I'm having issues with a specific file in photoshop CC. I've been working on this image and earlier today it was fine. Now, it's not tracking changes on the images. For instance, I deleted two text layers and saved the image. The text from those two images still appears on the graphic but teh layers are removed from my layers panel. If I attempt to hide a layer it doesn't go away. If I attempt a color change on a text layer it doesn't show up. However, if I open a new file I can do all of that...
What is going on and is there a solution. I've spent hours on this specific file and I do not want to redo it because of some weird issue at this point.
Moving to Photoshop​
What happens when you close the file and shut down the program and relaunch the program and open the file ?
Same issue ?
In preferences>general> select delete preferences on quit. Save your workspace and close and relaunch. I've never heard of your issue but that should fix it. Should ...
Did you try to save the file and than restart photoshop and clean the preferences?
Command or control Option or Alt Shift when you launch PS you will get a message ot clean preferences.
Sy yes and try to open the file and work...se if this helps
