My keyboard's Numberpad does not work in LR export menu... I use the numberpad throughout lightroom, but only when in the export menu do is dump me out, for instance when I change the dpi setting manually... it is frustrating as I know it used to work just fine... I keep searching for a setting I may have missed, but it only happens during export...
I cannot replicate your problem on my Windows 10 computer. Have you tried restarting your computer?
Working fine here too. Win 7 Pro, LR C CC 7.2. Logitech wireless keyboard and mouse.
What type of computer are you using?
Is the box highlighted before you start entering numbers?
Imac w/ a windows keyboard... yeah restarting is not going to fix it... it is only on that menu
And you are using the Numeric Keypad to the right of the regular keys?
Have you tried the number keys above the letter keys? If you have do they work.
Something is turning the numeric keypad off. This is quit common on Apple computers because AFAIR no Apple keyboard has a numeric keypad. At least none that are available today.
What happens if you hit the Num Lock button?
the numberpad works in every other place in lightroom except that menu... I
tag/rate my photos with the number pad all day long... the number pad works
on/in every other application that I use.
I'm pretty sure there is a GUI coding error with that particular box. This
has not been an issue until 2 updates ago.
On Wed, Feb 14, 2018 at 1:56 PM, Just Shoot Me <forums_noreply@adobe.com>
