7 Replies Latest reply on Feb 22, 2018 12:20 PM by Stephen_A_Marsh
    Extract part of filename and write to "Title" field in IPTC
    opn_morgan
      I have a series of files that follow the naming convention shown below.
      RED = Date and is always 6 digits
      BLUE = This string is a product code which can contain up to 3 letters followed by up to 6 digits, separated by an underscore
      What is the best way to extract what is in blue and write this to the Title field in IPTC?
      032917_R_1234_Description.tif
      Thank you,
      Morgan
        • 1. Re: Extract part of filename and write to "Title" field in IPTC
          SuperMerlin Level 5
          Try this for selected documents...
          #target bridge
             if( BridgeTalk.appName == "bridge" ) {
          addTitle= MenuElement.create("command", "Add Title", "at the end of Tools");
          addTitle.onSelect  = function () {
          var thumbs = app.document.selections;
          if (ExternalObject.AdobeXMPScript == undefined)  ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript");
          for(var a =0;a<thumbs.length;a++){
          var selectedFile =  new Thumbnail(thumbs[a]);
          Title=decodeURI(selectedFile.spec.name).split("_");
          if(Title.length <3) continue;
          newTitle =(Title[1] +"_"+Title[2]);
          app.synchronousMode = true;
          var xmp = new XMPMeta(selectedFile.synchronousMetadata.serialize());
          xmp.setLocalizedText( XMPConst.NS_DC, "title", null, "en-US", newTitle);
          var newPacket = xmp.serialize(XMPConst.SERIALIZE_USE_COMPACT_FORMAT);
          selectedFile.metadata = new Metadata(newPacket);
          ExternalObject.AdobeXMPScript.unload();
          ExternalObject.AdobeXMPScript = undefined;
          1 person found this helpful
          • 2. Re: Extract part of filename and write to "Title" field in IPTC
            Stephen_A_Marsh Adobe Community Professional
            I like these questions as they are a good way for me to practice regular expressions and ExifTool commands etc.
            Here is an ExifTool solution that uses a regular expression based search/replace to write the required part of the filename to the title metadata. Note that any content that already exists in the title field will be replaced:
            exiftool -r '-title<${filename;s/(^\d+?_)(.+?_\d+?)(_.+)/$2/}' '/path/to file/or main top level folder/here'
            This command is from the Mac OS, for Win OS simply change the straight single ' quotes to straight double " quotes if the path to the top level folder has a word space in it. Further commands can be added to only process specific file formats and or to ignore specific folders under the main top level folder. Further commands can be added to overwrite the original files rather than making a backup _original duplicate copy.
            • 3. Re: Extract part of filename and write to "Title" field in IPTC
              Here is a Bridge script that I modifed to use the same regular expression capture group find/replace as used in the previous ExifTool example. I personally find it easier to work with regular expressions to modify a script, as I am only a beginner with JavaScript/ExtendScript so the methods used by SuperMerlin are not as clear to me as RegEx. Note that any content that already exists in the title field will be replaced:
              // https://imagesimple.wordpress.com/2011/08/24/cs5-filename-to-title-script/
              // https://forums.adobe.com/thread/2455681
              // Input filename: 032917_R_1234_Description.tif
              // Output Title metadata: R_1234
              #target bridge
              FT = MenuElement.create("command", "Add Specific Filename RegEx Pattern to Title", "at the end of Tools");
              FT.onSelect = function () {
                AddFilenameToTitle();
              function AddFilenameToTitle(){
              if(!thumbs.length) return;
              for(var a in thumbs){
              var selectedFile = thumbs[a].spec;
              var Title = decodeURI(selectedFile.name).replace(/(^\d+?_)(.+?_\d+?)(_.+)/,'$2')
                    var myXmpFile = new XMPFile( selectedFile.fsName, XMPConst.UNKNOWN,
              XMPConst.OPEN_FOR_UPDATE);
                var myXmp = myXmpFile.getXMP();
                      myXmp.deleteProperty(XMPConst.NS_DC, "title");
                      myXmp.appendArrayItem(XMPConst.NS_DC, "title", Title, 0,
              XMPConst.ALIAS_TO_ALT_TEXT);
                      myXmp.setQualifier(XMPConst.NS_DC, "title[1]",
              "http://www.w3.org/XML/1998/namespace", "lang", "x-default");
                      if (myXmpFile.canPutXMP(myXmp)) {
                      myXmpFile.putXMP(myXmp);
                      myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY);
              Prepression: Downloading and Installing Adobe Scripts
              • 4. Re: Extract part of filename and write to "Title" field in IPTC
                opn_morgan Level 1
                Hi Stephen,
                Thank you so much for your quick response and solution! It worked!!!!
                I am not a programmer of any kind but spend a lot of time looking at how I can leverage existing data for DAM solutions.
                Thanks again,
                Morgan
                • 5. Re: Extract part of filename and write to "Title" field in IPTC
                  Hi Morgan, thank you for the reply and for providing me with an opportunity to practice and learn.
                  • 6. Re: Extract part of filename and write to "Title" field in IPTC
                    opn_morgan Level 1
                    Hi Stephen,
                    You might already know of this site but I tried using this to try and understand regex syntax.
                    https://regex101.com/
                    Morgan
                    • 7. Re: Extract part of filename and write to "Title" field in IPTC
                      Hi Morgan, yes, that is one of my main “go to” sites!
                      I also like:
                      RegExr: Learn, Build, & Test RegEx
                      Regex Tester and Debugger Online - Javascript, PCRE, PHP
                      As you may know, there are multiple valid regular expressions that lead to the same result, some more concise/verbose than others and some more robust than others.
