bought Photoshop Just bought a NEW pc very fast
hp pavilion power desktop - 580-015xt
Installed photoshop
now its slower than my old pc
JJMack wrote
It very posible the his machine has nvidia and intel gpu and need to use Nvidia control panel to make sure ythat Photoshop and sniffer prefered GPU is the nvidia gpu not both GPUs.
I always wonder when I see an odd number for system memory, which is 12Gb in this case. It makes me think it might be using on-board graphics which borrows from the usual 16Gb or RAM. The specs above mention a GTX1060, which is not stellar, but does at least have its own DDR5 memory (3Gb). So definite
...Copy link to clipboard
If your old PC was also running Windows 10 I thing there may be a problem with your Photoshop installation. Use Photoshop's menu Help>System Information and post the information here.
Also check if you have Graphic Processor acceleration and OpenCL enabled (may require drived update)
I always wonder when I see an odd number for system memory, which is 12Gb in this case. It makes me think it might be using on-board graphics which borrows from the usual 16Gb or RAM. The specs above mention a GTX1060, which is not stellar, but does at least have its own DDR5 memory (3Gb). So definitely worth checking what JJ has suggested.
Try installing system checking software like CPU-Z and/or Speccy, and make sure that the Turbo boost is kicking in. You might need to enable that in the BIOS. Another thought, although not a nice one, is that there is a problem with CPU cooling and it is getting too hot and throttling.
I can't see what motherboard you are using from the above specs, but Speccy will tell you that. You can then Google — or just read the manual that came with the computer, to see where to enable Turbo Boost in BIOS (if is in fact not kicking in).
Is this the correct spec for the new computer? If yes, what was the old computer?
HP Pavilion Power Desktop PC - 580 (X6B79AA#ABA) | HP® Store
The reason I posted what I did was I also saw a web page for the machine that had this and I said to me self what if!
