I have had this problem for some time now (probably more than a year). Whenever I open a PDF, Acrobat has the hand tool as the default instead of the select tool. I know I can manually switch. I know I can use the keyboard shortcut "v". I have tried about every solution on the internet, including deselecting a host of settings, editing the preferences, and uninstalling and reinstalling. None of this works. A quick Google search shows that hundreds of people have had the exact same problem for years (at least since 2009). One search even showed up with an Adobe rep saying it was a problem they were working on.
So is there any confirmation of this incredibly annoying behavior by Adobe? I don't think I have used the hand tool once in a decade of Acrobat use. I don't want it to be the default. Ever. I just want the software to do what it claims - that is, to save my preferences. Is there a registry edit that will fix this? Or a manual edit of an Acrobat preference file (not the UI)?
Really sorry for this issue you're facing. We are not able to reproduce this issue at our end. Hand Tool/Cursor tool should be sticky. Could you please provide us with the following information so that we can try reproducing it at our end
1) Which OS are you using.
2) What is the Version of Acrobat you're using. Steps to know Acrobat/Reader version:
Win: Go to Help menu -> About Adobe Acrobat Pro DC. A window would pop up containing version number. You may send us snapshot of the pop up window.
Mac: Go to Acrobat menu -> About Adobe Acrobat Pro DC. A window would pop up containing version number. You may send us snapshot of the pop up window.
You can send the above information to me at [Moderator: personal information removed (can send a private message:How Do I Send Private Message )]
Thanks & Regards,
Paramjeet Yadav
i am having the same issue
i have changed it in Prefrences but it still starts off with the hand tool and not the slect tool
this is driving me crazy - please help
Often, the right answer comes from abandoning the wrong question.
In Preferences, you can ask the Hand tool (default tool) to behave like the selection tool.
