Locked
Connection Script to MariaDB using PDO PHP 7 fails
Participant ,
Feb 10, 2018 Feb 10, 2018
I have a site on a production server with a hosting company that has connected to our MariaDB for a couple years with no problem using our connection script in PDO version 7.x PHP.
I'm looking at moving our sites to Google Compute Engine on Google Cloud Platform  so I'm running a trial VM. I've spun-up a debian-9-stretch and installed Apache, MariaDB and PHP 7.x.
My connection script fails to connect to my database thus getting the error message Cannot connect to database.  I have checked the usernames and passwords and the database name for errors and there are none.  The read and write usernames and their encrypted passwords are in database MySQL table user and were placed in that table using the command line.  The connection script is:
<?php
function dbConnect($usertype, $connectionType = 'pdo') {
$host = 'localhost';
$db = 'mswaxa15_mqzmkt';
if ($usertype == 'read') {
  $user = 'mswaxa15_psread';
  $pwd = 'j3&uG39#bR2m';
} elseif ($usertype == 'write') {
  $user = 'mswaxa15_pswrite';
  $pwd = 'Ne#6B?uQx9#2k';
} else {
  exit('Unrecognized user');
if ($connectionType == 'mysqli') {
  $conn = new mysqli($host, $user, $pwd, $db);
  if ($conn->connect_error) {
   exit($conn->connect_error);
  return $conn;
} else {
  try {
   return new PDO("mysql:host=$host;dbname=$db", $user, $pwd);
  } catch (PDOException $e) {
   echo 'Cannot connect to database';
exit;
Any help getting this connection script to work would be greatly appreciated.  Thank you.
Code , Error
14.1K
Community Expert , Feb 11, 2018 Feb 11, 2018
1. Have you activated 'extension=php_pdo_mysql.dll' ?
2. Is 'localhost' recognised or do you need an IP-address like '127.0.0.1'?
Wappler, the only real Dreamweaver alternative.
Participant ,
Feb 12, 2018 Feb 12, 2018
Thanks for the reply Ben.
Something must be side-ways on the server I spun-up at GCE since my connection script is still not working and I have very limited skills as a System Admin.
I've included below 3 screen shots that I believe show I have PDO enabled and the extension=php_pdo_mysql.dll activated.  In addition, I changed the script from 'localhost' to '127.0.0.1', restarted Apache from the command line (pretty sure) limited "flight time" on a command line, still no connection.
Any other suggestions would be appreciated; but, like I say maybe it's not the script but the server set-up that's not letting PDO interface with MariaDB.
Rather than using your script to connect, try this
<?php
$server = "localhost";
$user = "mswaxa15_psread";
$pwd = "j3&uG39#bR2m";
try {
  $connection = new PDO("mysql:host=$server;dbname=mswaxa15_mqzmkt", $user, $pwd);
  // PDO can throw exceptions rather than Fatal errors, so let's change the error mode to exception
  $connection->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
  echo "connection successful";
catch(PDOException $e)
  echo "Connection failed: " . $e->getMessage();
Participant ,
Feb 13, 2018 Feb 13, 2018
Thanks Ben for all your assistance.
As you saw, I activated the extension then it (finally) struck me I had not granted appropriate privileges to the users for this particular database.  Jumped on my SQLyog, went to User Management took care of the privilege issue.  Connection script worked great.
Sorry to have not gotten back to you sooner.  Since I'm on other side of world, little delay on my part.
Again thanks for all the help and I will keep the other connection script you provided as a good backup resource.
Thanks for the feedback and very glad you managed to resolve the issue.
Apr 12, 2018 Apr 12, 2018
There might be something wrong with your php script. You can follow this tutorial to get the correct script and know how to correctly make pdo connection in PHP.
