221
21 com.adobe.exo.framework 0x000000010b7f4307 exo::app::AppBase::Terminate() + 39
22 com.adobe.ame.application.CC13 0x00000001000368ae AME::RunTheApp(exo::app::AppInitArgs&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&) + 10046
23 com.adobe.ame.application.CC13 0x0000000100077ecf main + 399
24 libdyld.dylib 0x00007fff76412085 start + 1
Thread 1:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff7654ac2a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff7654b174 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff4937e05e __CFRunLoopServiceMachPort + 337
3 com.apple.CoreFoundation 0x00007fff4937d5ad __CFRunLoopRun + 1654
4 com.apple.CoreFoundation 0x00007fff4937cce4 CFRunLoopRunSpecific + 463
5 com.apple.CFNetwork 0x00007fff48280ef5 -[__CoreSchedulingSetRunnable runForever] + 195
6 com.apple.Foundation 0x00007fff4b6d3234 __NSThread__start__ + 1218
7 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
8 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
9 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff76551052 kevent + 10
1 com.adobe.dvatransport.framework 0x0000000105a0e23d boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 253
2 com.adobe.dvatransport.framework 0x0000000105a0dc48 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 232
3 com.adobe.dvatransport.framework 0x0000000105a0d9b5 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 165
4 com.adobe.dvatransport.framework 0x0000000105a02c87 SkyConnectionEnv::MainLoop() + 151
5 com.adobe.dvatransport.framework 0x0000000105a02569 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
Thread 3:
0 libsystem_kernel.dylib 0x00007fff7654e1b2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff766075cb _pthread_cond_wait + 724
2 com.adobe.dvatransport.framework 0x0000000105a0dce7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 391
4 com.adobe.dvatransport.framework 0x0000000105a1956f boost::asio::detail::resolver_service_base::work_io_service_runner::operator()() + 47
5 com.adobe.dvacore.framework 0x00000001007fddf0 boost_asio_detail_posix_thread_function + 16
6 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
8 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff76551e82 __select + 10
1 com.apple.CoreFoundation 0x00007fff493abc83 __CFSocketManager + 639
2 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
3 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
4 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 5:
0 libsystem_kernel.dylib 0x00007fff7654ac7e semaphore_timedwait_trap + 10
1 com.apple.CoreServices.CarbonCore 0x00007fff4a6f900d MPWaitOnSemaphore + 74
2 ??? 0x000000013132ba77 0 + 5120375415
3 ??? 0x00000001312e27f2 0 + 5120075762
4 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
5 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
6 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 6:
2 ??? 0x000000013132c5f7 0 + 5120378359
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
2 com.adobe.dvacore.framework 0x0000000100725c21 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
3 com.adobe.dvacore.framework 0x000000010072588b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 315
4 com.adobe.dvacore.framework 0x000000010086866e dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 142
5 com.adobe.dvacore.framework 0x0000000100866b8c dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 140
6 com.adobe.dvacore.framework 0x0000000100863fba dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 362
7 com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
8 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
9 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
10 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 15 Crashed:
0 com.adobe.AMEDynamicLinkServer.framework 0x000000010c31fd14 AME::DynamicLinkServer::AMEEncoderImpl::AddItemShared(dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::filesupport::File const&) + 180
1 com.adobe.AMEDynamicLinkServer.framework 0x000000010c321d69 AME::DynamicLinkServer::AMEEncoderImpl::AddItem_1(dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 777
2 com.adobe.AMEDynamicLinkServer.framework 0x000000010c3354bf AME::DynamicLinkServer::AMEEncoderServerImpl::AddItem_1(dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 799
3 com.adobe.AMEDynamicLinkServer.framework 0x000000010c36a649 boost::enable_if_c<(boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>::arity) == (7), void>::type dvamarshal::DoHandleRequest<boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)> >(boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)> const&, dvamarshal::Responder&, std::__1::vector<boost::shared_ptr<boost::any>, dvacore::utility::SmallBlockAllocator::STLAllocator<boost::shared_ptr<boost::any> > > const&) + 201
4 com.adobe.dvamarshal.framework 0x0000000105ae5ff2 dvamarshal::DispatchRequest(boost::shared_ptr<dvatransport::Session> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, long long, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&, boost::shared_ptr<boost::any>&) + 466
5 com.adobe.dvamarshal.framework 0x0000000105afae7b dvamarshal::RPCServerGremlin::OnRequestReceived(boost::shared_ptr<dvatransport::Session> const&, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 715
6 com.adobe.dvamarshal.framework 0x0000000105af9b0a dvamarshal::RPCServerGremlin::StaticOnRequestReceived(boost::weak_ptr<dvamarshal::RPCServerGremlin> const&, boost::shared_ptr<dvatransport::Session> const&, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 74
7 com.adobe.dvatransport.framework 0x00000001059f4929 boost::function2<dvatransport::TransportError, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > >::operator()(boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > >) const + 89
8 com.adobe.dvatransport.framework 0x00000001059f43a4 dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvatransport::SessionFacade>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 372
9 com.adobe.dvatransport.framework 0x00000001059f465f dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvatransport::SessionFacade>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 1071
10 com.adobe.dvatransport.framework 0x00000001059fabb1 dvatransport::GenericTransporter::SessionTable_RecvMessage(boost::shared_ptr<dvatransport::GenericSession>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 161
11 com.adobe.dvatransport.framework 0x00000001059fc253 dvatransport::GenericTransporter::NotifyIncomingExecute(unsigned long long) + 563
12 com.adobe.dvatransport.framework 0x00000001059f779a dvatransport::GenericTransporter::StaticNotifyIncomingExecute(boost::weak_ptr<dvatransport::GenericTransporter>, unsigned long long) + 58
13 com.adobe.dvatransport.framework 0x00000001059ffd52 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::weak_ptr<dvatransport::GenericTransporter>, unsigned long long), boost::_bi::list2<boost::_bi::value<boost::weak_ptr<dvatransport::GenericTransporter> >, boost::_bi::value<unsigned long long> > >, void>::invoke(boost::detail::function::function_buffer&) + 50
14 com.adobe.dvacore.framework 0x0000000100866bc1 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 193
15 com.adobe.dvacore.framework 0x0000000100863fba dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 362
16 com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
17 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
18 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
19 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 16:
Thread 17:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff468dc581 _NSEventThread + 160
Thread 18:
Thread 19:
Thread 20:: MPSupport Worker
2 MultiProcessor Support 0x000000015ffb379b boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
3 MultiProcessor Support 0x000000015ffb36bb ThreadFunctor::operator()() + 203
4 MultiProcessor Support 0x000000015ffd581b boost::(anonymous namespace)::thread_proxy(void*) + 151
5 libsystem_pthread.dylib 0x00007fff7660433d _pthread_body + 126
6 libsystem_pthread.dylib 0x00007fff766072a7 _pthread_start + 70
7 libsystem_pthread.dylib 0x00007fff76603425 thread_start + 13
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: MPSupport Worker
Thread 26:: MPSupport Worker
Thread 27:
0 libsystem_pthread.dylib 0x00007fff76603408 start_wqthread + 0
1 ??? 0x0000000054485244 0 + 1414025796
Thread 28:
Thread 29:
Thread 30:
1 libdispatch.dylib 0x00007fff763c4428 _dispatch_sema4_timedwait + 76
2 libdispatch.dylib 0x00007fff763c4b19 _dispatch_semaphore_wait_slow + 58
3 libdispatch.dylib 0x00007fff763d1b5a _dispatch_worker_thread + 328
Thread 31:
Thread 32:
Thread 33:
Thread 15 crashed with X86 Thread State (64-bit):
rax: 0x6000000015dd0f87 rbx: 0x0000700005481610 rcx: 0x0000000000000001 rdx: 0x0000000030af8836
rdi: 0x00000000000000a4 rsi: 0x00006000005546a0 rbp: 0x0000700005481250 rsp: 0x0000700005480f20
r8: 0x00000000000001ff r9: 0x00000000000007fb r10: 0x00000000000006a0 r11: 0x0000000000000020
r12: 0x00007000054815f8 r13: 0x0000000000000001 r14: 0x00007000054815c0 r15: 0x00007000054815b0
rip: 0x000000010c31fd14 rfl: 0x0000000000010206 cr2: 0x00000001313282d0
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x100000000 - 0x10029efff +com.adobe.ame.application.CC13 (13.0.203 - 13.0.203) <01ABA88F-4FCF-3FCD-8C03-B5338EECA22E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/MacOS/Adobe Media Encoder CC 2019
0x100512000 - 0x100517ffb +com.adobe.AdobeCrashReporter (7.7 - 7.7.5) <F5F5AC4D-28D0-3301-82A5-AB220B99B648> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x100523000 - 0x100524ffb +com.adobe.boost-system.framework (13.0.0 - 13.0.0.203) <562EF604-D7EA-3B85-A0F9-E4536F666FE0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x10052c000 - 0x100530ff7 +com.adobe.boost-date-time.framework (13.0.0 - 13.0.0.203) <12A44D23-8586-3282-AEB4-A02D91AF65D1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x100541000 - 0x10054dff7 +com.adobe.boost-threads.framework (13.0.0 - 13.0.0.203) <5CE44423-A6ED-3DFE-972A-03B1A7C5CFE4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x10056b000 - 0x100579ff7 +com.adobe.boost-filesystem.framework (13.0.0 - 13.0.0.203) <392990B5-875F-3F70-8F69-EDD8597C80DC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10058f000 - 0x100630ff7 +com.adobe.boost-regex.framework (13.0.0 - 13.0.0.203) <04E7AF20-54F0-31C2-BB95-13993B78468E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x1006a7000 - 0x1006c9ff7 +com.adobe.dvaunittesting.framework (13.0.0 - 13.0.0.203) <FD5FEB25-C69E-3B76-82E5-0AD399B2F5A8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x100709000 - 0x100ac4fff +com.adobe.dvacore.framework (13.0.0 - 13.0.0.203) <81CAF27D-ABB1-3BF6-B382-6465953A58D9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x100e39000 - 0x100eb9ff7 +com.adobe.dvamediatypes.framework (13.0.0 - 13.0.0.203) <CAE64C97-2E32-3B76-82DD-A6DA43721AFE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x100f85000 - 0x101054ff7 +com.adobe.dvaaudiofilterhost.framework (13.0.0 - 13.0.0.203) <221D6A53-C9AF-3A83-BDA6-AA1E3275F08F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
0x10118d000 - 0x10122dfff +com.adobe.dvaappsupport.framework (13.0.0 - 13.0.0.203) <CE9D01EE-918E-3B09-AA46-04E8D2FEC659> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
0x10130d000 - 0x101a5bfff +com.adobe.dvaui.framework (13.0.0 - 13.0.0.203) <0FB79951-D2E4-3219-B84D-ACA26BDA2E6F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x102683000 - 0x102742ff7 +com.adobe.dvaeve.framework (13.0.0 - 13.0.0.203) <A5E61C03-81DE-3D4F-AC07-80E0D887B328> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x1028a1000 - 0x1028a4fff +com.adobe.PRM.framework (13.0.0 - 13.0.0.203) <CFC7671D-BEF7-34B5-BE22-71360D0E55C6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x1028b0000 - 0x102909fff +com.adobe.ASLFoundation.framework (13.0.0 - 13.0.0.203) <8CC86FFC-BE5A-3835-9905-AD9D95F8DBEE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
0x10296c000 - 0x1029aafff +com.adobe.MediaCoreUI.framework (13.0.0 - 13.0.0.203) <A6C1887B-85AB-3364-9682-7EDF37D0F9F9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
0x102a0a000 - 0x102ad5fff +com.adobe.dvanet.framework (13.0.0 - 13.0.0.203) <FB9113A0-C39B-36BE-A37C-95B258C106C1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x102c01000 - 0x1034a0ff7 +com.adobe.EAClient.framework (13.0.0 - 13.0.0.203) <3522C659-91AE-3D9A-A99B-223B90EC74B0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
0x104015000 - 0x104235fff +com.adobe.EACodec.framework (13.0.0 - 13.0.0.203) <FBECA19B-4D86-3239-99D0-0AF47C3FAA49> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
0x10430c000 - 0x10460cff7 +com.adobe.EAMedia.framework (13.0.0 - 13.0.0.203) <503291FC-E1E8-3D77-99AB-ED558FA05511> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
0x1049bc000 - 0x104f0afff +com.adobe.EAProjectBridge.framework (13.0.0 - 13.0.0.203) <88DFF4B8-BBB0-389A-A7FB-216418A7EDB0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
0x1055c9000 - 0x10576bfff +com.adobe.EAPrBridge.framework (13.0.0 - 13.0.0.203) <C54048D6-B0B1-3C8D-A18D-23A179EC4F62> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
0x1059ea000 - 0x105a43fff +com.adobe.dvatransport.framework (13.0.0 - 13.0.0.203) <8444344E-B6BD-39B3-8262-5B3B97966239> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
0x105ae2000 - 0x105b05fff +com.adobe.dvamarshal.framework (13.0.0 - 13.0.0.203) <5B1783FB-B1AB-3E48-A2F4-C62577DAB848> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
0x105b4a000 - 0x105d37fff +com.adobe.dynamiclink.framework (13.0.0 - 13.0.0.203) <08D84697-8EAA-39E4-B0B1-64B392F4AF29> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x10605d000 - 0x1069d4fff +com.adobe.dvaaccelerate.framework (13.0.0 - 13.0.0.203) <9CE283C8-9F9E-3192-8C81-6EEC75A06D04> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
0x106bb2000 - 0x106e2bfef +com.adobe.dvaaudiodsp.framework (13.0.0 - 13.0.0.203) <91F7ADF7-CEA9-3770-BC71-83BF6CF669FC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
0x1070fa000 - 0x1070fcff7 +com.adobe.Memory.framework (13.0.0 - 13.0.0.203) <DFAEF13E-7840-3B5C-8B4C-C6972F1CD8ED> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x107104000 - 0x1071c3fff +com.adobe.MediaFoundation.framework (13.0.0 - 13.0.0.203) <F8C2C587-BE26-35DE-B6B2-25CFE7F7AFA2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
0x1072bb000 - 0x10733aff7 +com.adobe.AudioRenderer.framework (13.0.0 - 13.0.0.203) <74B7B8BE-450A-36BB-8388-AD30FC2F3BD2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
0x107404000 - 0x107563fff +com.adobe.dvacaptioning.framework (13.0.0 - 13.0.0.203) <B843D987-6223-3EB3-9B68-1649B9EE97FD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
0x10766d000 - 0x1076bdff7 +com.adobe.dvatemporalxmp.framework (13.0.0 - 13.0.0.203) <4862F9A2-4A3B-3A66-A0AF-D2B91E8721E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x1076f4000 - 0x1077bafff +com.adobe.dvametadata.framework (13.0.0 - 13.0.0.203) <E68E703C-9B04-3FD0-BE25-B53A22D592B5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x1078b1000 - 0x108708fff +com.adobe.Backend.framework (13.0.0 - 13.0.0.203) <0AE70367-A3A6-35A5-AE46-9A530FD8580D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x109878000 - 0x1098f2ff7 +com.adobe.DynamicLinkMedia.framework (13.0.0 - 13.0.0.203) <8AAC47EB-56CA-3B58-B8EF-B6FF96F360D6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
0x1099fc000 - 0x109a2afff +com.adobe.MLFoundation.framework (13.0.0 - 13.0.0.203) <6A856708-20DB-3933-8EF8-0505ABAFBC9F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
0x109a89000 - 0x109bfcff7 +com.adobe.ImageRenderer.framework (13.0.0 - 13.0.0.203) <9F64BECA-1F82-39E0-8AF0-813D5566F998> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
0x109d61000 - 0x109dd1ff7 +com.adobe.VideoFrame.framework (13.0.0 - 13.0.0.203) <ECED4A28-131E-3C62-889D-2CB784985D05> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
0x109e4f000 - 0x109ea6fff +com.adobe.PluginSupport.framework (13.0.0 - 13.0.0.203) <1FD8C301-DD73-3CA8-95F2-D9E917816225> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
0x109f15000 - 0x109f44fff +com.adobe.SweetPeaSupport.framework (13.0.0 - 13.0.0.203) <03974591-B39D-32B1-8627-4D7920C300BB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
0x109f8c000 - 0x10a0d7ff7 +com.adobe.VideoRenderer.framework (13.0.0 - 13.0.0.203) <C0F68542-0E79-3F33-8040-57C5315E7E00> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
0x10a27c000 - 0x10a2bdff7 +com.adobe.AudioSupport.framework (13.0.0 - 13.0.0.203) <99DD0C0E-F571-36A2-AD00-4A7812BAC761> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
0x10a342000 - 0x10a35eff7 +com.adobe.MediaUtils.framework (13.0.0 - 13.0.0.203) <730292D2-91AC-35BD-9DCB-78A206A82E82> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
0x10a389000 - 0x10a56dff7 +com.adobe.ImporterHost.framework (13.0.0 - 13.0.0.203) <941DD855-0F0B-3D0E-8931-1633594AEED1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
0x10a843000 - 0x10a933fff +com.adobe.ExporterHost.framework (13.0.0 - 13.0.0.203) <28EBC949-8A5C-3C46-B042-81A8A2882323> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
0x10aa5f000 - 0x10aab7ff7 +com.adobe.ScriptLayer.framework (13.0.0 - 13.0.0.203) <7FE60339-B590-3BFC-A19F-81EBF7E94CE4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
0x10aba2000 - 0x10abc6ff7 +com.adobe.cloudservices.framework (13.0.0 - 13.0.0.203) <E37365C7-5821-3442-8FC5-82A84EF63F9E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/cloudservices.framework/Versions/A/cloudservices
0x10ac08000 - 0x10ac14ff7 +com.adobe.SharedSettings.framework (13.0.0 - 13.0.0.203) <E8609417-F1D9-3D21-B198-F1222A5004EE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SharedSettings.framework/Versions/A/SharedSettings
0x10ac48000 - 0x10acc66a7 dyld (625.13) <D6387150-2FB8-3066-868D-72E1B1C43982> /usr/lib/dyld
0x10ad29000 - 0x10ae77fff +com.adobe.VideoFilterHost.framework (13.0.0 - 13.0.0.203) <BFDEA03D-1E21-3975-A3D2-102A6E95E1DD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
0x10b019000 - 0x10b1ddff7 +com.adobe.EncoderHost.framework (13.0.0 - 13.0.0.203) <15852DFE-E263-3178-92B9-C3085A6A939D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
0x10b400000 - 0x10b544fff +com.adobe.dvaworkspace.framework (13.0.0 - 13.0.0.203) <0220F8C9-BDDE-3BEE-8C06-D1AAC851A909> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x10b7f1000 - 0x10b8d5ff7 +com.adobe.exo.framework (13.0.0 - 13.0.0.203) <46EEBB30-81CA-3BBE-8AE6-A1D9F80F423E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x10bac7000 - 0x10bca2fff +com.adobe.Batch.framework (13.0.0 - 13.0.0.203) <698B7533-FC22-3660-BD26-078CD736B78B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
0x10c044000 - 0x10c09ffff +com.adobe.AMEDynamicLinkClient.framework (13.0.0 - 13.0.0.203) <D228ABE4-0EC5-32D1-A88B-0B588D2B7DBC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEDynamicLinkClient.framework/Versions/A/AMEDynamicLinkClient
0x10c150000 - 0x10c2a9ff7 +com.adobe.dvametadataDB.framework (13.0.0 - 13.0.0.203) <040396E9-2C1E-3D47-A459-CCDF5B8B07C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
0x10c2f4000 - 0x10c392fff +com.adobe.AMEDynamicLinkServer.framework (13.0.0 - 13.0.0.203) <1C8FB5E8-9C1C-391C-91BD-01B432AB318B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEDynamicLinkServer.framework/Versions/A/AMEDynamicLinkServer
0x10c4dc000 - 0x10c500ff7 +com.adobe.AMEAppFoundation.framework (13.0.0 - 13.0.0.203) <B43F5621-CC58-37E2-8E55-85D5EF999927> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
0x10c555000 - 0x10c5a1ff7 +com.adobe.dynamiclinkUI.framework (13.0.0 - 13.0.0.203) <A7F58EF1-114B-3885-97A8-A23C69F60BE2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
0x10c63e000 - 0x10c980ff7 +com.adobe.AMEFrontend.framework (13.0.0 - 13.0.0.203) <D7F6D1F9-893D-36D4-9B7C-5C994C9E9011> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEFrontend.framework/Versions/A/AMEFrontend
0x10cebb000 - 0x10ced9ff7 +com.adobe.IngestGlue.framework (13.0.0 - 13.0.0.203) <FE902A9C-B30C-3C8C-AADA-71F2002244E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
0x10cf20000 - 0x10cf3cfff +com.adobe.postprocess.framework (13.0.0 - 13.0.0.203) <0F4AA40E-4C05-3AA5-B767-5520E34D546B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
0x10cf79000 - 0x10d2e4ff7 +com.adobe.SettingsUI.framework (13.0.0 - 13.0.0.203) <FF5E3499-A314-3658-BF02-FB111CD08B00> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
0x10d89f000 - 0x10d901ff7 +com.adobe.WatchFolder.framework (13.0.0 - 13.0.0.203) <95CB373E-A002-3173-AA01-96757DB499D3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/WatchFolder.framework/Versions/A/WatchFolder
0x10d9d9000 - 0x10da35ff7 +com.adobe.AudioFilterHost.framework (13.0.0 - 13.0.0.203) <6013D086-C222-30D2-80B4-0C6856F8F7B2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
0x10dacc000 - 0x10db02ff7 +com.adobe.AudioFilters.framework (13.0.0 - 13.0.0.203) <8C30BB00-F920-3B5B-BA47-FCD73510E76D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
0x10db76000 - 0x10db7dfff +com.adobe.dvabravoinitializer.framework (13.0.0 - 13.0.0.203) <09C0EC02-8E33-3381-B93D-7450F961FE97> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvabravoinitializer.framework/Versions/A/dvabravoinitializer
0x10db8e000 - 0x10dbb6fff +com.adobe.ImmersiveVideo.framework (13.0.0 - 13.0.0.203) <F86DA200-997A-3AF3-B355-1255CB4DB7A6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
0x10dbd6000 - 0x10dc51fff +com.adobe.DisplaySurface.framework (13.0.0 - 13.0.0.203) <5F67F404-A170-37BF-ACC8-781D522E5653> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
0x10dce4000 - 0x10ddfcfff +com.adobe.dvascripting.framework (13.0.0 - 13.0.0.203) <8B669103-C770-3730-B5A9-4895E7F8C4A3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
0x10e0a0000 - 0x10e0f2fff +com.adobe.FontEngine.framework (13.0.0 - 13.0.0.203) <1DEAFDB4-5D66-39AB-A36C-B542142E154B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
0x10e185000 - 0x10e19eff7 +com.adobe.TitleLayer.framework (13.0.0 - 13.0.0.203) <D1FFEEB1-3AD8-3096-B8F7-57BB4C4FF368> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
0x10e33b000 - 0x10e343ff7 +com.adobe.TitleImageManager.framework (13.0.0 - 13.0.0.203) <1A48B078-57EA-369E-87D7-8275E7BD7738> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
0x10e352000 - 0x10e3d0fff +com.adobe.TitleCharacterFactory.framework (13.0.0 - 13.0.0.203) <5FF7EB84-D328-3311-8291-A2E65386D303> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
0x10e422000 - 0x10e57eff7 +com.adobe.TitleCG.framework (13.0.0 - 13.0.0.203) <9E3AFED1-0D33-32E8-9A3C-384B624DA978> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
0x10e68c000 - 0x10e8bafff +com.adobe.TitleLayout.framework (13.0.0 - 13.0.0.203) <5FB0F02B-77A2-31CE-AE44-B37D8D71EB69> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
0x10edcb000 - 0x10ee20ff7 +com.adobe.TitleRenderer.framework (13.0.0 - 13.0.0.203) <89144B40-A3A3-393A-8D62-6530A7A89363> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
0x10eeb6000 - 0x10f0b1fff +com.adobe.MBCProvider.framework (13.0.0 - 13.0.0.203) <A4C0B806-625F-3E87-8FD6-B90627F14DF1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
0x10f20c000 - 0x10f27eff7 +com.adobe.PlayerHost.framework (13.0.0 - 13.0.0.203) <9D04191D-ADDF-3FA8-80E0-21E29AEAB330> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
0x10f36d000 - 0x10f380ff7 +com.adobe.ProjectConverterHost.framework (13.0.0 - 13.0.0.203) <C12B992C-9A09-3FE8-A3D8-6D9BC3A1EEDD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
0x10f3a8000 - 0x10f3c2fff +com.adobe.ProjectSupport.framework (13.0.0 - 13.0.0.203) <69A4F771-7B11-34AB-A0FD-FB7F81CEC303> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
0x10f3fa000 - 0x10f4daff7 +com.adobe.CodecSupport.framework (13.0.0 - 13.0.0.203) <5CFC4BF1-CE90-3A0C-B277-76D329B47067> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
0x10f59f000 - 0x10f5c3ff7 +com.adobe.dvavulcansupport.framework (13.0.0 - 13.0.0.203) <C9FA1F27-3BA2-3653-8B08-835FB355963C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
0x10f5fb000 - 0x10f661fff +com.adobe.csxsmanager.framework (13.0.0 - 13.0.0.203) <6E063E9E-DE4B-3C80-B5E3-4AA878E9B9A5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
0x10f6ec000 - 0x10f8fcff7 +com.adobe.GPUFoundation.framework (13.0.0 - 13.0.0.203) <8759DCAB-1EEB-33B8-95E8-EEA81C7481EE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
0x10fa5b000 - 0x10fc48ff7 +com.adobe.RendererGPU.framework (13.0.0 - 13.0.0.203) <6EA0F2D3-56C4-3B02-9E56-660407184EFC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
0x10fd9e000 - 0x10fdfcff7 +com.adobe.dvamediaui.framework (13.0.0 - 13.0.0.203) <A6724084-499D-3D7C-A9E0-3E1B434D2922> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
0x10febf000 - 0x110042fff +com.adobe.dvamediabrowser.framework (13.0.0 - 13.0.0.203) <83330B99-6595-3F49-AB8B-6C38C96AF964> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
0x110325000 - 0x110441ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.163499) <7CE7074B-ED39-31E5-9998-4A29FBD07EE9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x1105a1000 - 0x110712ff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 51 - 79.163499) <D9246333-E422-3CBC-8841-4D75836763AD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x110873000 - 0x110908fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <1EB545A5-0EEF-3BDF-B625-4ADF18A8E686> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
0x1109a3000 - 0x110a3cfff +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <3D784486-7FBA-3666-96BF-894172D1D142> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
0x110ae8000 - 0x110bf3ff7 +com.adobe.ACE (AdobeACE 2.20.02.41706 - 2.20.02.41706) <FC3950C6-2B16-3AA2-B185-F70F87B9F5DA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x110c0c000 - 0x1110e2fff +com.adobe.AGM (AdobeAGM 4.30.87.41706 - 4.30.87.41706) <EA4ABA10-5017-3B6B-95CC-D92B461BDD7B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x11118f000 - 0x1111a5fff +com.adobe.BIB (AdobeBIB 1.2.03.41706 - 1.2.03.41706) <E6EC9F2C-B761-333F-A528-FD05C70068DE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x1111ae000 - 0x1114a4ff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.41706 - 5.17.00.41706) <570DEEF4-688C-31D8-83FB-AA718115E5F5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x1114f6000 - 0x11169efff +com.adobe.headlights.LogSessionFramework (8.0.0.46.47979) <C8618457-89D1-384A-8EAD-43823AEF86AB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x11183c000 - 0x111ac6fc7 +com.adobe.PlugPlug (9.2.1.39 - 9.2.1.39) <5BAB72EB-96AE-36EA-9E82-9C7377D5ADD5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x111d43000 - 0x111e41ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x111e6f000 - 0x111e8bffb +com.adobe.libzip.framework (13.0.0 - 13.0.0.203) <0CD835FB-18D5-3424-BF11-FDD7B09EABCC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
0x111ea3000 - 0x111ec7fff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VulcanControl.dylib
0x111ef4000 - 0x111f2fff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VulcanMessage5.dylib
0x111f79000 - 0x112105ff7 +com.adobe.dvaaudiofilters.framework (13.0.0 - 13.0.0.203) <C233BAD2-EE4D-375C-8706-DC39C209FAF3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
0x112334000 - 0x1125e5ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libxerces-c-3.1.dylib
0x112795000 - 0x1127aefff +com.adobe.TeamProjectsLocalClient.framework (13.0.0 - 13.0.0.203) <AFAC943A-3298-311E-BBFC-46FC6AB17D51> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLocalClient
0x1127e8000 - 0x1128a9fff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.163499) <1381AAF4-3CBB-38C1-BBCF-FED0F2AF34D3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompareAndMerge
0x112a14000 - 0x112accff7 +com.adobe.ColorSpaceConverter.framework (13.0.0 - 13.0.0.203) <A574E6AB-237C-3DBA-AD31-FD8F8FB982F1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ColorSpaceConverter.framework/Versions/A/ColorSpaceConverter
0x112b42000 - 0x112b52ff7 +com.adobe.ACEWrapper.framework (13.0.0 - 13.0.0.203) <27E32138-F1FA-352A-AAE6-355EA81C88B3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ACEWrapper.framework/Versions/A/ACEWrapper
0x112b75000 - 0x112b94ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.41706 - 1.1.41706) <571B5070-B38D-3D5A-8658-33C16CB963C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x112b9c000 - 0x112bb2ff7 +com.adobe.RuntimeInstaller.framework (13.0.0 - 13.0.0.203) <1630DF90-9199-336D-8B25-9EF5F3AA7C63> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
0x112bd1000 - 0x112cd2fff +com.mainconcept.mc.mfimport (10.5 - 10.5.18.0000) <239D9891-75B3-35DA-9523-52DF4F1B81EF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
0x112ce3000 - 0x113054fe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.18.0000) <88B2A327-A7BD-365D-BFC5-A47FCB6CA834> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
0x11318d000 - 0x11339ffc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.18.0000) <0001E005-5103-3A41-B642-15F4525DBB2E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
0x1133e3000 - 0x113674ff7 +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.18.0000) <CEC9696E-3BCE-36A7-B2D1-FD8E616EDE74> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
0x1136a1000 - 0x11383afef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.18.0000) <5439586D-D789-30B7-8D74-7688C4149491> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
0x113849000 - 0x113adbfcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.18.0000) <DB8F4720-6CB8-3876-9620-3CAC63EE187E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
0x113af2000 - 0x113ccafe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.18.0000) <3A6C38F7-AB6D-3520-BE1E-C75E3EDFCD33> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
0x113cdd000 - 0x115246fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
0x115442000 - 0x1155b5fef +com.mainconcept.mc.trans.video.colorspace (10.5 - 10.5.18.0000) <32A0CE5A-A476-324A-93E3-59EF0F32C95B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_trans_video_colorspace.framework/Versions/10/mc_trans_video_colorspace
0x1155c2000 - 0x11560bfdf +com.adobe.ProResOpt.framework (13.0.0 - 13.0.0.203) <208036B1-BDF3-354B-826E-4A392CAFF42D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
0x115654000 - 0x115660fff +com.adobe.QT64Utils.framework (13.0.0 - 13.0.0.203) <8D0E177E-C4C9-3363-BD2E-A813157D48E2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
0x115677000 - 0x115b58fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libDNxHR.dylib
0x115c47000 - 0x115db6ff7 +libSonyRawDev.dylib (3.1) <0128E0CE-B6D4-316B-B125-008B8AC7C40B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libSonyRawDev.dylib
0x115e52000 - 0x1171c8fff +libArriRawSDK.dylib (0) <F09C8C7E-AD5F-339E-900B-2E47789A5A9B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libArriRawSDK.dylib
0x117900000 - 0x1179dcfe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmp4decMT.dylib
0x117a3b000 - 0x117b45fff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libCFHDDecoder.dylib
0x117be6000 - 0x117ce8fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libCFHDEncoder.dylib
0x117d97000 - 0x117ec5ff3 +libkdu_as7AR.dylib (0) <4953AF4F-BB7F-3CFE-9594-77748AD230CB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libkdu_as7AR.dylib
0x117f2a000 - 0x118097feb +libkdu_vs7AR.dylib (0) <11C608BE-DC34-352B-90B6-C1A9428AA898> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libkdu_vs7AR.dylib
0x1180db000 - 0x118118ff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libcudart.6.5.dylib
0x118124000 - 0x11823cfdf +libiomp5.dylib (0) <C97AB725-E5D2-31C7-81BD-8CAA641357CD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libiomp5.dylib
0x1182a4000 - 0x1182eaff7 +libtbb.dylib (0) <8B2D7D64-9404-3E6D-A7A5-6B76038F4450> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libtbb.dylib
0x11833f000 - 0x11836ffef +libtbbmalloc.dylib (0) <3CE44609-95E5-35E1-8167-17A4F4DA2378> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libtbbmalloc.dylib
0x1183b5000 - 0x1183e8ff7 +com.adobe.QTParser.framework (13.0.0 - 13.0.0.203) <D8BB20B2-701F-3814-B5F3-9D5F373B1FEA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
0x118410000 - 0x1184f5fdf +libProResDecoder.dylib (0) <04FA87AB-AC1C-3B5E-A76B-B74F2367BCAA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libProResDecoder.dylib
0x118536000 - 0x118571fff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libcudart.dylib
0x11857f000 - 0x118595ff7 +com.adobe.CCLibrariesSupport.framework (13.0.0 - 13.0.0.203) <DC2EA830-56E3-3172-904E-B80097F80C4B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
0x1185cc000 - 0x118732fcf +com.adobe.atl-audio.framework (13.0.0 - 13.0.0.203) <1228A4DE-DF78-387E-BE75-80D907CC9737> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
0x118770000 - 0x11889ffff +com.adobe.dvaaudiodevice.framework (13.0.0 - 13.0.0.203) <8D5B04E5-5271-3A41-B9D1-A50EC7D7861A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
0x118b34000 - 0x118bddfff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 041 - 79.163581) <D83DE453-EEA5-396C-8BA2-FF58EE15CF1F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
0x118c80000 - 0x118d58fff +com.adobe.OpticalFlow.framework (13.0.0 - 13.0.0.203) <2092497B-0EB7-3B4A-B329-620C710948AF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
0x118e20000 - 0x119315fff +com.adobe.ATEWrapper.framework (13.0.0 - 13.0.0.203) <0A3B11DF-C9F8-3FA9-B8D6-F812EB739BB9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
0x119890000 - 0x11b190fff +com.adobe.ICUData (58.2 - 3.61) <8E068A48-E220-3267-8756-3D2A19B07964> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUData.framework/Versions/58.2/ICUData
0x11b1e5000 - 0x11b2baff7 +com.adobe.ICUConverter (58.2 - 3.61) <7E138985-1007-3EF5-A253-50740FE803FB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUConverter.framework/Versions/58.2/ICUConverter
0x11b2fe000 - 0x11b42dff3 +com.adobe.ICUUnicode (58.2 - 3.61) <DCF3DD51-98E8-3780-87CB-EB4598F0742C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUUnicode.framework/Versions/58.2/ICUUnicode
0x11b49c000 - 0x11b658ff7 +com.winsoft.wrservices (WRServices 14.0.0 - 14.0.0) <8912A48C-5441-3D15-93FB-C91BD026FD32> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
0x11b6e1000 - 0x11b709ff7 +com.adobe.TimeCarving.framework (13.0.0 - 13.0.0.203) <7E3DE647-2952-3DB2-A437-8CCE38D53990> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
0x11b74f000 - 0x11b765ff7 +com.adobe.dvanetsync.framework (13.0.0 - 13.0.0.203) <B413BE97-9F3E-3733-BCF5-265995686B50> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
0x11b7a3000 - 0x11b7dfff7 +com.adobe.boost-serialization.framework (13.0.0 - 13.0.0.203) <8D18D56C-9E1B-3707-8D3D-F8CD015892EC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
0x11b8ac000 - 0x11be95fff +com.adobe.TeamProjectsLocalLib.framework (13.0.0 - 13.0.0.203) <0746F0AC-81AC-3189-B5C7-A3D7CC38C20B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalLib
0x11c4df000 - 0x11c512fff +com.adobe.boost-program-options.framework (13.0.0 - 13.0.0.203) <DA4144EF-A9CC-339A-9F8B-5AEDAD8C8DD3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_options
0x11c571000 - 0x11c6afff7 +com.adobe.dvastorage.framework (13.0.0 - 13.0.0.203) <D42FD183-549D-3D95-8066-AA69967613A1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
0x11c724000 - 0x11c7dbff7 +com.adobe.dvacapsule.framework (13.0.0 - 13.0.0.203) <1EB00660-0C87-3776-A9AA-50E862F4BB3E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacapsule.framework/Versions/A/dvacapsule
0x11c8eb000 - 0x11c99dfff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libgit2.dylib
0x11c9c1000 - 0x11ca95ff7 +com.adobe.cclibmanager.framework (13.0.0 - 13.0.0.203) <B08A8625-2BB8-360B-A5E7-EF398BA77694> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/cclibmanager.framework/Versions/A/cclibmanager
0x11ccbf000 - 0x11cd3aff7 +com.adobe.RecorderHost.framework (13.0.0 - 13.0.0.203) <0E017E76-4F38-36D5-B0AC-5775F77C28AF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
0x11ce4a000 - 0x11d29efff +com.adobe.UIFramework.framework (13.0.0 - 13.0.0.203) <CA8B6D99-E5E7-38A5-AED3-97CA8055DAC5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
0x11dbce000 - 0x11e7e6ff7 +com.adobe.Mezzanine.framework (13.0.0 - 13.0.0.203) <936F1AEB-AFEC-30A1-B198-E3E4B84E2373> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
0x11f591000 - 0x11fb21ff7 +com.adobe.Dialogs.framework (13.0.0 - 13.0.0.203) <282AA77D-4ED3-37CA-BE71-3B6CF27590EB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
0x120167000 - 0x120390fff +com.adobe.IngestCore.framework (13.0.0 - 13.0.0.203) <DF22E48C-58D1-3BA4-A7B8-5F79A385440B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
0x12070a000 - 0x120750ff7 +com.adobe.TransmitHost.framework (13.0.0 - 13.0.0.203) <FB95225F-CDA0-382D-AAF1-F2F1CFEC8F81> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
0x1207b7000 - 0x120858ff7 +com.adobe.dvascriptedworkflow.framework (13.0.0 - 13.0.0.203) <EE1E1AA2-B659-32BE-8107-9A2DC0B7D3D6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascriptedworkflow.framework/Versions/A/dvascriptedworkflow
0x1209db000 - 0x120a64fff +com.adobe.MediaFinder.framework (13.0.0 - 13.0.0.203) <F9F1BB7E-AADC-3B65-82A3-2C4A60436A67> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
0x120b72000 - 0x120d1bfff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
0x120e47000 - 0x120e90ff7 +com.adobe.ahclientframework (4.0.0.0 - 4.0.0.0) <51C89AA8-9D51-31E7-BD87-F0949DF0EB2A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x120ecd000 - 0x120ed3ff7 +com.adobe.dvaundo.framework (13.0.0 - 13.0.0.203) <6A0B8CAD-FD7B-3420-B3AB-AC51439736C0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
0x120ee1000 - 0x120f99ff7 +com.adobe.essentialsound.framework (13.0.0 - 13.0.0.203) <30B0F423-9CB1-3A41-A945-3443DF615814> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
0x1210b0000 - 0x121117ff7 +com.adobe.dvaaudiofilterhostui.framework (13.0.0 - 13.0.0.203) <B8DC34B3-615C-3509-A3F1-046799D542B2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
0x12120f000 - 0x121305ff7 +com.adobe.dvametadataUI.framework (13.0.0 - 13.0.0.203) <CD8078DC-2718-3C0D-8A07-1B360C193015> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x121463000 - 0x12146dff7 +com.adobe.dvamarkerUI.framework (13.0.0 - 13.0.0.203) <3118720C-98C7-3DD0-A1F4-4BA8B1D8D49E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
0x121492000 - 0x1214bcff7 +com.adobe.dvatypekit.framework (13.0.0 - 13.0.0.203) <60768F27-70A6-3DD1-8333-5424CA8B080D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
0x1214fd000 - 0x1215a8fff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
0x1215d4000 - 0x121607fff +com.adobe.dvacontrolsurfacehost.framework (13.0.0 - 13.0.0.203) <27E95B18-6783-304B-905E-5227DF2A0692> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
0x121694000 - 0x1216d2fff +com.adobe.dvaaudiodeviceui.framework (13.0.0 - 13.0.0.203) <DE5CA40B-3C2D-3248-8B25-31963C74CF4B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
0x121738000 - 0x1219a4fff +com.adobe.Registration.framework (13.0.0 - 13.0.0.203) <FDF6544B-8765-37B8-92F1-E6174CA79B20> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
0x121bd5000 - 0x121c85fff +com.adobe.dvascriptingES.framework (13.0.0 - 13.0.0.203) <14354C9C-B1D1-374E-8E85-651E0C625410> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
0x121d98000 - 0x121e7dff7 +com.adobe.IngestDialog.framework (13.0.0 - 13.0.0.203) <3B9AA0E2-B902-3AA1-9253-8FFDF21258EC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
0x124dc8000 - 0x124de0fff com.apple.security.csparser (3.0 - 58286.200.222) <7BC2CE7B-69F5-3A24-B4C2-52A7E075D9AD> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x1271e4000 - 0x1271e6ffb com.apple.textencoding.unicode (5.0 - 5.0) <8F8EAF7E-BE4A-363A-A855-B817C81CF951> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x127289000 - 0x1272affef +com.mainconcept.mc.enc.dv (10.5 - 10.5.18.0000) <EA916625-DD33-3B51-AAB8-00A9AAFEB2A2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
0x1272c4000 - 0x1272c8fff com.apple.audio.AppleHDAHALPlugIn (282.10 - 282.10) <94DDF962-09E0-3B3E-B887-9A0301022190> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x12aa15000 - 0x12aa1bff7 +com.adobe.ExporterPNG.framework (13.0.0 - 13.0.0.203) <684C3499-A212-310C-970F-484F2353DC3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterPNG.bundle/Contents/MacOS/ExporterPNG
0x12aa5e000 - 0x12aa65fff +com.adobe.ExporterAIFF.framework (13.0.0 - 13.0.0.203) <D42AD785-5CED-394D-A2A0-577FE73CBE14> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterAIFF.bundle/Contents/MacOS/ExporterAIFF
0x12c6b2000 - 0x12c6eafff +com.adobe.pip (8.0.0.46.47979) <EAE71E0D-9079-34DF-97E2-341DCA74223D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x12c7b8000 - 0x12c7bbffb +com.adobe.AfterEffects.Standard3D (0) <6F4D96AD-D80E-35BB-94C5-1FC47F6FF45C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Required/Standard3D.plugin/Contents/MacOS/Standard3D
0x12c904000 - 0x12c907ff7 +FastCore (18.1.0 - 18.1.0) <7ACD8C31-E08B-303E-A024-73A7F35BD451> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/FastCore.plugin/Contents/MacOS/FastCore
0x12ec5e000 - 0x12edaeff7 +IMSLib.dylib (10.0.0.35 - 10.0.0.35) <0F67F73D-2BD4-3432-AB6F-47C632068CBB> /Library/Application Support/Adobe/*/IMSLib.dylib
0x12edd2000 - 0x12ef43ff7 +imshelper.dylib (1.0.0.22 - 1.0.0.22) <D1014FA3-607E-3AA8-8D56-04723CF5EFB1> /Library/Application Support/Adobe/*/imshelper.dylib
0x12f4a4000 - 0x12f4a7047 libobjc-trampolines.dylib (750) <B81473FA-927B-3852-BC34-66E66AAE24F4> /usr/lib/libobjc-trampolines.dylib
0x12f4ad000 - 0x12f4cdff7 +com.adobe.ExporterDPX.framework (13.0.0 - 13.0.0.203) <38972A33-9C81-38CD-8878-5605614B1BBD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterDPX.bundle/Contents/MacOS/ExporterDPX
0x12f56d000 - 0x12f574ff7 +com.adobe.ExporterTIFF.framework (13.0.0 - 13.0.0.203) <4DB0D288-0373-3628-B6D0-0E6E5883A889> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterTIFF.bundle/Contents/MacOS/ExporterTIFF
0x12f608000 - 0x12f61cfff +com.adobe.ExporterWave.framework (13.0.0 - 13.0.0.203) <38E080CE-E893-3992-993A-DCD891A171E6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterWave.bundle/Contents/MacOS/ExporterWave
0x12f6ca000 - 0x12f6cffff +com.adobe.ExporterTarga.framework (13.0.0 - 13.0.0.203) <165302D2-314E-36B8-B172-6C40E33F2263> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterTarga.bundle/Contents/MacOS/ExporterTarga
0x12f815000 - 0x12f833fff +com.adobe.ExporterJPEG.framework (13.0.0 - 13.0.0.203) <6CB210B1-1B6B-3588-AC16-240FCC6F4F05> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterJPEG.bundle/Contents/MacOS/ExporterJPEG
0x12fde2000 - 0x12fdebfff +com.adobe.ExporterGIF.framework (13.0.0 - 13.0.0.203) <D6676312-9542-3234-9DEE-86FEF1034EA5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterGIF.bundle/Contents/MacOS/ExporterGIF
0x12fe9c000 - 0x12ffccff7 +com.adobe.ExporterP2.framework (13.0.0 - 13.0.0.203) <996AA587-A522-3CDB-9A66-B0FD740A9A33> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
0x130106000 - 0x130147fff +com.adobe.ExporterMPEGPreview.framework (13.0.0 - 13.0.0.203) <4BA1C714-0416-36FE-93A2-2AD3DF7C0D4D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGPreview
0x1301e5000 - 0x13021eff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.18.0000) <705CFB3A-7678-3F89-B96A-83657D1415FA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
0x1304b9000 - 0x130510fe7 +com.adobe.ExporterMP3.framework (13.0.0 - 13.0.0.203) <28B09975-319E-3986-8958-5754823E4B7F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMP3.bundle/Contents/MacOS/ExporterMP3
0x13061b000 - 0x1306e4ff7 com.apple.AMDRadeonX4000GLDriver (2.0.36 - 2.0.0) <0A445D3B-E2FC-3808-AB69-0AF62ED70D14> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x13172f000 - 0x131748fff +com.adobe.ImporterAVFoundation.framework (13.0.0 - 13.0.0.203) <E0C67E09-34CF-3BAF-B4CB-A7745093DB98> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFoundation
0x13176d000 - 0x1317a1fff +com.adobe.PlatformAudioCodecs.framework (13.0.0 - 13.0.0.203) <AE4A2D98-0BD5-3EBE-A0C7-8DBFEA6B9158> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
0x1317d4000 - 0x1317daff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.18.0000) <B17D83C0-6733-3984-9DB4-56181F934BF2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
0x1317e0000 - 0x13180aff7 +libMOG_Framework.5.0.15.dylib (0) <85570972-CC5B-3B3A-BB97-43F74815F910> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.15.dylib
0x131828000 - 0x131837fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.18.0000) <F1C0C327-9096-34E6-B97D-EF0208AA0D07> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
0x1348f1000 - 0x1349c9ff7 +REDMetal.dylib (0) <0C988F53-14FA-35D8-9F57-9A11C47CF981> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/REDMetal.dylib
0x134cfb000 - 0x134d0bff7 +com.adobe.TransitionsMetaPlugin.framework (13.0.0 - 13.0.0.203) <8B08B8A2-75F4-34F5-B2F7-81AFC0094624> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMetaPlugin
0x134d1f000 - 0x134d29fff +com.adobe.PremiereFiltersMetaPlugin.framework (13.0.0 - 13.0.0.203) <49ADBE01-36A9-3FDF-ACC4-3B11BC8DC8FE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFiltersMetaPlugin
0x135100000 - 0x135195fff +com.adobe.ImporterRED.framework (13.0.0 - 13.0.0.203) <C37B9839-199A-341A-8EB0-3E5346C1DF16> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
0x1354a1000 - 0x1354b7ff7 +com.adobe.ImporterSensorManager.framework (13.0.0 - 13.0.0.203) <C1FDF1AA-1596-3DEC-BA05-C0790D51B639> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterSensorManager.bundle/Contents/MacOS/ImporterSensorManager
0x1354dc000 - 0x1354e3ff7 +LIST.dylib (0) <5189A970-DAC7-34AD-BF82-523E6349000A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/LIST.dylib
0x1354f4000 - 0x1354f7ffb +VAL.dylib (0) <6A7593E4-44AA-3361-9EF6-0EC7A4041BC4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VAL.dylib
0x135600000 - 0x1357d0fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
0x135da0000 - 0x135e99fff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.18.0000) <4060AF33-C621-36CA-90DE-7FD1692B538F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
0x135eab000 - 0x135f66ff7 +com.adobe.ExporterXDCAMHD.framework (13.0.0 - 13.0.0.203) <ECAEABAB-6270-3C2C-BF11-48A907DB58C3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
0x13602f000 - 0x13635afef +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.9603) <677C9D0F-DFCF-39C0-AB6A-D5E9F8852AF2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
0x13647e000 - 0x13666ffe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.18.0000) <CD9D9A4B-F450-3CF9-82D8-B134AB167E80> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
0x1366c3000 - 0x136a3cfff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.18.0000) <CEC65258-20AA-3957-BE94-BC16FCF47E0D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
0x136b76000 - 0x137301fff +libMXF_SDK.5.0.15.dylib (0) <9385AD7F-8D09-3761-8A2E-EFCDF6C8D1DF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.15.dylib
0x1378c3000 - 0x1378f3fff +com.adobe.ARE (AdobeARE 1.5.02.41706 - 1.5.02.41706) <63D929CD-D174-328F-A35C-3F8336FC3070> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x137c00000 - 0x137d5cfe7 +com.adobe.ExporterMPEG4.framework (13.0.0 - 13.0.0.203) <C294D9F9-98FD-319D-9584-7240A1CAC5F7> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
0x137e10000 - 0x137f24ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.18.0000) <0146E5C7-A69D-3B7E-9DD5-ECD50804334D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
0x137f3c000 - 0x137f75ff7 +com.adobe.RendererCPU.framework (13.0.0 - 13.0.0.203) <1BC4BE7F-C36E-3570-B241-966C77D3BA3B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
0x137fbc000 - 0x137fc9ff7 +BEZ.dylib (0) <A11BA203-09D8-3B06-9056-8782289120A9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/BEZ.dylib
0x137fd5000 - 0x137fe6fff +com.adobe.GPUKernels.framework (13.0.0 - 13.0.0.203) <AAEE818C-49D6-37F9-A990-2FF3E6CCE2E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
0x138800000 - 0x138c55fff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
0x139118000 - 0x1392e6fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.18.0000) <B081472A-D511-3B55-BC6C-6DA4ACC5C428> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
0x13932a000 - 0x1393d1fcf +com.adobe.IPPMPEGDecoder.framework (13.0.0 - 13.0.0.203) <DEDBD963-5AEB-3893-B279-F74651C9BC1F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
0x13950a000 - 0x13964cfff +com.adobe.ExporterMXF.framework (13.0.0 - 13.0.0.203) <5ED6FE2A-86D6-35DB-8ADB-3E27CB4F4F6C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
0x1396f5000 - 0x139754fff +com.adobe.PlayerMediaCore.framework (13.0.0 - 13.0.0.203) <41019EB6-5746-379B-80AB-EF96B7145E1C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
0x1397c3000 - 0x139844fff +com.adobe.ExporterMPEG2.framework (13.0.0 - 13.0.0.203) <7956252C-072A-3DC7-8AA6-D278340ABF6A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
0x1398ab000 - 0x139900fff +com.adobe.ExporterQuickTimeHost.framework (13.0.0 - 13.0.0.203) <831886A5-DF0C-3400-A8A9-9976960A9C8E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuickTimeHost
0x139943000 - 0x13995dff7 +com.adobe.QTWriter.framework (13.0.0 - 13.0.0.203) <CDC072A1-E088-3A76-9BEA-99C6CCA9BD61> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
0x13998a000 - 0x139a69fff +com.adobe.aelib.framework (16.0.0 - 16.0.0.235) <8823DA6F-48D2-3343-B369-98BFD1D13CEC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/aelib.framework/aelib
0x139bbb000 - 0x139c27fff +com.adobe.boost-test.framework (13.0.0 - 13.0.0.203) <C18C91E8-842C-35C0-AF3D-78A3427133A6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_test.framework/Versions/A/boost_test
0x139cbc000 - 0x139d7eff7 +com.adobe.JP2K (1.2.2 - 1.2.2.41336) <5210D413-6DF1-337C-AE4B-EED426047288> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x139dc6000 - 0x13a11dfff +com.adobe.MPS (AdobeMPS 5.8.1.41653 - 5.8.1.41653) <F4E72D92-835F-3736-892D-641BCDF3A25A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x13a198000 - 0x13a9b7fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.41785) <508ACD0B-9ED6-332B-B5A6-48B78DDF8FA5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x13afcb000 - 0x13aff1ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.41336 - 3.8.0.41336) <1C2D547C-0F9E-3170-AE6D-793E811E2601> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x13b016000 - 0x13b03cfff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.41336 - 3.8.0.41336) <0B10C368-525F-3F7B-B8BA-EA0B283F0B07> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
0x13b061000 - 0x13b127ff7 +com.adobe.drawbotagm.framework (13.0.0 - 13.0.0.203) <D8340A84-F6D9-39F8-A119-7C6A479B06F8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
0x13b1fb000 - 0x13b2befff +U.dylib (0) <38031625-81A5-39BC-B1A0-B861522AACC4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/U.dylib
0x13b3b3000 - 0x13b4c4ff7 +MEE.dylib (0) <1C0A0E74-2165-3FC3-B558-CBBCBE57C273> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MEE.dylib
0x13b5d7000 - 0x13b615ff7 +aedisplay.dylib (0) <98CC64CD-4E41-3D28-B7BB-3C479599A231> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/aedisplay.dylib
0x13b659000 - 0x13b67efff +FILE.dylib (0) <746CEFCF-DDC4-3BE3-8340-DE3E02AA17F1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FILE.dylib
0x13b6b4000 - 0x13b70bff7 +SLU.dylib (0) <B11E31A5-162E-3D40-9076-F7C78E9E03C2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SLU.dylib
0x13b79e000 - 0x13b7b8ff7 +PREF.dylib (0) <E25E39F9-4352-317D-A55C-0867E74E0322> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PREF.dylib
0x13b7da000 - 0x13b829fff +TDB.dylib (0) <F29DF640-2AC4-3F5F-8757-3F6ABE77302E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TDB.dylib
0x13b897000 - 0x13b8ccff7 +MC.dylib (0) <07433EE7-634D-3C89-9A25-5001D01C3E31> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MC.dylib
0x13b91e000 - 0x13b955ff7 +COR.dylib (0) <AC2F5434-9FFA-36B2-B17A-16FD3C8A001B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/COR.dylib
0x13b9b0000 - 0x13bca8fff +PF.dylib (0) <C37F67B1-402A-3487-AA1D-0C379FF79BBE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PF.dylib
0x13be29000 - 0x13c2f5fff +TXT.dylib (0) <81AE9D74-96BB-3408-810C-3E3D292E521D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TXT.dylib
0x13c8d2000 - 0x13c924ff7 +TDL.dylib (0) <C0FB9135-9749-350D-9FF0-4A91C2200A4A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TDL.dylib
0x13c964000 - 0x13c9a1fff +OM.dylib (0) <C0B9C6B8-B818-380B-8765-61AFFC811011> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/OM.dylib
0x13c9df000 - 0x13ca03ff7 +P.dylib (0) <A2BA2BAE-BD87-39C6-9C15-DA1600D05806> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/P.dylib
0x13ca1d000 - 0x13ca49ff7 +PREM.dylib (0) <0765EE18-9C08-3F46-BA9F-7A62B74E84FF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PREM.dylib
0x13ca99000 - 0x13cae0fff +SND.dylib (0) <C6321453-49CE-38D2-9B88-49162B04AD3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SND.dylib
0x13cb48000 - 0x13cd8ffff +PIN.dylib (0) <049E15C0-3FFE-3AC1-A90F-5FEF35BD751C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PIN.dylib
0x13cf86000 - 0x13cfb8ff7 +RG.dylib (0) <0A3F298F-0C59-386B-B79B-355E7A7AC193> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RG.dylib
0x13cffc000 - 0x13d0c3ff7 +FLT.dylib (0) <03BDE5DF-B369-394D-BE18-D539E0301EC5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FLT.dylib
0x13d218000 - 0x13d26bfff +MSK.dylib (0) <FE09B94F-BC3E-3765-AAD9-AAFBAE3EE185> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MSK.dylib
0x13d2be000 - 0x13d379fff +FRP.dylib (0) <C5A05F27-84CF-32BF-92A7-5B97C0B162C1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FRP.dylib
0x13d470000 - 0x13d489ff7 +PR.dylib (0) <D576175E-C0A4-3468-93B3-86ADE8F1B2C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PR.dylib
0x13d4be000 - 0x13e71cff7 +BEE.dylib (0) <67085929-55A3-3D68-A1E9-CBDBEEBEBC52> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/BEE.dylib
0x13fb1a000 - 0x13fb60ff3 +FLO.dylib (0) <B6454703-8E51-306B-8B3C-0FB138C7BFF1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FLO.dylib
0x13fb82000 - 0x13fb92ff7 +PLUG.dylib (0) <CBB15694-EECE-344A-9AD0-E5E8DA8AAC73> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PLUG.dylib
0x13fbaf000 - 0x13fe03fd7 +com.adobe.AIDE (1.5.0 - 1.5.0.41688) <0342B9A3-C636-3CB7-BCC8-E1C672E393C6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x13fe37000 - 0x13ff1afff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.41336 - 3.8.0.41336) <F77B6193-5D17-304C-AEB1-51E8A543D747> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x13ffc4000 - 0x140085ff7 +com.adobe.dvaplayer.framework (13.0.0 - 13.0.0.203) <3FDE29C3-7D4B-3C76-94DC-15CC13013161> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
0x14021e000 - 0x140236fff +com.adobe.eaurl.framework (13.0.0 - 13.0.0.203) <DA45BD43-AFCD-3F1E-8202-44D2A9739097> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
0x140264000 - 0x14254aff7 +com.adobe.psl (AdobePSL 15.1.0.41703 - 15.1.0.41703) <BF0F550E-CDE7-38EF-81A9-610D9896FA95> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x142868000 - 0x143727fe7 +libmkl_intel_lp64.dylib (0) <783D2EDB-A8C3-3084-99DA-C78F4E3FC565> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_intel_lp64.dylib
0x14392f000 - 0x145adaff7 +libmkl_intel_thread.dylib (0) <B4F72FD0-8AE6-3B01-B3F7-F1C1865ACE3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_intel_thread.dylib
0x146340000 - 0x14a38ff37 +libmkl_avx512.dylib (0) <ACF63D70-A801-3F03-9FD4-85F3E63631BD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_avx512.dylib
0x14a655000 - 0x14e132f8f +libmkl_core.dylib (0) <18885A1C-38C8-3737-B201-15A9BEE85707> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_core.dylib
0x14eb00000 - 0x14ebe8ff7 +com.adobe.adobe_caps (adobe_caps 11.0.0.14 - 11.0.0.14) <471DBB2B-FEA4-31CF-AC2D-F9C37073B804> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x15cb0e000 - 0x15cb56ff7 +com.adobe.AfterEffects.PNGIO (0) <27D8032D-35D7-3825-AA25-77F2567D3B8F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/PNGIO.plugin/Contents/MacOS/PNGIO
0x15d09d000 - 0x15d105fff +com.adobe.AfterEffects.Advanced3D (0) <715DC996-5FB3-38BF-A335-60F16A7E69ED> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Required/Advanced3D.plugin/Contents/MacOS/Advanced3D
0x15d1ba000 - 0x15d214fff +com.adobe.AfterEffects.TIFF (0) <C7BB14B5-D3E7-3577-9D0D-7A6A758FAC16> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/TIFF.plugin/Contents/MacOS/TIFF
0x15db78000 - 0x15dc6eff7 +com.adobe.AfterEffects.Anywhere2 (0) <DF47357A-27A4-30B4-B39B-1BBF2372C19D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Extensions/Anywhere2.plugin/Contents/MacOS/Anywhere2
0x15de00000 - 0x15f24cff7 +com.imagineersystems.mochashapeconverter4ae (6.0.0 - 6.0.0f23.g37cb12555413) <7B58BAE3-E703-30E9-A153-B25ECC682623> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Effects/mochaAE/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
0x15f464000 - 0x15f681fef +com.adobe.AfterEffects.OpenEXR (???) <415CEBC3-0C65-C2B9-DA34-EF176DF31828> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
0x15f879000 - 0x15fcdbfed +com.adobe.ProImportAE (Pro Import AE version 8.00 - 8.00) <AC4080BD-55B3-9433-7BE1-371B4F0A5629> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/ProImport/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
0x15fe96000 - 0x15fedeff7 +MMXCore (18.1.0 - 18.1.0) <71BD02ED-4F9F-37D8-A544-D619B7D18B43> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x15ff6b000 - 0x15ffe3fff +MultiProcessor Support (18.1.0 - 18.1.0) <0E07BC92-23C7-3AF9-9514-AA673F811E02> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x7fff3e117000 - 0x7fff3e118ff7 libCyrillicConverter.dylib (73) <3C190A58-3420-3F4D-AA20-250F21679096> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x7fff3e11c000 - 0x7fff3e137ff7 libJapaneseConverter.dylib (73) <5F03C58F-72BD-3CCB-833B-15590CD10BDB> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x7fff3e138000 - 0x7fff3e159ffb libKoreanConverter.dylib (73) <CFA3A1BE-55F8-3520-85BB-73B20E32F6EE> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x7fff3e15a000 - 0x7fff3e15bff3 libLatin2Converter.dylib (73) <F977D9D7-9A61-336F-B0AD-8BC0C963711E> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
0x7fff3e162000 - 0x7fff3e171ffb libSimplifiedChineseConverter.dylib (73) <991F3402-E9C7-3BE3-BC60-73326DADB2D5> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x7fff3e175000 - 0x7fff3e187ff3 libTraditionalChineseConverter.dylib (73) <CE960AF9-2041-321E-BC2C-3AD1347A18E2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x7fff3e19d000 - 0x7fff3e4faff7 com.apple.RawCamera.bundle (8.10.0 - 1031) <F311B880-6219-395B-8F79-02504DDA0010> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff3e4fd000 - 0x7fff3e648ff7 com.apple.AMDMTLBronzeDriver (2.0.36 - 2.0.0) <39929A89-44C7-3534-B6A4-AA31B027414A> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff3e649000 - 0x7fff3edc0ff7 ATIRadeonX4000SCLib.dylib (2.0.36) <C19893B6-EE0A-3A4D-BF3F-5B1221942109> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff452a4000 - 0x7fff452a8fff com.apple.agl (3.3.2 - AGL-3.3.2) <81130C05-30AD-3BDA-BB9C-72ADDD5FAA2C> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff452a9000 - 0x7fff45497ff3 com.apple.avfoundation (2.0 - 1540.118.2) <1EE74E35-F16B-3034-AEA5-723198E519F8> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff45498000 - 0x7fff45566ff7 com.apple.audio.AVFAudio (1.0 - ???) <727A6D92-D1F2-3179-80D3-51F1481F5A87> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff45674000 - 0x7fff45674fff com.apple.Accelerate (1.11 - Accelerate 1.11) <2C602CED-72CA-37C2-BDF5-31697FC9100B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff45675000 - 0x7fff4568bfe3 libCGInterfaces.dylib (506.19) <6455899E-BAC7-34D1-802B-FFE19A2337E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff4568c000 - 0x7fff45d2cfe3 com.apple.vImage (8.1 - ???) <65912AFB-D4C1-3494-AE97-DDFDAF3BE1EB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff45d2d000 - 0x7fff45fa4fd7 libBLAS.dylib (1243.200.4) <76710990-AE2B-300E-88BB-797ABAD74956> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff45fa5000 - 0x7fff46017fe7 libBNNS.dylib (38.200.5) <5F3A4021-8FF8-30E8-B84A-AA2BD70F4151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff46018000 - 0x7fff463befff libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff463bf000 - 0x7fff463d4ffb libLinearAlgebra.dylib (1243.200.4) <E923DA33-B142-3A73-A80A-642878D19099> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff463d5000 - 0x7fff463daff3 libQuadrature.dylib (3.200.2) <6FFAC142-415D-3AF0-BC09-336302F11934> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff463db000 - 0x7fff46458ffb libSparse.dylib (79.200.5) <0D7E71A4-10D2-3979-B386-D2426ADAF6D7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff46459000 - 0x7fff4646cffb libSparseBLAS.dylib (1243.200.4) <00D6FC17-B739-3259-90A4-92AC8BBE03D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff4646d000 - 0x7fff46651ff3 libvDSP.dylib (671.201.1) <716585BD-04D7-30A9-B315-689184275E38> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff46652000 - 0x7fff46707ff3 libvMisc.dylib (671.201.1) <EDA66C06-A11F-3EE5-96D5-B20893448899> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff46708000 - 0x7fff46708fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <DADD83A2-550F-3570-8D71-16614C6A4CE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff468b9000 - 0x7fff476d8ff3 com.apple.AppKit (6.9 - 1671) <E1B2CAF1-9231-3B3D-BD9E-B770FE87F407> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff4772a000 - 0x7fff4772afff com.apple.ApplicationServices (50.1 - 50.1) <1B71604B-9AC5-3A2F-8CB7-0EFA34A20F12> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff4772b000 - 0x7fff47796ff7 com.apple.ApplicationServices.ATS (377 - 453.11) <7599E619-EE21-3EB7-875B-AE3B8D3E13BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff47797000 - 0x7fff47798ff7 ATSHI.dylib (453.11) <78D93611-C22F-39E6-AD4A-E0ABF620EE04> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x7fff4782f000 - 0x7fff4794efff libFontParser.dylib (228.6) <E800074F-62CF-340A-A5A7-B8BE5B560045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff4794f000 - 0x7fff4799afff libFontRegistry.dylib (228.12) <480D472D-C8FB-321D-86EC-2EA6927A97AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff479f9000 - 0x7fff47a2cff7 libTrueTypeScaler.dylib (228.6) <D23BFDE4-8664-335A-B43B-A13A8EF29E40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff47a96000 - 0x7fff47a9aff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <90641B6B-D07B-3577-B594-965825544B60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff47b37000 - 0x7fff47b89ff3 com.apple.HIServices (1.22 - 627.14.2) <01F309D6-32E7-3C4F-A38B-8206EE3076CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff47b8a000 - 0x7fff47b98ff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <67BC5855-B7A3-39E6-B5DD-52B287EB1532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff47b99000 - 0x7fff47be5fff com.apple.print.framework.PrintCore (14.0 - 503.7) <C13BC56A-65F4-35B1-9E33-51FE6F3B06FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff47be6000 - 0x7fff47c21ff7 com.apple.QD (3.12 - 407.2) <94A30038-C545-327A-B1C0-E19C79D62BAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff47c22000 - 0x7fff47c2eff7 com.apple.speech.synthesis.framework (8.0.15 - 8.0.15) <A96C744B-B1AD-32E3-BA72-7A221684BE3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff47c2f000 - 0x7fff47ecbff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <89D2529D-CF36-3081-A700-70892F888718> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff47ecd000 - 0x7fff47ecdfff com.apple.audio.units.AudioUnit (1.14 - 1.14) <8B9A5ADB-E62C-3838-BB5E-AF20CAE449CC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff47ece000 - 0x7fff4800eff3 com.apple.AudioVideoBridging (700.6 - 700.6) <B2BBFF05-AE27-36D2-8587-93C0DCB96C18> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x7fff48231000 - 0x7fff485f2ff7 com.apple.CFNetwork (974.1 - 974.1) <ACC604FA-5D40-34CE-9206-8091010306B7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff48607000 - 0x7fff48607fff com.apple.Carbon (158 - 158) <DAF95685-B793-34EB-96EA-3E292A9E3378> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff48608000 - 0x7fff4860bffb com.apple.CommonPanels (1.2.6 - 98) <F1E1C47B-FD1A-30A4-B41B-87BD8B178B56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff4860c000 - 0x7fff48913ff7 com.apple.HIToolbox (2.1.1 - 916.32) <B2ED8B1C-FC3E-3FA0-8F6D-E7A448E6FAA7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff48914000 - 0x7fff48917ffb com.apple.help (1.3.8 - 66) <4392A63F-9B58-3248-BF73-B46AD3744E6E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff48918000 - 0x7fff4891dff7 com.apple.ImageCapture (9.0 - 1529.7) <364EDC6B-6374-31A7-A637-0044B73F8DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff4891e000 - 0x7fff489b2ff3 com.apple.ink.framework (10.9 - 225) <D6503F37-7EBC-32C1-95CC-A35EFC54E7ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff489b3000 - 0x7fff489cdfff com.apple.openscripting (1.7 - 178) <D4A4D130-9C7B-3656-9D58-50F9D09C276E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff489ee000 - 0x7fff489effff com.apple.print.framework.Print (14.0 - 267.3) <5CD250DF-98AD-30B8-A5D5-47634FF9E74D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff489f0000 - 0x7fff489f2ff7 com.apple.securityhi (9.0 - 55006) <C5308CBC-6736-31A7-905B-C635C6D43FDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff489f3000 - 0x7fff489f9ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C38B9CB-DD45-3A7B-9D4C-631855A4EE32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff48b20000 - 0x7fff48b20fff com.apple.Cocoa (6.11 - 23) <A520D2A3-032B-3C06-81E1-EFDD97C47ACE> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff48b2e000 - 0x7fff48bfafff com.apple.ColorSync (4.13.0 - 3340) <0618DA46-5A5E-339D-BB2F-ED66A2BFCCF9> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff48d95000 - 0x7fff48e25fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <5845D43B-BBB5-343B-A164-6F9E2C53CFA3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff48e27000 - 0x7fff48e8aff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <2156EBFF-88B6-38C5-A16E-F12ACE8DFB25> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x7fff48e8b000 - 0x7fff48eb6ff7 com.apple.CoreBluetooth (1.0 - 1) <D2F48E3D-79FC-32D7-B281-658EAD2CC50B> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff48eb7000 - 0x7fff49257feb com.apple.CoreData (120 - 865.2) <90A5058F-A5AF-311A-81CC-B20C2AC9E85E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff49258000 - 0x7fff49341fff com.apple.CoreDisplay (101.3 - 101.17.6) <4AE5C221-B8E1-3A4F-91E0-96ED5926E82B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff49342000 - 0x7fff49791fff com.apple.CoreFoundation (6.9 - 1555.10) <4A4C87BC-4C8E-392A-ABEE-824D4074C485> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff49793000 - 0x7fff49e20fff com.apple.CoreGraphics (2.0 - 1245.8.4.8) <FFFFEAF0-14DD-38A3-BD68-AA9AB2C672C1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff49e22000 - 0x7fff4a147ff7 com.apple.CoreImage (14.0.0 - 700.2.220) <E9E7B27C-C4FD-3AD6-923E-DF7EAE36D1FF> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4a1ca000 - 0x7fff4a226ff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <32CA3EA2-E1A4-34AC-97A6-5E71C2B10E6C> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff4a499000 - 0x7fff4a59aff3 com.apple.CoreMedia (1.0 - 2280.133.4) <5E733D6B-B683-3931-9D02-82300A43378D> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4a59b000 - 0x7fff4a5fdfff com.apple.CoreMediaIO (900.0 - 5025) <BFB3978A-FDBB-352B-A96D-E8761FC51370> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff4a5fe000 - 0x7fff4a5fefff com.apple.CoreServices (933 - 933) <B79C910E-93B9-3686-8E72-E0B63083AAE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4a5ff000 - 0x7fff4a67dffb com.apple.AE (768 - 768) <E795749D-CE50-3B8C-91A7-8C2618887288> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff4a67e000 - 0x7fff4a956ff7 com.apple.CoreServices.CarbonCore (1178.11 - 1178.11) <9FBE7BFB-3A81-37AC-8E15-E6F7932BBDC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff4a957000 - 0x7fff4a9a1ff7 com.apple.DictionaryServices (1.2 - 284.16.3) <D9388630-E7F2-321E-81FF-EBD5F3B47A52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff4a9a2000 - 0x7fff4a9aaffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <E40A3C4A-79C7-37D8-999B-D1169A06870B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff4a9ab000 - 0x7fff4ab76ff7 com.apple.LaunchServices (933 - 933) <4614A4B4-C358-3460-9FA7-DF8D6C466806> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff4ab77000 - 0x7fff4ac19ffb com.apple.Metadata (10.7.0 - 1191.51) <6B9CCA98-6F68-3908-A7A9-96D3E2AE5968> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff4ac1a000 - 0x7fff4ac65ff7 com.apple.CoreServices.OSServices (933 - 933) <A92C846F-872D-3534-B60E-6CD445A9BAEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff4ac66000 - 0x7fff4acd4ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C6A34D09-9707-3F28-838F-63B59B8A12D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff4acd5000 - 0x7fff4acf9ffb com.apple.coreservices.SharedFileList (71.27 - 71.27) <B46A15E0-4C10-3616-BE49-58E07EC463FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff4b03c000 - 0x7fff4b1a1fff com.apple.CoreText (352.0 - 584.24) <5B55B533-F4DE-32CE-8739-16FFFA1A64F8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff4b1a2000 - 0x7fff4b1dffff com.apple.CoreVideo (1.8 - 0.0) <C7BB7D0F-3AF2-3046-A387-A802BCA52A3A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff4b1e0000 - 0x7fff4b276ffb com.apple.framework.CoreWLAN (13.0 - 1370.8) <19E41424-B956-34DF-AE02-9822308FA3DC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4b412000 - 0x7fff4b4ccff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <55E40DE0-500B-3AC4-81BA-4A54BC04740C> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff4b4f3000 - 0x7fff4b4f8fff com.apple.DiskArbitration (2.7 - 2.7) <C53C1905-9BCF-3AE8-8BB3-C8A2C7DB7D25> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff4b6c1000 - 0x7fff4ba8ffff com.apple.Foundation (6.9 - 1555.10) <0CCAF9AF-F7AF-3174-98D4-6C188B1079CC> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff4bb00000 - 0x7fff4bb30ff3 com.apple.GSS (4.0 - 2.0) <74ACB1A1-A5A4-3180-AC00-688C94AA4434> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff4bc49000 - 0x7fff4bd52ff3 com.apple.Bluetooth (6.0.8 - 6.0.8f6) <6CB8A08E-1154-3333-83CC-2A939AC94562> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff4bdb4000 - 0x7fff4be45fff com.apple.framework.IOKit (2.0.2 - 1483.201.1) <DA4ED91F-2CC9-3CFD-9200-9D5D31EEE4F3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff4be47000 - 0x7fff4be51ff7 com.apple.IOSurface (255.1 - 255.1) <538F0257-A408-36AF-AB1E-1D7037D6359E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff4bea8000 - 0x7fff4c03cff7 com.apple.ImageIO.framework (3.3.0 - 1796.5.4.1) <9D078F50-BB75-3D04-8636-3FDDAB9C95DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff4c03d000 - 0x7fff4c041ffb libGIF.dylib (1796.5.4.1) <93AD6FB9-03BA-350E-AF98-D371A2BFD58F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff4c042000 - 0x7fff4c127fef libJP2.dylib (1796.5.4.1) <3780EB9B-5219-385D-9472-17B0397697A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff4c128000 - 0x7fff4c14dff7 libJPEG.dylib (1796.5.4.1) <83CA8BEB-34BD-3B58-A704-C6A875984FAD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff4c420000 - 0x7fff4c446fe7 libPng.dylib (1796.5.4.1) <9F30FA63-8AB2-3646-A6A8-FCE9F8436C35> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff4c447000 - 0x7fff4c449ff7 libRadiance.dylib (1796.5.4.1) <2C07887C-0584-3538-A9EC-3988AA5B234B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff4c44a000 - 0x7fff4c498fff libTIFF.dylib (1796.5.4.1) <F420B0DC-D0F7-3DD5-9E17-00462441635C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff4c794000 - 0x7fff4d516ff7 com.apple.JavaScriptCore (14606 - 14606.1.36.1.9) <7FF80E53-3D6B-33BF-9538-A263513475EC> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4d52e000 - 0x7fff4d547fff com.apple.Kerberos (3.0 - 1) <8BE3D524-257D-3663-A937-F1AC76BDF4D9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff4d548000 - 0x7fff4d57dffb com.apple.LDAPFramework (2.4.28 - 194.5) <DC361FB9-4B59-311E-8CC5-07FF9A9C673F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff4d804000 - 0x7fff4d80efff com.apple.MediaAccessibility (1.0 - 114.4) <29D89F2B-6254-3D0D-BD0C-8472FCA373F4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff4d8c8000 - 0x7fff4df64ff7 com.apple.MediaToolbox (1.0 - 2280.133.4) <FB1C3DD9-A91B-3952-A892-9F009B854F8F> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff4df66000 - 0x7fff4dff9fff com.apple.Metal (157.55 - 157.55) <49CD402F-20CB-3930-B997-BBDC495ABF64> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4dffb000 - 0x7fff4e015ff3 com.apple.MetalKit (1.0 - 113) <8949A0FA-337E-3C28-94D1-35853D69761B> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff4e016000 - 0x7fff4e036ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <9A841A76-43BC-3220-A4DA-99137C42A0BC> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff4e037000 - 0x7fff4e0b4fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <C469D1E5-F621-3E56-87AC-1BD889664FA3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff4e0b5000 - 0x7fff4e0ddfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <8C57A3A2-8EBB-3401-87FC-368D1BE6DAAC> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff4e0de000 - 0x7fff4e205ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <CE3201A3-4ACE-3E79-990B-8987C576B31B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff4e206000 - 0x7fff4e221ff7 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <8F02CFCA-41E1-3194-915F-3106E8B48B32> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff4e222000 - 0x7fff4e222ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <8B715D78-8357-38F4-A03C-926EE967CE71> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4f421000 - 0x7fff4f42dffb com.apple.NetFS (6.0 - 4.0) <529E29A9-5E77-3A8C-A982-CF55F949FE5D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff51ee4000 - 0x7fff51eecfe7 libcldcpuengine.dylib (2.9.6) <48AB98D8-1098-3B1D-8AFD-17B40F7A2F5D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff51eed000 - 0x7fff51f46ff7 com.apple.opencl (2.12.1 - 2.12.1) <3EAE5BC8-E948-3926-9319-9DAC2A8B5484> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff51f47000 - 0x7fff51f63ff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) <7E4EFF02-2596-31E6-88DE-29C89E2837E4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff51f64000 - 0x7fff51f70ffb com.apple.OpenDirectory (10.14 - 207.200.4) <52A3918E-0F7A-33FD-87EE-21A37B37D13B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff528d3000 - 0x7fff528d5fff libCVMSPluginSupport.dylib (17.0.37) <38A18A32-BBF2-3A0F-AE37-51734B6CA91A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff528d6000 - 0x7fff528dbff3 libCoreFSCache.dylib (163.20) <BF8F04DD-C1A1-3D2A-BF3F-639FE907E28D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff528dc000 - 0x7fff528e0fff libCoreVMClient.dylib (163.20) <45A2C724-F3D1-316A-9A41-CAB8E2A390EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff528e1000 - 0x7fff528e9ffb libGFXShared.dylib (17.0.37) <267B40DF-2939-3D76-89FA-E8DBDEE96D92> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff528ea000 - 0x7fff528f5fff libGL.dylib (17.0.37) <2E25A83B-B560-34A1-B474-3027C8B75BA4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff528f6000 - 0x7fff52930fef libGLImage.dylib (17.0.37) <49C5F799-66E5-3A81-AF88-948DD0E583FA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff52931000 - 0x7fff52aa3ff3 libGLProgrammability.dylib (17.0.37) <8A5E29FF-04DA-33D4-9F5F-B896CC967386> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff52aa4000 - 0x7fff52ae1fff libGLU.dylib (17.0.37) <79555E42-B816-3106-8FA0-FC14A54AE8B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff53491000 - 0x7fff534a0ff3 com.apple.opengl (17.0.37 - 17.0.37) <FA76EAA6-D035-3444-87F5-DD95446D651D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff534a1000 - 0x7fff53637ff7 GLEngine (17.0.37) <0A43977A-AA0D-3B05-AC7E-C7A8BFB3B449> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff53638000 - 0x7fff53660ff7 GLRendererFloat (17.0.37) <F7461A91-0F80-336E-9CC5-9A777A454D28> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff542fc000 - 0x7fff54552fff com.apple.QuartzCore (1.11 - 693.16.4.2) <2C9E3279-3F97-3440-B937-E5FE888232E2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff54553000 - 0x7fff545acff7 com.apple.QuickLookFramework (5.0 - 775) <A4CA709A-2828-3F04-8786-7FAC8A95B98B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff54d87000 - 0x7fff54d9ffff com.apple.ScriptingBridge (1.4 - 77) <3502C869-965C-3D65-AC25-D18636CBA127> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff54da0000 - 0x7fff550c6fff com.apple.security (7.0 - 58286.200.222) <AEB638D9-BFE9-319E-A70B-557ACF41117A> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff550c7000 - 0x7fff55156fff com.apple.securityfoundation (6.0 - 55185.200.14) <770D67D1-3DA6-3FD3-8531-376712BA4F60> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff55188000 - 0x7fff5518cff3 com.apple.xpc.ServiceManagement (1.0 - 1) <20DB899D-3BAF-36FD-86A6-F66A82074607> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff55549000 - 0x7fff555b9ff3 com.apple.SystemConfiguration (1.17 - 1.17) <EED5BC9B-CE8D-343C-BCDC-04A79F704828> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff5581a000 - 0x7fff55b7cff7 com.apple.VideoToolbox (1.0 - 2280.133.4) <468A9F6D-33AB-31D3-A8A3-A6A432033C9E> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff55e8a000 - 0x7fff56418ff7 libwebrtc.dylib (7606.1.36.1.9) <9D8EADA7-921A-377C-8B0F-5A1D42AC43A7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff56419000 - 0x7fff57c99ff7 com.apple.WebCore (14606 - 14606.1.36.1.9) <099B8FA5-D49D-3C7E-B40A-613CA6E7B769> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff57c9a000 - 0x7fff57e89ffb com.apple.WebKitLegacy (14606 - 14606.1.36.1.9) <60C1D461-49C9-3B8B-9BD4-B95F1D18335F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff57e8a000 - 0x7fff58387fff com.apple.WebKit (14606 - 14606.1.36.1.9) <5E4AF277-D207-3647-9D5C-A6F1543A2D4D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff5881e000 - 0x7fff588c3ff7 com.apple.APFS (1.0 - 1) <CBE5EE83-7A5F-3C10-93FF-F6DA84DFB875> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff58e4c000 - 0x7fff58e52ff3 com.apple.accessibility.AXCoreUtilities (1.0 - 1) <A10AB2DC-7C65-3FC0-8416-246003D158A6> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff592ff000 - 0x7fff59300ff3 com.apple.AggregateDictionary (1.0 - 1) <1DEBBE36-8945-3AD8-BD48-2850AD845711> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff598fb000 - 0x7fff59927ff7 com.apple.framework.Apple80211 (13.0 - 1375.14) <79EBF155-EAB2-37EE-BF8C-57BC453217B1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff59c03000 - 0x7fff59c12fcf com.apple.AppleFSCompression (96.200.3 - 1.0) <E093776E-C367-3CCF-BFD5-623476A89E9A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff59d10000 - 0x7fff59d1bfff com.apple.AppleIDAuthSupport (1.0 - 1) <5362D9AD-A2AE-3436-97CE-C353124504E5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff59d5c000 - 0x7fff59da5ff3 com.apple.AppleJPEG (1.0 - 1) <9A690E6E-F987-3660-BED6-B1A4D1906B6C> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff59ff0000 - 0x7fff59ff4ff7 com.apple.AppleSRP (5.0 - 1) <B8E2BEC9-FAFB-3E26-BF26-E2E58C545006> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff59ff5000 - 0x7fff5a01dff7 com.apple.applesauce (1.0 - ???) <60BB16D6-DE7E-356A-B9DE-F73EE179934A> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff5a0e8000 - 0x7fff5a138fff com.apple.AppleVAFramework (5.0.44 - 5.0.44) <F7B8CD3A-8671-3B2C-B67C-CE39C1442207> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff5a183000 - 0x7fff5a199ffb com.apple.AssertionServices (1.0 - 1) <8FB0D908-6C46-3399-92D6-4E7D4B5F4F19> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff5a3a6000 - 0x7fff5a3beff3 com.apple.AudioServerApplication (1.0 - 400.4) <3CEB592E-6FA6-37DA-9726-531F9E2F22E1> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x7fff5a4c9000 - 0x7fff5a76cffb com.apple.AuthKit (1.0 - 1) <ED375339-69F6-34AE-825D-F16BF0618E3E> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff5a93d000 - 0x7fff5a946ff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <972F41B3-7DF7-3BF1-ACCA-A093A4328ADF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff5a947000 - 0x7fff5a9e9ff7 com.apple.backup.framework (1.10 - ???) <46534B04-DD0E-357B-9CB5-F88AAC6AF4ED> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5a9ea000 - 0x7fff5aa5bffb com.apple.BaseBoard (360.18.4 - 360.18.4) <709EF03C-5BCE-3F47-BD58-A48C1F9378A5> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff5aae4000 - 0x7fff5ab20ffb com.apple.bom (14.0 - 197) <8BD14107-DB70-3800-9377-618CA230B40A> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff5b8fd000 - 0x7fff5b94afff com.apple.ChunkingLibrary (194 - 194) <13F1F769-E8E7-372A-8F0B-2BB4B7753248> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff5b9f2000 - 0x7fff5ba81ffb com.apple.CloudDocs (1.0 - 575.120) <94232936-1B40-3EAF-B731-883A4872BCE4> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff5c60a000 - 0x7fff5c613fff com.apple.CommonAuth (4.0 - 2.0) <7105F266-35C3-3582-9383-A2A9D7184A7B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff5cac3000 - 0x7fff5ce9afef com.apple.CoreAUC (273.0.0 - 273.0.0) <288EC7ED-A86A-30D0-ADE2-56C33CD93AA8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff5ce9b000 - 0x7fff5ceccfff com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <507AC58B-4527-353B-99CB-67FF183BD4D5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5cee9000 - 0x7fff5cf0bfff com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <698E1B63-B193-3431-A1C7-9B8D2D62088C> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff5d0f9000 - 0x7fff5d102fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8D971ACD-6A26-30A9-9C5B-BCBF60A661F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff5d310000 - 0x7fff5d323fff com.apple.CoreEmoji (1.0 - 69.15.9) <011E7853-BDD6-3197-BA8D-D6B977EF56EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff5d8f9000 - 0x7fff5d96bff7 com.apple.CoreNLP (1.0 - 130.15.22) <401F5284-A984-32A1-A547-CC8156381070> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff5daee000 - 0x7fff5daf2ff7 com.apple.CoreOptimization (1.0 - 1) <AEF88F43-C928-3DCB-95D6-C6706B565422> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff5dc26000 - 0x7fff5dc2effb com.apple.CorePhoneNumbers (1.0 - 1) <F47CA56F-6760-3282-BFD8-C8C8D2C33ECF> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff5dc2f000 - 0x7fff5dc8bfff com.apple.CorePrediction (1.0 - 1) <BD34AB8C-8899-3BB1-95A2-0A2A1C901ADC> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5ddbd000 - 0x7fff5ddeefff com.apple.CoreServicesInternal (357 - 357) <2D012EB3-83BF-3E51-A2BE-41AF26F2DDF0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff5e1b3000 - 0x7fff5e241ff7 com.apple.CoreSymbolication (10.0 - 64235.3.1) <912C63C0-473B-3352-A255-60F7CA3FE3F2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff5e2d1000 - 0x7fff5e3fdfff com.apple.coreui (2.1 - 498.46) <05F9736C-5A62-33B3-9607-551A332AEF28> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff5e3fe000 - 0x7fff5e57dffb com.apple.CoreUtils (5.7 - 570.70) <2554BA12-16A2-399F-A13A-E5C8EB4FC1EC> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff5e5d4000 - 0x7fff5e637ffb com.apple.framework.CoreWiFi (13.0 - 1370.8) <5C6ACF32-14D3-35FD-8A4A-629521090F41> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff5e638000 - 0x7fff5e649ffb com.apple.CrashReporterSupport (10.13 - 938.23) <36754BB2-680F-36AE-A5DE-548B4F41F0AE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5e6cc000 - 0x7fff5e6dbff3 com.apple.framework.DFRFoundation (1.0 - 210) <61EF0583-E946-3201-932D-7D117BC62CB2> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff5e6dc000 - 0x7fff5e6e0ff7 com.apple.DSExternalDisplay (3.1 - 380) <B6B26BB3-2DC9-34D0-817E-EB612432EC96> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff5e763000 - 0x7fff5e7daffb com.apple.datadetectorscore (7.0 - 590.24) <2D4CFF51-BCD4-3D08-AE73-AB2B8BEC8659> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff5e828000 - 0x7fff5e869fff com.apple.DebugSymbols (185 - 185) <01F561DA-4724-32FD-B2C7-6436F4CEB980> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff5e86a000 - 0x7fff5e9c3ff7 com.apple.desktopservices (1.13 - ???) <053D3A96-9263-3242-8625-101DDB9350DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5eaf5000 - 0x7fff5ebc7ff7 com.apple.DiskImagesFramework (480.201.1 - 480.201.1) <54D2F7DC-DAA6-3667-9590-1407C7B738EC> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff5ebc8000 - 0x7fff5ec8cfff com.apple.DiskManagement (12.0 - 1530) <F844A618-613A-3609-9C31-621D92FB75DD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff5ed32000 - 0x7fff5ed35fff com.apple.EFILogin (2.0 - 2) <8FCA68D2-CEA5-39F6-B222-AC31FCF79D1D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff5fa07000 - 0x7fff5fe2ffff com.apple.vision.FaceCore (3.3.4 - 3.3.4) <CCBC466A-1AD4-3B0B-80B2-D6CFCBB37FC0> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff5fe62000 - 0x7fff5feeeff7 com.apple.FileProvider (125.129 - 125.129) <31642A56-F183-3DA3-8713-745358CAE55D> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff63751000 - 0x7fff63752fff libmetal_timestamp.dylib (902.1.49) <F0C95234-16BA-3F0B-A11E-087ABDC8DD6C> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff64deb000 - 0x7fff64df6ff7 libGPUSupportMercury.dylib (17.0.37) <E8A195F4-E2E4-3EB5-AF21-856EBA145436> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff64df7000 - 0x7fff64dfcff7 com.apple.GPUWrangler (3.22.9 - 3.22.9) <A7FF28DC-3576-3E53-AFAF-0E29CB45E9AE> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff651ac000 - 0x7fff651d1ff7 com.apple.GenerationalStorage (2.0 - 285.101) <089301DF-60C9-3BED-9357-2F91336C1579> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff65c5b000 - 0x7fff65c6afff com.apple.GraphVisualizer (1.0 - 5) <C7040CD7-6CAB-3878-B29E-21F1665341D0> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff65c6b000 - 0x7fff65c78fff com.apple.GraphicsServices (1.0 - 1.0) <F099E6ED-E08D-3F37-B381-0DF3109B27AA> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff65d51000 - 0x7fff65dc5fff com.apple.Heimdal (4.0 - 2.0) <793E1D31-6166-37F2-A989-F98FE1706E5D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff65dc6000 - 0x7fff65df5fff com.apple.HelpData (2.3 - 184) <56A7277E-B1C3-3AD8-AF4B-8BAA41D6E640> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff67197000 - 0x7fff671a0fff com.apple.IOAccelMemoryInfo (1.0 - 1) <A2E867B2-615D-393C-A2C7-D2B83B56756D> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff671a1000 - 0x7fff671a8ffb com.apple.IOAccelerator (400.24 - 400.24) <01551ED8-6AE1-307D-A3F0-DCA85FAA5210> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff671ac000 - 0x7fff671c5ff7 com.apple.IOPresentment (1.0 - 37) <751130A1-8639-3BDA-BF8F-A3BE54427E43> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff675d8000 - 0x7fff67607ff7 com.apple.IconServices (379 - 379) <BE9E71B4-C00E-317D-9093-6E637C905A09> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff67732000 - 0x7fff67736fff com.apple.InternationalSupport (1.0 - 10.15.6) <F0E300AD-1E67-3D57-B179-C2212F7CD00C> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff678a6000 - 0x7fff678b9fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <10A17A9D-564E-3841-A433-D6D7401ED733> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff678d4000 - 0x7fff679cbfff com.apple.LanguageModeling (1.0 - 159.15.15) <E524CC46-42C7-3046-AD6C-5D5D768EA478> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff679cc000 - 0x7fff67a0dff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <90C1CFE1-9935-3F4F-8A9B-1DD697F2FF3D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff67a14000 - 0x7fff67a1aff7 com.apple.LinguisticData (1.0 - 238.15.29) <D27B30BA-3F5D-3AF2-895C-3B64569EEA1B> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff68277000 - 0x7fff6827afff com.apple.Mangrove (1.0 - 25) <8744DBF9-3375-392C-8EE6-24373E0D19E8> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff68398000 - 0x7fff683cbff3 com.apple.MediaKit (16 - 906) <15D4EDA2-AAAC-3CF3-BB2B-3A92AECC932D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff68774000 - 0x7fff6879cffb com.apple.spotlight.metadata.utilities (1.0 - 1191.51) <7CD28A81-F0D6-3575-8F83-3D45D53F72BB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff6879d000 - 0x7fff6882ffff com.apple.gpusw.MetalTools (1.0 - 1) <60BE7793-D8DE-3DF1-94D7-503301EC1E72> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff68844000 - 0x7fff6885dfff com.apple.MobileAssets (1.0 - 437.200.49) <0C9B7077-BFCF-3A2E-8F54-D7C2820893FD> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff6886f000 - 0x7fff689d8fc7 com.apple.mobiledevice (988.200.73.100.1 - 988.200.73.100.1) <EB2F212B-FDEB-30D8-9678-0F2DE2E2EBA6> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fff689d9000 - 0x7fff689f4fff com.apple.MobileKeyBag (2.0 - 1.0) <E9F2FF73-22D0-35B5-BD2C-9DD8FDB12BCC> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff68a82000 - 0x7fff68aacff7 com.apple.MultitouchSupport.framework (2400.15 - 2400.15) <A2BB198C-0B1A-3988-8611-9A9BCCE650B5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff68d1e000 - 0x7fff68d28fff com.apple.NetAuth (6.2 - 6.2) <55DC741A-A01A-380C-B2D3-244241DA1F2C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff695f3000 - 0x7fff69649fff com.apple.OTSVG (1.0 - ???) <A0E0FC0B-B48F-3639-9C50-BAECC72988D5> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6a7ac000 - 0x7fff6a7bbff3 com.apple.PerformanceAnalysis (1.217 - 217) <8560F263-31F4-3CCA-84B1-30C296DC1A7D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff6c323000 - 0x7fff6c335ff3 com.apple.PowerLog (1.0 - 1) <F921C10F-11EC-3D68-91FD-CA836F1B26CE> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff6c71c000 - 0x7fff6c773fff com.apple.ProtectedCloudStorage (1.0 - 1) <737DEC8B-342E-3BB2-AF69-D4428D467E4E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff6c774000 - 0x7fff6c792ff7 com.apple.ProtocolBuffer (1 - 263) <C5AC21FB-74AD-3FC2-B231-B1376751BBAE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff6c92a000 - 0x7fff6c940ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <AAF7A93C-5553-3476-B2F2-B8B1DA2BEF54> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff6c941000 - 0x7fff6c999f0f com.apple.ROCKit (24 - 24) <5437F6F7-453F-3D75-9E87-D2A090D82D25> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff6ca5a000 - 0x7fff6ca66ff3 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.201.2) <FB030135-1633-378F-A7A6-B1A81AD068A2> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff6ca79000 - 0x7fff6ca9cffb com.apple.RemoteViewServices (2.0 - 128) <68530B4D-B2C0-3271-941B-D9EA62095727> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff6ca9d000 - 0x7fff6cab1fff com.apple.xpc.RemoteXPC (1.0 - 1336.201.2) <1E00A78B-1934-39A0-8F35-48CBEB93D04C> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff6d908000 - 0x7fff6d952ff7 com.apple.Safari.SafeBrowsing (606 - 606.1.36.1.9) <5ABFF535-18D9-395C-877F-66013774824D> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff6e40a000 - 0x7fff6e529fff com.apple.Sharing (1176.11 - 1176.11) <9881AEAD-5410-33F7-A852-770C7FE677C9> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6e52a000 - 0x7fff6e549ff3 com.apple.shortcut (2.16 - 101) <D724B49E-C972-31CC-B47C-8CB769A3E0B0> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff6f2db000 - 0x7fff6f58bff7 com.apple.SkyLight (1.600.0 - 336.80.6) <5F7D2312-0003-354C-82BC-DC346B1A98E6> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6fd5a000 - 0x7fff6fd67fff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <816EC315-3E76-37B7-A495-B4AE031DA439> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6fe24000 - 0x7fff7008cffb com.apple.spotlight.index (10.7.0 - 1191.51) <583CD37E-9C0E-3842-B2C8-B809F0A6DD6D> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff7044c000 - 0x7fff7048bff3 com.apple.StreamingZip (1.0 - 1) <3F13DFEE-A6C9-3815-9120-B5CA6987662E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff70bc8000 - 0x7fff70c55ff7 com.apple.Symbolication (10.0 - 64254.5) <7D5FB79E-1121-3DB0-9CBE-C023835ACE60> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff70c56000 - 0x7fff70c5fffb com.apple.SymptomDiagnosticReporter (1.0 - 820.207.88) <0D7B57B7-8563-3B6D-9084-AA5A1340CAA8> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff7115e000 - 0x7fff7116bff3 com.apple.TCC (1.0 - 1) <55C045F7-D8AB-3BE6-970B-9457FA78E7E3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff713da000 - 0x7fff714a1ff7 com.apple.TextureIO (3.8.4 - 3.8.1) <F9D5F55D-9A33-326E-8B2F-B533CC91DD64> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff714ce000 - 0x7fff714feff3 com.apple.TimeSync (1.0 - 700.7) <B2D2B1D8-0AF2-398C-80A3-0EC2ABB3773B> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x7fff7155b000 - 0x7fff7155cfff com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <BD0BE410-E172-3585-82B2-869A1FE43092> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff71562000 - 0x7fff7171cfff com.apple.UIFoundation (1.0 - 550.35) <1CAAA3AC-1477-3E24-B55C-07A704D7CA03> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff7176b000 - 0x7fff71771fff com.apple.URLFormatting (59 - 59.34) <D104A904-5B18-368E-8290-35212094D9F5> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff7240a000 - 0x7fff724f3fff com.apple.ViewBridge (400.1 - 400.1) <0BCCA232-710B-3F84-8341-A30F77B3A4E9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff72973000 - 0x7fff72bdfffb libAWDSupportFramework.dylib (865) <054B6F72-B75B-3AFC-9E9C-9929C9634200> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff72be0000 - 0x7fff72bf1fff libprotobuf-lite.dylib (865) <B69A744C-4920-3587-A987-A0D349437F4B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff72bf2000 - 0x7fff72c54ff7 libprotobuf.dylib (865) <7867D62B-1FDC-3F06-B234-4B6CE5D10602> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff72c55000 - 0x7fff72c9bfff com.apple.awd (1.0 - 930.11) <534B230C-8453-3F01-B6B8-4C1226D3F1E8> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff72d0e000 - 0x7fff72d11fff com.apple.dt.XCTTargetBootstrap (1.0 - 1) <63A533F6-988D-3FED-A1C7-20BC725A0D4B> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff72d19000 - 0x7fff72d79ff7 com.apple.xquery (1.3.1 - 30) <DB666CD4-4C35-316A-8D7A-CF8CD6CEF36F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff73142000 - 0x7fff73144ff3 com.apple.loginsupport (1.0 - 1) <5F1E000D-0674-3413-AB3E-83F7974666FB> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff73145000 - 0x7fff7315afff com.apple.login (3.0 - 3.0) <474C5E41-1326-3E78-A154-218D618D6BD4> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff7336a000 - 0x7fff7337dffb libAccessibility.dylib (2402.6.10.3) <3044BCB8-1470-3054-9FB6-3D88AA57115B> /usr/lib/libAccessibility.dylib
0x7fff733fe000 - 0x7fff73436fff libCRFSuite.dylib (41.15.4) <62EDD39F-6D1B-334B-A9A2-5800714255BB> /usr/lib/libCRFSuite.dylib
0x7fff73439000 - 0x7fff73444ff7 libChineseTokenizer.dylib (28.15.3) <8CD1C213-7F62-3F02-BFB1-D0A5EFF92AB0> /usr/lib/libChineseTokenizer.dylib
0x7fff73445000 - 0x7fff734d1ff7 libCoreStorage.dylib (546.50.1) <F56AD958-416C-38EA-9829-DEAAB1F0C155> /usr/lib/libCoreStorage.dylib
0x7fff734d5000 - 0x7fff734d6ff7 libDiagnosticMessagesClient.dylib (107) <C542CB3C-AA44-3D7F-B88C-79CC31B481AB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff7350d000 - 0x7fff736d0ff7 libFosl_dynamic.dylib (18.3.2) <6EF1CB2A-2BDA-3458-B631-F794D72660FD> /usr/lib/libFosl_dynamic.dylib
0x7fff73726000 - 0x7fff73745ffb libMobileGestalt.dylib (645.200.76) <A2C32318-0E35-3963-B9B7-E1E92AD33BA6> /usr/lib/libMobileGestalt.dylib
0x7fff73746000 - 0x7fff73746fff libOpenScriptingUtil.dylib (178) <2EEBF84D-9E00-3570-AC0C-C49C8D25A8BF> /usr/lib/libOpenScriptingUtil.dylib
0x7fff73887000 - 0x7fff73888ffb libSystem.B.dylib (1252.200.5) <D5133811-9D66-3DEB-9521-0A67347C9A54> /usr/lib/libSystem.B.dylib
0x7fff73889000 - 0x7fff73911ff7 libTelephonyUtilDynamic.dylib (3608) <05694AE8-9065-36CD-A03B-15D23D09414E> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff73912000 - 0x7fff73913fff libThaiTokenizer.dylib (2.15.1) <A8235B04-F541-3856-BE2E-B58EE0483AD9> /usr/lib/libThaiTokenizer.dylib
0x7fff73926000 - 0x7fff7393cffb libapple_nghttp2.dylib (1.24.1) <B8D45114-3868-3154-BC35-22597E3E7D8A> /usr/lib/libapple_nghttp2.dylib
0x7fff7393d000 - 0x7fff73966ffb libarchive.2.dylib (54.200.3) <B47C54A0-3A30-374A-BD99-2304B9B0EC82> /usr/lib/libarchive.2.dylib
0x7fff73967000 - 0x7fff739e6fef libate.dylib (1.13.8) <C647A80F-6F80-3FDA-A9B4-92800999F963> /usr/lib/libate.dylib
0x7fff739ea000 - 0x7fff739eaff3 libauto.dylib (187) <01824E49-F2EF-3FC1-ABF3-782EFDF6CA17> /usr/lib/libauto.dylib
0x7fff739eb000 - 0x7fff73ac1ff7 libboringssl.dylib (109.201.1) <EE1460C1-EA18-3BC8-BC43-BC916E09C790> /usr/lib/libboringssl.dylib
0x7fff73ac2000 - 0x7fff73ad2ff3 libbsm.0.dylib (39.200.18) <5E5098D0-F7B2-32A1-8038-E709F6718D4E> /usr/lib/libbsm.0.dylib
0x7fff73ad3000 - 0x7fff73ae1fff libbz2.1.0.dylib (38.200.3) <4EE3C5E8-BEF3-3910-A231-B1AE2B437E01> /usr/lib/libbz2.1.0.dylib
0x7fff73ae2000 - 0x7fff73b39ff7 libc++.1.dylib (400.9.4) <D4AB366F-48A9-3C7D-91BD-41198F69DD57> /usr/lib/libc++.1.dylib
0x7fff73b3a000 - 0x7fff73b4ffff libc++abi.dylib (400.17) <BA948A32-9024-3E55-98D4-18E31F6AED25> /usr/lib/libc++abi.dylib
0x7fff73b50000 - 0x7fff73b50ff3 libcharset.1.dylib (51.200.6) <D998A58B-E4A8-3685-9A6A-43AFC28100EB> /usr/lib/libcharset.1.dylib
0x7fff73b51000 - 0x7fff73b61ffb libcmph.dylib (6.15.1) <5D776FF6-DF7F-3EDD-B920-C07ED76C672B> /usr/lib/libcmph.dylib
0x7fff73b62000 - 0x7fff73b7affb libcompression.dylib (52.200.13) <EA767836-CBDC-318D-AC14-963C90D6CC67> /usr/lib/libcompression.dylib
0x7fff73e25000 - 0x7fff73e3bfff libcoretls.dylib (155.200.6) <6E68F922-752C-311F-B56D-EE391E6AE1F7> /usr/lib/libcoretls.dylib
0x7fff73e3c000 - 0x7fff73e3dff3 libcoretls_cfhelpers.dylib (155.200.6) <7300BA76-39D2-349E-9FB8-EBE5947A708A> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff73ef3000 - 0x7fff73fdbff7 libcrypto.0.9.8.dylib (76.200.2) <0B2819E5-A99F-3165-904D-3A659669D8C7> /usr/lib/libcrypto.0.9.8.dylib
0x7fff73fdc000 - 0x7fff7416cff3 libcrypto.35.dylib (22.200.4) <B4F83304-FB35-3CA5-8949-DE7D75B8A9D9> /usr/lib/libcrypto.35.dylib
0x7fff74307000 - 0x7fff7449fff7 libcrypto.42.dylib (22.200.4) <EFCEE49A-759B-3A9A-A164-ECD1A98D40F9> /usr/lib/libcrypto.42.dylib
0x7fff744a0000 - 0x7fff744abff7 libcsfde.dylib (546.50.1) <65E8F1F1-665A-381E-8932-D7CBA451991B> /usr/lib/libcsfde.dylib
0x7fff744b4000 - 0x7fff7450affb libcups.2.dylib (462.9) <51E06E95-891F-3B88-A8C3-35B514C57239> /usr/lib/libcups.2.dylib
0x7fff74534000 - 0x7fff74588ff3 libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib
0x7fff74642000 - 0x7fff74642fff libenergytrace.dylib (17.200.1) <D62ED169-B91C-3CCB-ADF5-E66AE4007B51> /usr/lib/libenergytrace.dylib
0x7fff74643000 - 0x7fff7465cffb libexpat.1.dylib (16.1.1) <D91D81FF-D190-36A7-B440-F4AEB4220C80> /usr/lib/libexpat.1.dylib
0x7fff74674000 - 0x7fff74679ff7 libgermantok.dylib (17.15.2) <9CBF0658-E83B-32E6-B674-3EE72D22C041> /usr/lib/libgermantok.dylib
0x7fff7467a000 - 0x7fff7467fff7 libheimdal-asn1.dylib (520.200.17) <58971629-3850-3905-A9A1-09FCF7A32815> /usr/lib/libheimdal-asn1.dylib
0x7fff746ab000 - 0x7fff7479cff7 libiconv.2.dylib (51.200.6) <3240A278-F537-3EC8-BE0C-983797520A50> /usr/lib/libiconv.2.dylib
0x7fff7479d000 - 0x7fff74a00ffb libicucore.A.dylib (62107.0.1) <EAE6FC43-3AD2-3A53-9F7A-4E5E5F66D006> /usr/lib/libicucore.A.dylib
0x7fff74a4d000 - 0x7fff74a4efff liblangid.dylib (128.15.1) <F79B6250-C0B1-3E8E-851F-6CA33B4311A3> /usr/lib/liblangid.dylib
0x7fff74a4f000 - 0x7fff74a67fff liblzma.5.dylib (10.200.3) <3ADDFA63-F37A-3C9C-91E4-58EE3113B9A1> /usr/lib/liblzma.5.dylib
0x7fff74a7f000 - 0x7fff74b2ffff libmecab.1.0.0.dylib (779.15.23) <6A38FCDA-17CE-30C3-AB66-A714CF645384> /usr/lib/libmecab.1.0.0.dylib
0x7fff74b30000 - 0x7fff74d6dfff libmecabra.dylib (779.15.23) <30E102AA-F3D3-3572-A1AE-1F2287DEF696> /usr/lib/libmecabra.dylib
0x7fff74f45000 - 0x7fff7529dfff libnetwork.dylib (1229.200.109) <AD59D28C-CCB2-3B34-B904-8CCCEB2CF320> /usr/lib/libnetwork.dylib
0x7fff7532e000 - 0x7fff75ab4fe7 libobjc.A.dylib (750) <2E868147-8818-359E-8CD7-A8B80665928F> /usr/lib/libobjc.A.dylib
0x7fff75ac7000 - 0x7fff75acbffb libpam.2.dylib (22.200.1) <8C419238-675A-3C41-B8D4-95E391CA630F> /usr/lib/libpam.2.dylib
0x7fff75ace000 - 0x7fff75b04ff7 libpcap.A.dylib (79.200.4) <5939AB23-B2A9-3C03-B6C1-4F0E5A21D9FC> /usr/lib/libpcap.A.dylib
0x7fff75b05000 - 0x7fff75b41ff3 libpcre.0.dylib (9) <E756BD3C-C54E-3D7D-85C3-90195F4342B5> /usr/lib/libpcre.0.dylib
0x7fff75c1e000 - 0x7fff75c36ffb libresolv.9.dylib (65.200.2) <0FEAEB01-B926-37FA-AB47-99BAC481C10B> /usr/lib/libresolv.9.dylib
0x7fff75c75000 - 0x7fff75c87ff7 libsasl2.2.dylib (211) <205CC13E-4ED7-3CE9-987F-12B28C6115A7> /usr/lib/libsasl2.2.dylib
0x7fff75c88000 - 0x7fff75c89ffb libspindump.dylib (266) <0E60D709-0A48-3905-ACD1-9DDE6FD8B476> /usr/lib/libspindump.dylib
0x7fff75c8a000 - 0x7fff75e61fe7 libsqlite3.dylib (274.20) <4434B695-BC65-30D6-AFED-1B6488DB3D2E> /usr/lib/libsqlite3.dylib
0x7fff75e84000 - 0x7fff75ebdff7 libssl.0.9.8.dylib (76.200.2) <E4BDEEE8-0E93-3F06-9172-BEDDF0D9D93F> /usr/lib/libssl.0.9.8.dylib
0x7fff75ebe000 - 0x7fff75f11ffb libssl.35.dylib (22.200.4) <6C42D9B4-1E35-3102-BA4A-164AD070F519> /usr/lib/libssl.35.dylib
0x7fff75f64000 - 0x7fff75fb1fff libssl.44.dylib (22.200.4) <CF4931A6-5928-3E2B-8E31-1854F36B0C19> /usr/lib/libssl.44.dylib
0x7fff75fb2000 - 0x7fff76003ff7 libstdc++.6.dylib (104.1) <0E48A478-4CFD-3111-8027-1047508A1D73> /usr/lib/libstdc++.6.dylib
0x7fff7603a000 - 0x7fff7606afff libtidy.A.dylib (16.1) <435FB24F-0289-3330-B485-713909D6DA44> /usr/lib/libtidy.A.dylib
0x7fff7608e000 - 0x7fff760edff3 libusrtcp.dylib (1229.200.109) <07B2AEC8-5FD4-34BE-B35B-B595283D9DC9> /usr/lib/libusrtcp.dylib
0x7fff760ee000 - 0x7fff760f1ffb libutil.dylib (51.200.4) <91EE9BF4-FB06-3260-B502-7EFDAD5AF59B> /usr/lib/libutil.dylib
0x7fff760f2000 - 0x7fff760fffff libxar.1.dylib (404) <4B4D0206-0B62-3E89-AD07-E7BB9E4DFA68> /usr/lib/libxar.1.dylib
0x7fff76104000 - 0x7fff761e7fff libxml2.2.dylib (32.6) <BFF70F01-6755-36B9-B7AA-724743E63503> /usr/lib/libxml2.2.dylib
0x7fff761e8000 - 0x7fff76210ff3 libxslt.1.dylib (16.1) <F191E8B9-7530-30CA-873B-2FA2BF2D6374> /usr/lib/libxslt.1.dylib
0x7fff76211000 - 0x7fff76223ffb libz.1.dylib (70.200.4) <99A3D725-8388-38B4-B66C-5E9006E6F072> /usr/lib/libz.1.dylib
0x7fff76251000 - 0x7fff76252ffb liblog_network.dylib (1229.200.109) <932F8E45-9A5A-3A42-9C5E-3FAE6CD8938E> /usr/lib/log/liblog_network.dylib
0x7fff76294000 - 0x7fff76298ff3 libcache.dylib (81) <FE21A7E9-DBEB-33AC-836B-785AD036ACF4> /usr/lib/system/libcache.dylib
0x7fff76299000 - 0x7fff762a3ff3 libcommonCrypto.dylib (60118.200.6) <78093D4F-91DB-35C8-981A-13375778B2E7> /usr/lib/system/libcommonCrypto.dylib
0x7fff762a4000 - 0x7fff762abfff libcompiler_rt.dylib (63.4) <A4D9CF37-D076-3CE9-95F1-DA89DA1601B6> /usr/lib/system/libcompiler_rt.dylib
0x7fff762ac000 - 0x7fff762b5ff3 libcopyfile.dylib (146.200.3) <4BCDADBF-79F5-3829-B47D-64DA0D44BCBF> /usr/lib/system/libcopyfile.dylib
0x7fff762b6000 - 0x7fff7633afff libcorecrypto.dylib (602.200.50) <7AEC5B72-0B92-37E8-808B-6732DB714139> /usr/lib/system/libcorecrypto.dylib
0x7fff763c0000 - 0x7fff763faff7 libdispatch.dylib (1008.200.78) <B8962879-AD55-3CF0-9B0A-5F1D57D1E14B> /usr/lib/system/libdispatch.dylib
0x7fff763fb000 - 0x7fff7642afff libdyld.dylib (625.13) <4B16C209-83D4-3817-9B62-C2F7FFB23755> /usr/lib/system/libdyld.dylib
0x7fff7642b000 - 0x7fff7642bffb libkeymgr.dylib (30) <A73AA788-C35C-3284-BFCA-95B1BBDF0CF3> /usr/lib/system/libkeymgr.dylib
0x7fff7642c000 - 0x7fff76438ff7 libkxld.dylib (4903.201.2) <EAF1CF8D-3843-33BE-8126-30994685B8F0> /usr/lib/system/libkxld.dylib
0x7fff76439000 - 0x7fff76439ff7 liblaunch.dylib (1336.201.2) <43E6698E-155E-3EAE-BAFF-CA5FCB35325C> /usr/lib/system/liblaunch.dylib
0x7fff7643a000 - 0x7fff7643ffff libmacho.dylib (917) <17BF7038-9C70-3EE1-9E96-3AE10D49669E> /usr/lib/system/libmacho.dylib
0x7fff76440000 - 0x7fff76442ff3 libquarantine.dylib (86.200.11) <C70DA995-0D6E-302C-A15E-F7F03A3857B4> /usr/lib/system/libquarantine.dylib
0x7fff76443000 - 0x7fff76444ff3 libremovefile.dylib (45.200.2) <D74A307B-3DC7-3992-B16C-DACB8207BE13> /usr/lib/system/libremovefile.dylib
0x7fff76445000 - 0x7fff7645cff3 libsystem_asl.dylib (356.200.4) <EC9D8AD4-E5CB-3765-804A-9E1E9DC045D2> /usr/lib/system/libsystem_asl.dylib
0x7fff7645d000 - 0x7fff7645dfff libsystem_blocks.dylib (73) <26419398-C30C-30F1-B656-A92AFA9560F6> /usr/lib/system/libsystem_blocks.dylib
0x7fff7645e000 - 0x7fff764e6fff libsystem_c.dylib (1272.200.26) <3DEEE96E-6DF6-35AD-8654-D69AC26B907B> /usr/lib/system/libsystem_c.dylib
0x7fff764e7000 - 0x7fff764eaff7 libsystem_configuration.dylib (963.200.27) <02CC3996-B34E-333C-8806-AE2699D34424> /usr/lib/system/libsystem_configuration.dylib
0x7fff764eb000 - 0x7fff764eeff7 libsystem_coreservices.dylib (66) <254B6849-2C8F-302C-8616-B8324A11AB30> /usr/lib/system/libsystem_coreservices.dylib
0x7fff764ef000 - 0x7fff764f5ffb libsystem_darwin.dylib (1272.200.26) <974E9EF7-DE72-34B7-B056-0A81C10DF8EB> /usr/lib/system/libsystem_darwin.dylib
0x7fff764f6000 - 0x7fff764fcff7 libsystem_dnssd.dylib (878.200.35) <FFC665AA-B257-35AD-BD8B-32FD42C2EEC1> /usr/lib/system/libsystem_dnssd.dylib
0x7fff764fd000 - 0x7fff76549ff3 libsystem_info.dylib (517.200.9) <0707C387-D7DE-372E-8FF1-3DE5C91932D6> /usr/lib/system/libsystem_info.dylib
0x7fff7654a000 - 0x7fff76571ff7 libsystem_kernel.dylib (4903.201.2) <45FAA4C0-D553-34FD-ADF8-884886AE0D2A> /usr/lib/system/libsystem_kernel.dylib
0x7fff76572000 - 0x7fff765bdff7 libsystem_m.dylib (3158.200.7) <43D1796B-954F-37D6-B1AC-9D80DF0655A2> /usr/lib/system/libsystem_m.dylib
0x7fff765be000 - 0x7fff765e2ff7 libsystem_malloc.dylib (166.200.60) <846F6898-117C-3427-A8FB-3772FFC2410B> /usr/lib/system/libsystem_malloc.dylib
0x7fff765e3000 - 0x7fff765eeffb libsystem_networkextension.dylib (767.200.40) <F84D5474-4DC1-3E1A-AE00-8CE9593278B4> /usr/lib/system/libsystem_networkextension.dylib
0x7fff765ef000 - 0x7fff765f6fff libsystem_notify.dylib (172.200.21) <BCCB222F-DC64-3954-A836-DCCE6659CA5A> /usr/lib/system/libsystem_notify.dylib
0x7fff765f7000 - 0x7fff76600fef libsystem_platform.dylib (177.200.16) <B75B04AD-69FE-3ADE-84D2-C17972FC8F49> /usr/lib/system/libsystem_platform.dylib
0x7fff76601000 - 0x7fff7660bfff libsystem_pthread.dylib (330.201.1) <87A6B136-E423-3B6D-A58A-137F392D7D9D> /usr/lib/system/libsystem_pthread.dylib
0x7fff7660c000 - 0x7fff7660fff7 libsystem_sandbox.dylib (851.201.1) <FBA7E09B-F10F-3424-90EA-B4999B7FB461> /usr/lib/system/libsystem_sandbox.dylib
0x7fff76610000 - 0x7fff76612ff7 libsystem_secinit.dylib (30.200.13) <CBEAB62B-F0A0-342F-9878-CADC14A3CB0D> /usr/lib/system/libsystem_secinit.dylib
0x7fff76613000 - 0x7fff7661aff7 libsystem_symptoms.dylib (820.207.88) <B6E22FA8-0F7B-36FD-9D99-284056D3CB47> /usr/lib/system/libsystem_symptoms.dylib
0x7fff7661b000 - 0x7fff76630ff7 libsystem_trace.dylib (906.200.86) <7983ED77-18B5-39A5-BE19-AE4F2832ADEA> /usr/lib/system/libsystem_trace.dylib
0x7fff76632000 - 0x7fff76637ffb libunwind.dylib (35.4) <41222EF6-2233-3CF4-947A-15D48CB8C030> /usr/lib/system/libunwind.dylib
0x7fff76638000 - 0x7fff76668fff libxpc.dylib (1336.201.2) <0A8747D1-33AA-37E1-B97A-BA9B95FE4E8C> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2484
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.2M 9
ATS (font support) (reserved) 4K 2 reserved VM address space (unallocated)
Accelerate framework 384K 3
Activity Tracing 256K 2
CG backing stores 62.9M 5
CG image 136K 14
CG raster data 32K 4
CoreAnimation 52K 7
CoreGraphics 8K 2
CoreImage 24K 3
CoreUI image data 952K 12
CoreUI image file 516K 4
Foundation 32K 4
Image IO 80K 9
Kernel Alloc Once 8K 2
MALLOC 574.9M 120
MALLOC guard page 48K 11
MALLOC_NANO (reserved) 384.0M 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 251 32K 3
SQLite page cache 64K 2
STACK GUARD 56.1M 35
Stack 32.3M 36
VM_ALLOCATE 24.3M 60
__DATA 86.1M 784
__FONT_DATA 4K 2
__GLSLBUILTINS 5176K 2
__LINKEDIT 517.5M 288
__NV_CUDA 6064K 3
__TEXT 887.3M 621
__UNICODE 560K 2
libnetwork 640K 8
mapped file 149.8M 78
shared memory 7752K 23
TOTAL 2.8G 2130
TOTAL, minus reserved VM space 2.4G 2130
Model: iMac17,1, BootROM IM171.0157.B00, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.34f2
Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe
Memory Module: BANK 0/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, 0x202020202020202020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
Bluetooth: Version 6.0.8f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST2000DM001, 2 TB
Serial ATA Device: APPLE SSD SM0128G, 121,33 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
Thunderbolt Bus: iMac, Apple Inc., 28.1
Hi krystynaw58700073,
Sorry for the issue with Queue to Media Encoder feature.
1. Have you tried to uninstall and reinstall Media Encoder?
2. Is this happening with all projects? Please check with a new project and a simple composition.
3. Is there an anti-virus or firewall enabled in the machine? If yes, disable them and see if it works.
4. Are you logged in as an Administrator? Just for a test, log in to a different Admin account in OS and see if the issue persists.
Vidya
I'm having this issue. uninstall and reinstall hasn't helped. I've checked your 4 points, no help. Also can't import from AE to premiere. how do I fix the link issue?
Please uninstall & reinstall Adobe Media Encoder on ap lioa
SOLUCIĆN
Yo tenĆa el mismo problema pero logrĆ© solucionarlo. Busquen en preferencias de AE y el Encoder. Anteriormente ya dijeron quĆ© modificar en el preferencias de AE. En el Encoder, vayan a preferencias y luego a Sincronizar configuraciĆ³n. Una opciĆ³n dirĆ” "Al sincronizar", deben seleccionar "cargar siempre configuraciĆ³n". Luego, si desean pueden volver a la configuraciĆ³n anterior.
YES!!!! thank you anthony!!..it finaly works... For me this is the sollution....preferences in Adobe Media encoder > synchronize configuration > always load configuration....and VOILA it works.
Awesome, thanks!
I think in my version it's called differently:
Media Encoder menu > Sync Settings > Manage Sync Settings > "When Syncing: Always Upload Settings"
