Backslash for toggle rubylith layer mask on/off is not working (Danish keyboard)
Feb 12, 2018 Feb 12, 2018
Hi
I am using PS CC (English version) on Windows 10 with a Danish keyboard.
Nothing happens when a layer mask is active and I hit the \ key (AltGr + <>).
- Can the keys be forund with another key combination?
- Is there an alternative way to switch "show a layer mask as rubylith" on/off?
Soren
4.6K
correct answers 3 Correct answers
Community Expert , Feb 12, 2018 Feb 12, 2018
You could create an Action and assign it an F-key.
Have you used the Brush tool while in Quick Mask? You should see a red stroke. When you leave Quick Mask, the Red Stroke is a selection. The settings should be as below.
A selection tool acts differently. You make the selection before going into Quick Mask, then after pressing Q, you see the rubylith and also Quick Mask in the title tab. If you press Q before using a section tool, you will not see the red area. This example uses the rectangular Marquee tool.
Is it working as explained?
Community Beginner , Sep 22, 2020 Sep 22, 2020
He is talking about Toggle layer mask on/off as rubylith (layer mask must be selected) [\] function. Since in many keyboard layouts the key for "\" (backslash) does not exist (for example, on Croatian keyboard the "\" character is Alt Gr + Q and there is "Ž" character instead of the backslash character), the OP wanted to know if there is another way of activating that function and the answer is:
Shift + Alt + click on the layer mask (PC)   Shift + Opt + click on the layer mask (Mac)
Adobe
Thank You both for your suggestions.
Now I see that "Q" as well as the "Edit in Quick Mask Mode" tool is changing the mode as indicated on the status line in the top. And in the Layers panel there is a red marking of the layer. So I think the suggestion to use Q in stead of \ has solved the keyboard issue. Thank You so far.
But still I see no red colour on the mask itself although I have checked the "Layer Mask Display Options" and increased the opacity. So I think there must be another problem.
Any suggestions why don't see the red colour on the image?
Soren
If it is not working as described, try resetting Preferences.
Thank you. My apologies.
Everything seems to be OK.
I just I have to work more with Quick Masks to find out how I can use it.
Soren
Feb 16, 2018 Feb 16, 2018
Just for information if anybody get the same problem:
I was NOT looking for the Quick Mask functionality. I was looking for the functionality that makes an active layer mask visible together with the image as a red overlay. This is a very useful feature, when you want to make adjustments to a layer mask. Without this functionality it is only possible to see either the image or the mask in black and white.
The mask overlay looks like the overlay in the Quick Mask functionality, but it seems to have nothing to do with it. The mask overlay can not be toggled on and off with the Q key. The only way I have found to toggle the mask overlay on and off is to use the \ key on the US keyboard.
But unfortunately this key doesn't seem to work right on the Danish keyboard. The only way I have found it possible to find the mask overlay is to configure my keyboard as an US keyboard. This can be done under Settings, or you can hold down the Windows key and touch the space bar.
Soren
Feb 17, 2018 Feb 17, 2018
I never heard of this, but yes I see what you mean. View Your Layer Mask As A Rubylith
Ok, glad you found a workaround.
Gene
Feb 05, 2019 Feb 05, 2019
I have the same problem with Spanish (ISO) keyboard.
Apr 04, 2020 Apr 04, 2020
I had the same problem. I have the correct solution. Be on the layer and mask that you are referring to. Then go to channels and double click on that same layer mask and Layer Mask Display Options will come up. Change it from black 100% to red 60%. Paint black for the red overlay and white to remove the red overlay.
The only way for using "Toggle layer mask on/off as rubylith (layer mask must be selected)" function with keyboard layouts that don't have "\" key is Shift + Alt + click on the layer mask. The same problem is with the Croatian keyboard layout where there is "Ž" character in the place of "\". The backslash character on Croatian keyboard is Alt Gr + Q but that doesn't work.
Q is usually the keyboard default for Quick Mask (rubylith). Not so on Danish keyboards?
Sep 23, 2020 Sep 23, 2020
