Hello, is their a way in Adobe Muse to create a menu that when you rollover 'HOME' for example, the other menu items darken and Home stays white. In the normal state all the menu Items are white.
An example of what I want done is the Carhartt WIP menu.
Thanking you in advance
J
Hey jasona,
If I understand correctly, you want the rollover effect to be on other objects rather then what the mouse if hovered, correct?
If that is the case you can use a composition widget to achieve this effect.
Keep the Trigger and target fill transparent and place a trigger on top of your Logo.
Now you can place the changed content (Like you want on rollover) in target container and place it exactly on top of your original content.
Please refer to the video (refer to widget part of it) which might help: Adobe Muse: Customize Widgets - YouTube
Hope this helps.
Ankush
Thanks for your reply, I was thinking about using the composition window but the problem with this is, placing the text exactly on top leaves a slight hallow, especially with the background being black
