Best exporting settings for clips from original footage
Feb 09, 2018 Feb 09, 2018
Good day everyone,
I've been recently saving clips from Shadowplay Recordings because I want to have them for later use instead of having the whole recording take up my hard drive space. My question is, for the bitrate settings, should I export it at the total bitrate my recording was from Shadowplay and set a maximum to be just a little higher than the total bitrate of the recording so it has room for any high action frames? Or does it not matter what bitrate settings I set for the export of the clip(s)?
565
Contributor ,
You may use CBR 1 pass with12bitrate which won't take all your HDD space, and will give you good quality,
Thank you for your response.
I used VBR 2 pass with 35 target and 45 maximum as I really don't mind the clips being so big as long as they aren't as big as the original, longer recordings. I came out pretty well, but will try your method and compare quality!
Contributor ,
Feb 12, 2018 Feb 12, 2018
If you are not really mind of clips being even bigger then the original, then set the target bitrate 72 and maximum 78
If I were to use those bitrate settings, what passage would you use? CBR 1 pass or VBR 1 pass or 2 pass?
Thanks for the response!
It would be helpful to know what resolution and frame rate we are even discussing here, makes a difference. Is the footage 1080p or 4K or what?
Jeff
This is what I am working with, all of my recordings come from Shadwoplay recordings at the moment, sometimes from OBS, but about the same bitrate all around
Contributor ,
Feb 13, 2018 Feb 13, 2018
vbr 2 pass
