Locked
Menu Item height changes when adding / removing pages
Feb 16, 2018 Feb 16, 2018
Hello - kind of new to this... So excuse me if I am overlooking a simple fix - but when using
a 'vertical menus widget' I am having trouble keeping the size of the menu item / housing bar
consistent when adding or subtracting pages from the site plan - add pages it shrinks in
vertical height - delete pages it grows. Have tried  both uniform size / uniform spacing in options
as well as various parts positioning options. IF Graphic styles are applied it also occurs....
Any help would be gratefully received... Thanks and Best - Julian
328
LEGEND , Feb 21, 2018 Feb 21, 2018
This is normal behaviour of vertical menus.
The height, which is defined in the beginning stays fixed, and the menu entries share this area. In other words:
If your vertical menu has a height of 300 px and only one menu entry, this entry will have a height of 300 px too.
If you have two entries, each one will have a height of 150 px (150px x 2 = 300).
If you have three entries, each one will have a height of 100 px (100px x 3 = 300).
This is the way, Muse works and it helps, to define the dimensions,
Feb 20, 2018 Feb 20, 2018
Hey Julian,
It works as expected at my end.
With "uniform size option the widget's size remains intact and the height of particular menu label increases or decreases accordingly.
However, with "uniform spacing" option it goes totally opposite and does what you are asking for!
Can you please check once again and share some visual references with us like a screenshot or a video to depict the issue?
Ankush
Ankush - Thanks so much for responding - much appreciated,
maybe its something I have set up incorrectly but i have just started
from scratch, and it happened again — so made some screenshots
attached as single file that I hope demonstrate the issue i seem to be facing.
Your help and time are much appreciated.
Best - Julian
You could really follow ankushr40215001​, and watch out the flyout (blue arrow) menu options panel. See screenshot –
I added four pages , set up my two different setupped menus (uniform spaces and/or size – I called them equal distance / equal size, but,  hey I´m a native German Swabian, so don`t blame me for that ), deleted all pages except one and watch the result:
This should explain what happened to you, not your fault, though. Simply setup your menu at the end, when you have the desired number of pages.
Best Regards,
Uwe
Feb 22, 2018 Feb 22, 2018
Thanks so much for taking the time to help - much appreciated - Best - Julian
Please refer to my screenshots below.
Hope this helps!
Ankush
This is the way, Muse works and it helps, to define the dimensions, a menu should have, from the beginning.
Additionally: This is exactly the same behaviour, you see with horizontal menus: The menu items share the width you have defined for the complete menu. Adding a menu item, makes all items smaller in width, deleting an item makes the remaining ones wider.
Thanks Günter for your time, help and clear explanation - appreciated - Julian
Ankush - Thanks so much for taking the time to help.
Guess i was approaching it like adding page numbers in and Indesign doc - add them first to
the master then add pages and it says as was - So I was building a menu then adding pages -
and clearly going at it the wrong way round - so now I know... Thanks much - Best - Julian
