I have an old copy of Adobe Acrobat Pro 9, and I can't seem to find the function where I can add alternative text to images. I know it can be done. I googled videos for it and just find the latest versions.
I just noticed that the following is not activated in my Adobe Acrobat Pro 9, But it was before. I had uninstalled it from my computer a long time ago. and this morning reinstalled it, and the following is not active now.
To add alternate text to an image, choose Tools > Advanced Editing > TouchUp Object Tool. Click the image. Right click and choose Properties... from the context menu. Click on the Tag tab and fill in the alternate text field. To add alternate text to tags in the tags panel, select the tag, choose Options > Properties, click the Tag tab, and fill in the alternate text field.
[Moved to Acrobat forum]
Is there anyone out there running Adobe Acrobat 9 Pro ?
I am ... I'll look to see if I can edit via a plug in.
I have Acrobat Pro 9 and wonder if the edit plug in is available.
Hi Jaspermaxx44,
As mentioned in post#1, you can edit text using Touchup object tool in Acrobat. You may refer to the following link for more info:
Adobe Acrobat 9 How-To #57: Editing Text and Modifying Attributes > Tips for Tranquil Text Tweaking
Let us know if you have any further question.
Shivam
