I have a document PDF 44MB unable to convert to powerpoint. error message: too large or too complex. I bought the acrobat pack to do this conversion and now unable to use it. Can the PDF be altered to into segments for conversion. Please help.
Hello Jamesb,
As per the description above, you are not able to convert a 44 MB PDF file to powerpoint as getting a message of the size of complexity, Is that correct?
With the exception of Adobe Send, the Acrobat.com online services allow you to upload and convert files that are up to 100 MB.
However, it depends on the complexity of the document you're converting (number of pages, content) affect how large a file you can convert.
So, even files that are under the 100 MB file-size limit may not conv
...Copy link to clipboard
Hello Jamesb,
So, even files that are under the 100 MB file-size limit may not convert if they are overly complex. You can refer to File size limitations
In order to reduce the file size, please refer to the following KB and refer to the answer marked as correct in the following KB How to reduce the size of PDF Link: https://forums.adobe.com/thread/2219009
You may also refer to Optimizing PDFs in Adobe Acrobat Pro
Feel free to update this discussion for any further assistance.
Anand Sri.
