Below is information from the workstation that does not seem
to be compiling correctly. I registered the .dll, but the "search"
still did not function (did a compile of the project need to occur
after the re-registration?). I will be getting the result from the
workstation that is compiling properly shortly and will post the
result.
General Info
Report EXE: c:\temp\MJsDiag.exe
Report Run Date: 1/20/2009 1:29:06 PM
Report EXE Version: 2.7.2.0
Download URL:
http://helpware.net/downloads/
Operating System: Windows NT 5.1.2600
SysLocale.DefaultLCID: 0x0409 (1033)
SysLocale.PriLangID: 0x0009 (9)
SysLocale.SubLangID: 0x0001 (1)
DecimalSeparator: .
HH Installed: YES
HH Version: 5.2.3790.2847
HH Friendly Version: > 1.4a
H2 Installed: NO
H2 Version:
IE Installed: YES
IE Version: 6.0.2900.3462
IE Friendly Version: Internet Explorer 6 (Windows XP SP2)
NT Administrator
NT Admin Check: Current user has full administor privileges:
YES
HTML Help Run-time Components
File Registered OK: C:\WINDOWS\system32\hhctrl.ocx (Version:
5.2.3790.2847)
File Registered OK: C:\WINDOWS\system32\itss.dll (Version:
5.2.3790.2453)
File Registered OK: C:\WINDOWS\system32\itircl.dll (Version:
5.2.3790.2453)
File Found: C:\WINDOWS\system32\hhctrl.ocx
Version = 5.2.3790.2847
Registry Info: {adb880a6-d8ff-11cf-9377-00aa003b7a11}
ClassName = HHCtrl Object
InProcServer32 = C:\WINDOWS\system32\hhctrl.ocx
ProgID = Internet.HHCtrl.1
DLL is Found and Registered OK = YES
File Found: C:\WINDOWS\system32\itss.dll
Version = 5.2.3790.2453
Registry Info: {5D02926A-212E-11D0-9DF9-00A0C922E6EC}
ClassName = Microsoft InfoTech IStorage System
InProcServer32 = C:\WINDOWS\system32\itss.dll
ProgID = MSITFS1.0
File Found: C:\WINDOWS\system32\itircl.dll
Registry Info: {4662DAA5-D393-11D0-9A56-00C04FB68BF7}
ClassName =
InProcServer32 = C:\WINDOWS\system32\itircl.dll
ProgID = ITIR.WordWheelBuild.4
For HH Version Info See:
http://helpware.net/htmlhelp/hh_info.htm
HTML Help 1.x Registry Settings
Description: If present this Key can disable HH Shortcuts and
HH WinHelp commands on the local PC
Reference: KB 810687, KB 323180
Key:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\System\
Value: HelpQualifiedRootDir (string value) =
-> Report: Policy is not enabled. HH Shortcuts are not
restricted on local machine.
Description: This key can be used to enable Hhctrl.ocx
ActiveX Visual controls on servers
Reference: KB 892675
Key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\HHRestrictions
Value: UrlAllowList (string value) =
Value: MaxAllowedZone (string value) = 3
-> Report: Settings reported for information only.
Description: This key allows MS programs such as iexplore.exe
to open ITS file that do not have a .CHM file extension
Reference: KB 873343
Key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\HelpRestrictions\AllowedExtensions
-> Report: No special file extensions have been enabled
on this PC.
Description: This key can be used to allow access to remote
ITS files
Reference: Win 2003 SP1, KB 896054
Key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions
Value: NestedProtocolList (string value) =
For HH Registry Info See:
http://helpware.net/htmlhelp/hh_info.htm#hh14
HTML Help 1.x Workshop Components
*** HH Workshop not found or not installed correctly. Try
reinstalling.
File not found: C:\Program Files\itcc.dll
File Found: C:\WINDOWS\system32\hha.dll (Version:
4.74.8702.0)
KeyHelp OCX by Keyworks.net - KeyHelp.ocx
This is for information only. KeyHelp is a 3rd party DLL.
*** KeyHelp.ocx is not registered or not installed!
*** You can register your KeyHelp.ocx using the "Register a
DLL" button.
*** KeyHelp.ocx could be installed anywhere on your PC by
normally resides in the Windows System folder.
For More Info See:
http://keyworks.net/
RoboHelp DLL by eHelp/Macromedia - HHActiveX.dll
This is for information only. HHActiveX is a 3rd party DLL.
*** HHActiveX.dll is not registered or not installed!
*** You can register your HHActiveX.dll using the "Register
DLL..." button.
*** HHActiveX.dll could be installed anywhere on your PC.
For More Info See:
http://www.macromedia.com/
MS Help 2 Run-time Components
*** MS Help 2 NOT installed on this PC
