No matter what I enter in the search box, I get the below
error message. Is it just me? I waited several hours and tried
again, but I still get the same message.
/Eileen
The following information is meant for the website developer
for debugging purposes.
Error Occurred While Processing Request
Variable FTVAR_RESULTTYPE is undefined.
Resources:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debug Output Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1;
TuneUp HTML Client Embedded Web Browser from:
http://bsalsa.com/; .NET CLR
1.1.4322; .NET CLR 2.0.50727)
Remote Address 10.172.32.23
Referrer
http://www.adobe.com/cfusion/webforums/forum/categories.cfm?forumid=65&catid=448&entercat=y
Date/Time 16-Jan-09 05:38 AM
