This has happened several times now since I upgraded to the latest version. The imported PNG file looks like this
The file I opened is here: https://funkironmetalart.com/wp-content/uploads/2018/01/vintage-18.png
No problems here:
Perhaps you can try to check or uncheck your GPU perfomance.
I have the same problem with png.
I tried everything you said and still it won't open.
It seems, you tried to place the PNG?? Or copy&Paste ???
What is if you "only" open your (saved on your computer) PNG?
I tried every option place linked, embedded I even opened it as a separate file the result was the same.
I restarted photoshop and then it worked normal.
Any one of these methods (paste, place, open) should deliver the same results.
What is with all these bugs?!
Go to Preferences > Plug-ins and uncheck these options, then restart Photoshop
Allow Extensions to Connect to the Internet
Load Extensions Panel
That worked for me. Thanks!
Thanks Ged
Turned off (restart) on (restart) YEA! - seems to reset something - now have both ping and extensions both working properly
Can someone explain why this solution works?
Yah - this is pretty awful! - Levels is wacky too
Command + Option + Shift > click on Photoshop icon - delete prefs. All Fixed.
I am having this problem too. I get the same type of image to when trying to open any png from a client or coworker. The "fixes" above don't help. Is this an Adobe problem? Another problem I also noticed the pen tool won't work if the canvas is rotated.
