So i bought new monitor (dell u2518d) which has bigger resolution than my laptop. Laptop has 1920x1080 (gtx 960 m) and monitor 2556x1440. So if monitor set to max resolution, photshop works very slow, a lot of lag then drawing with wacom. Can i fix it?
That video hit most of the problems but as he point out at the end brush setting and document size must also be reasonable.
While he had problems making Photoshop lag again after he made the configuration changes it easy to switch back. You need to set Photoshop preferences setting back, configure Wacom Tablet to use ink again in Photoshop. Stop Photoshop remove the configuration file you added to Photoshop preferences and then restart Photoshop.
Even when you get Photoshop working well. I
...Copy link to clipboard
Many thing can cause lag. I can easily cause Photoshop lag on the fastest machine using the minimum display size 1024x768 with a Wacom tablet or a mouse. If you let me use a wet brush I bet a could perform a single quick stroke that would take minuets to renders on the display. This one has been running more that 5 minuets and is still not done.
Its done
Even a more normal brush stroke on a document that size zoomed to fit on screen will lag. Thes stroke took a few seconds. My machine is not the fastest and my display is 1920x1080
This video helped me to optimize photoshop
MAKING PHOTOSHOP PAINTING FAST - Tutorial - YouTube
P.S. that mirror drawing you used, is this plugin ?
Even when you get Photoshop working well. If you create a huge document zoom all the way out so it fit on your display and use a large brush tip with spacing set to 1% there will be lag.
There are some things he did not hit. I find Wacom double click distance should be turned off in Photoshop and in Windows control panel Pen and touch I turn off flicks and press and hold. All this has been posted in the forum before.
