I recently updated my Acrobat Pro DC. Since the update, it keeps crashing when I try to use the edit tool. The error message reads " Adobe Acrobat DC has stopped working". I've gone as far as uninstalling and re-installing the program.
Is there a bug in the new update?
I did figure this problem out. Deleting the custom preferences files did not work but I went ahead in the Toolbar and reset and deleted all the quick links I had. Once doing that, it was in working order again.
[Moved to Acrobat forum]
Hi KMuolo,
Could you please share dot version of Acrobat DC installed on the machine? To check the version, you may refer to the steps given in this link: Identify the product and its version for Acrobat and Reader DC
And, the operating system you are using?
Shivam
I believe this is the dot version: 18.011.20035
I am on Windows PC
Thanks! Could you please try editing another pdf file in Acrobat to check if its not a file specific issue?
Also, would it be possible to share the pdf file with us to analyze the issue at our end? You may refer to the steps given in this link on: How to share a file using Adobe Document Cloud
Yes, I have tried multiple files. The following is one of the simpler files, just a logo: Shared Files - Acrobat.com
Thanks for sharing the link. I tried replicating the issue with the file but the issue was not reproducible. Could you please try rebooting the machine if you haven't already and try editing pdf files again. If that doesn't work, reset preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. , reboot the machine and check.
I'm pretty sure I reset the preferences. I dragged the files to my desktop. Am i supposed to be deleting them? I don't want to loose preferences I may have set a long time ago and find out they no longer work.
My IT guy also saw this problem so I am unsure how else to fix this. Can someone from Adobe remote in to my desktop?
Deleting those files will also delete the custom preferences you set. If the issue still persists after resetting the preferences, then the issue isn't related to the preferences. Drag the folder back to its original location to restore custom settings.
Please contact our support using this link: Contact Customer Care ( sign in using your Adobe ID to begin).
Click Adobe Acrobat Pro> download and install > show me my contact option > select from chat or phone.
Shivam
#KMuolo2018.0228: what do you mean (Toolbar) "reset" "quicklinks". I find nothing like that in the Toolbar menu.
