Here is a screen of my camera raw window after the recent update. I would like for it not to be oversized.
Any help?
Screen res = 1920x1080
Screen size = 15"
Windows 10
Hi Johno.
I had the same issue.
I went into "system" "display" and "scale and layout" and changed it to recommended size of 125%
Hi John:
You can drag the lower left corner of the window to make it smaller, then reposition it by dragging the title bar at the top.
~Barb
I can, but it only sizes down a small bit. Still oversized.
Hi John:
Has the sizing changed for all of Photoshop, or just the ACR dialog box? Are you on Windows?
~Barb
Just the ACR window.
I am using Windows.
Ok, I see that there is already a patch for Camera Raw 10.2. Have you installed it yet? Takes you to 10.2.1:
~Barb
Trying now
Same results....oversized.
OK, then next I would take a look at the Windows magnification settings and/or UI Scaling in Photoshop Preferences > Interface. See if you can tweak either of those settings to fix the issue.
~Barb
Hi Johno.
karnikc, THANKS!
That worked. Must have been reset during an update.
John
I think it's the best way to solve the issue
Fantastic 🙂
