These are all the same portrait image, but they contain different developing processes, as color corrections, sharpening, etc.
They are all saved to same folder. Other folders give no problems.
The icons on all are normal. However, many of the tif images show something that looks like a "cut out" where all the background is missing and just the subject can be seen, as if there were a mask on the image, There is no mask on final layer. This occurs with latest Photoshop as well as any other app I can use to open tif files.
No other files are like this. The do appear normal when seen in Lightroom.
11,000 other images display normally in Photoshop, lightroom and any other app that will open tif files.
I am on iMac using Sierra. All apps are latest update.
Any suggestions? Help? Advice?
thanks
vince
Please post meaningful screenshots – so an affected image open in Photoshop with all pertinent Panels (Layers, Channels, …) and the folder window in Finder that displays the »faulty« icon.
Do the images have alpha channels?
Yes, as usual c. pfaffenbichler, you are correct.
Last night, lying in bed, I thought that an alpha might explain it. I would look today. I found that to be the explanation since they were copies of the same image, all had an alpha channels that blocked the background.
I gave you "CORRECT ANSWER' because you were first. 2 others also were spot on.
I NOTE D.A.R got it right , as well as a fellow Italian, melissapiccone.
THANKS TO ALL OF YOU MY PROBLEM HAS BEEN SOLVED
Vince
Are you viewing the files in the Finder in order to see the cutout effect?
Do the images have Alpha channels that correspond to what you are seeing?
Open the tif files and look in the channels and paths and see what you find. As stated above, the image most likely has an alpha channel save in there.
