I purchased a new laptop, re-installed Lightroom, and copied all files to the new hard drive (actual pictures, catalogues, etc)
Now when I import new pictures, the pictures actually go to the correct place, but in the library they show as a new root directory rather than their proper location. If you try to move the new folder to its proper place, Lightroom tells you there is already a file with that name -- which is true as the file is actually in the correct place. Just not in the Library list. If you look in file explorer, everything is fine -- its just the library list that is wrong. How do I fix this so new imports show correctly in the library?
doug@dougandpam wrote
But it appears you can't rename the user folder. Do I need to set up a new user folder called Doug (vs doug) and copy every file I have to the new user folder? Will it even let me a create a new user folder with in effect the same name?
Doug
Nothing like that. As I said earlier, the fix is quite simple. Proceed as follows:
1. Take a catalog backup, as a "just in case" restore point.
2. On your hard drive, but outside the Users folder, create a folder called e.g. Capsfix.
3. In
...Copy link to clipboard
In all probability you've changed the capitalisation of the file-path on the new laptop (typically the user-name is slightly different, e.g. Jim on one system, jim on the new). This trips up Lightroom because it would see Jim and jim as different, but the OS seems them as one and the same.
It's easy enough to fix once we've identified the source of the problem. To do that you need to hover the cursor over the Pictures folder in the Folders Panel, and a popup will show the full path to that folder. Note that down carefully, ensuring you get the capitalisation correct. Then repeat for the "Test Import" folder. Post both paths back here.
I think you're onto something -- the root shows
C:\Users\Doug\Pictures\Pictures
and the Test Import shows:
C:\Uers\doug\Pictures\PIctures\Boats\Test Imports
The Doug vs doug seems to be the issue.
The folder on my new computer is C:\Users\doug
Do you recommend renaming is C:\Users\Doug?
Doug
I'm not sure that changing the user name is entirely straightforward, however to fix the Lightroom issue to use the "doug" username is fairly easy. What do you want to do, change the username or have LR fixed to use the current username?
Doug
That might be the only solution. That is if you can actually create a new user with only the Capital D changed.
Doug
3. In Lightroom's Folders Panel, right-click on the "Pictures" folder and select "Update Folder Location".
4. In the resulting file browser, navigate to and select the "Capsfix" folder that you just created.
5. Pictures will disappear from the Folders Panel and Capsfix will appear.
6. Now right-click on "Capsfix" and again select "Update Folder Location".
7. In the resulting file browser, navigate to and select the "Pictures" folder in your user library.
8. You may receive a "Merge" dialog warning message, if you do, click on "Merge".
That should be that, future imports will now go into the correct place and will appear in Lightroom's Folder Panel in the right place.
Jim:
THANK-YOU SO MUCH. That fixed my issue.
I'm very impressed you responding on a Sunday, and with a quick and solid solution. Sincerely appreciate it.
Doug
