Batch replace smart objects in mockup file
Feb 10, 2018 Feb 10, 2018
Hi there,
I want to know if it's possible to import x-number of png images into a mockup template with a smart object and then all saved in jpgs? The following script is not working for me but it's probably close to what I need:
The script must do the following:
Search in folder for PNG files
Place the PNG image into the Smart Object (top center)
Save file as JPG into the source folder with the same name as the source file
For example:
Before the script
After the script
I hope this makes sense. I will appreciate if someone can give me an advise what is the best way to do that.
Kind regards,
Katt
Actions and scripting
13.9K
Adobe
My script would save Populated template as PSD you can adjust populated images and save out a PNG.  You need to take care when you want to place is png image the transparent borders around an item.   Place and Paste will most likely trim transparent borders to the subject item bounds.  To prevent that when I create the PNG file a put a 1% opaque pixel in the top left and bottom right corners of the documents canvas.  You will never see these pixels amt the will be not transparent borders the Photoshop will trim. If you do not have me scripts search for Photo Collage toolkit https://forums.adobe.com/search.jspa?q=Photo+Collage+toolkit
My scripts will not filter for PNG they will place in any type of image file from a source image folder.  It would be easy to change the extension list to be png only.
To place in images in a particular groups in  order requires you to rename the files with a sort order prefix  which will not be included if you use file nams stamping on placed images.
My Batch Scripts will save PSD files and optionally also save a additional JPG version.  The one image batch script will name save  files with a name that reflects the template and image name.   The Batch multi image script  save files with the a name that reflect the template name a suffix number.  The number is update 1 after a populated template is saved its a count of populated templates.    Many of my scripts do not save a file instead the populated template copy will remain open in Photoshop layered to allow you the tweak the populated template and save out the files you want with the names you want.
JJMack
Feb 11, 2018 Feb 11, 2018
// place png files in selected smart object and save jpg;
// 2018, use it at your own risk;
#target photoshop
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
var basename = myDocument.name.match(/(.*)\.[^\.]+$/)[1];
//var thePath = myDocument.path;
var theLayer = myDocument.activeLayer;
// jpg options
var jpgopts = new JPEGSaveOptions();
jpgopts.embedProfile = true;
jpgopts.formatOptions = FormatOptions.STANDARDBASELINE;
jpgopts.matte = MatteType.NONE;
jpgopts.quality = 10;
// check if layer is smart object;
if (theLayer.kind != "LayerKind.SMARTOBJECT") {alert ("selected layer is not a smart object")}
else {
// select files;
var theFolder = Folder.selectDialog ("select folder");
var theFiles = retrievePngFiles (theFolder, []);
if (theFiles) {
// work through the array;
for (var m = 0; m < theFiles.length; m++) {
var thePath = File(theFiles).path;
// open smart object;
var smartObject = openSmartObject (theLayer);
var theLayer2 = smartObject.activeLayer;
// place file and fit to convas;
var theNewOne = placeScaleRotateFile (theFiles, 0, 0, 100, 100, 0);
scaleLayerToFitCanvas ();
hideOthers ();
// close;
smartObject.close(SaveOptions.SAVECHANGES);
//save jpg;
myDocument.saveAs((new File(thePath+"/"+theFiles.name.match(/(.*)\.[^\.]+$/)[1]+"_"+basename+".jpg")),jpgopts,true);
// undo;
myDocument.activeHistoryState = myDocument.historyStates[myDocument.historyStates.length - 1];
////// get ong from subfolders //////
function retrievePngFiles (theFolder, theFiles) {
  if (!theFiles) {var theFiles = []};
  var theContent = theFolder.getFiles();
  for (var n = 0; n < theContent.length; n++) {
  var theObject = theContent;
  if (theObject.constructor.name == "Folder") {
  theFiles = retrievePngFiles(theObject, theFiles)
  if (theObject.name.slice(-4).match(/\.(png)$/i) ) {
  theFiles.push(theObject)
  return theFiles
////// place //////
function placeScaleRotateFile (file, xOffset, yOffset, theXScale, theYScale, theAngle) {
var idPlc = charIDToTypeID( "Plc " );
    var desc5 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
    desc5.putPath( idnull, new File( file ) );
    var idFTcs = charIDToTypeID( "FTcs" );
    var idQCSt = charIDToTypeID( "QCSt" );
    var idQcsa = charIDToTypeID( "Qcsa" );
    desc5.putEnumerated( idFTcs, idQCSt, idQcsa );
    var idOfst = charIDToTypeID( "Ofst" );
        var desc6 = new ActionDescriptor();
        var idHrzn = charIDToTypeID( "Hrzn" );
        var idPxl = charIDToTypeID( "#Pxl" );
        desc6.putUnitDouble( idHrzn, idPxl, xOffset );
        var idVrtc = charIDToTypeID( "Vrtc" );
        desc6.putUnitDouble( idVrtc, idPxl, yOffset );
    desc5.putObject( idOfst, idOfst, desc6 );
    var idWdth = charIDToTypeID( "Wdth" );
    var idPrc = charIDToTypeID( "#Prc" );
    desc5.putUnitDouble( idWdth, idPrc, theYScale );
    var idHght = charIDToTypeID( "Hght" );
    desc5.putUnitDouble( idHght, idPrc, theXScale );
    var idAngl = charIDToTypeID( "Angl" );
    var idAng = charIDToTypeID( "#Ang" );
    desc5.putUnitDouble( idAngl, idAng,theAngle );
    var idLnkd = charIDToTypeID( "Lnkd" );
    desc5.putBoolean( idLnkd, true );
executeAction( idPlc, desc5, DialogModes.NO );
return app.activeDocument.activeLayer;
////// scale layer to fit canvas //////
function scaleLayerToFitCanvas () {
var ref = new ActionReference();
ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("bounds"));
ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
var layerDesc = executeActionGet(ref);
var theBounds = layerDesc.getObjectValue(stringIDToTypeID("bounds"));
var layerX = theBounds.getUnitDoubleValue(stringIDToTypeID("left"));
var layerY = theBounds.getUnitDoubleValue(stringIDToTypeID("top"));
var layerWidth = theBounds.getUnitDoubleValue(stringIDToTypeID("right"))-layerX;
var layerHeight = theBounds.getUnitDoubleValue(stringIDToTypeID("bottom"))-layerY;
var ref1 = new ActionReference();
ref1.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
var docDesc = executeActionGet(ref1);
var docWidth = docDesc.getUnitDoubleValue(stringIDToTypeID("width"));
var docHeight = docDesc.getUnitDoubleValue(stringIDToTypeID("height"));
var docRes = docDesc.getInteger(stringIDToTypeID("resolution"));
var scaleX = docWidth/layerWidth*docRes/72*100;
var scaleY = docHeight/layerHeight*docRes/72*100;
var theScale = Math.min(scaleX, scaleY);
layerX = ((docWidth*docRes/144) - (layerX+layerWidth/2));
layerY = ((docHeight*docRes/144) - (layerY+layerHeight/2));
var idTrnf = charIDToTypeID( "Trnf" );
    var desc24 = new ActionDescriptor();
//    desc24.putEnumerated( charIDToTypeID( "FTcs" ), charIDToTypeID( "QCSt" ), charIDToTypeID( "Qcs0" ) );
    desc24.putEnumerated( charIDToTypeID( "FTcs" ), charIDToTypeID( "QCSt" ), charIDToTypeID( "Qcsa" ) );
        var desc25 = new ActionDescriptor();
        desc25.putUnitDouble( idHrzn, idPxl, layerX);
        desc25.putUnitDouble( idVrtc, idPxl, layerY);
    desc24.putObject( idOfst, idOfst, desc25 );
    desc24.putUnitDouble( idWdth, idPrc, theScale );
    desc24.putUnitDouble( idHght, idPrc, theScale );
executeAction( idTrnf, desc24, DialogModes.NO );
////// open smart object //////
function openSmartObject (theLayer) {
if (theLayer.kind == "LayerKind.SMARTOBJECT") {
var idplacedLayerEditContents = stringIDToTypeID( "placedLayerEditContents" );
    var desc2 = new ActionDescriptor();
executeAction( idplacedLayerEditContents, desc2, DialogModes.NO );
////// hide others //////
function hideOthers () {
// hide others;
var idShw = charIDToTypeID( "Shw " );
        var list1 = new ActionList();
            var idLyr = charIDToTypeID( "Lyr " );
            var idOrdn = charIDToTypeID( "Ordn" );
            var idTrgt = charIDToTypeID( "Trgt" );
            ref1.putEnumerated( idLyr, idOrdn, idTrgt );
        list1.putReference( ref1 );
    desc2.putList( idnull, list1 );
    var idTglO = charIDToTypeID( "TglO" );
    desc2.putBoolean( idTglO, true );
executeAction( idShw, desc2, DialogModes.NO );
Question I see that your script does not replace the current Smart object layer content instead it update the layers  object  opens and edits the object.  It places in the png  and scaled it to fit the object canvas and hides the other content in the object.
hideOthers ();
// close;
I think there may be some problems there.  I have never tried to update a smart object layer because of what I though might happen.  If the png image has a transparent borders I think place may trim these.  Additionally the png's file aspect ratio may be different than the work document canvas's aspect ratio so when the place layer is fitted for the canvas size there may be a border because of the aspect ratio mismatch.  Then there is this if the  template's current smart object was a Placed file it may be a raw file or ai file the object may open in ACR or Illustrator not Photoshop.  Are my concerns ill founded?
JJMack
The current SO is square, so Replace Contents to some file with another aspect Ratio might cause more issues with the Warp for example.
The Script places the png in the SO and scales to fit according to its longest side.
This seems to make the most sense to me considering that I don’t know if all designs will have the same aspect ratio.
Aug 16, 2020 Aug 16, 2020
Hi, I found your comment when i was searching for the solution of this problem.
I tried your script, but this error occured.
The smart object was selected when i ran this script, and i choosen the folder of PNGs file.
Could you please help me?
Thank you very much
Feb 12, 2018 Feb 12, 2018
The script works fine for me but I have one issue here - I need the png placed in the top center of the Smart Object, so if the image is shorter it will be still on top.Untitled-8.jpg
You can either include an additional Alignment step in the Script or try to change the line
to provide the result you want to achieve.
To be honest I have no idea how to do it. I don't know anything about scripting
Do your PNG files have transparent border?
Are all your PNG files the same size and resolution as the object in your mockup?
If your PNG has transparent borders these may be trimmed during place the smart object layer object size may not be the size of the PNG file canvas.
If your png files do not have the same aspect ratio as your mockup object when they are resize to fit the mockup object canvas size a border or two most like will be introduced.  The resize to fit must be a constrained resize otherwise the image will distort.
If the png contains text if the png files is not the same size as the mockup object the resize text may not be acceptable.
It there is no transparent borders in your png files and all the png are the same size as the mockup object and the object type is associated with Photoshop I think the script will work for you,
JJMack
If you want to use Scripts you should familiarise yourself with Scripting basics.
You can insert this line but you should figure out where yourself:
activeDocument.activeLayer.translate(0, activeDocument.activeLayer.bounds[1] * (-1))
Feb 16, 2018 Feb 16, 2018
Thank you for your help regarding this script. I placed the lane and it works fine but a got an error on one of the mockups. I guess it is the problem with the file. I will do more tests with different mockups. Thanks again
If you need help trouble-shooting that issue please state the exact error message and provide the file.
Is a Smart Object selected when you run the Script?
Yes, it is. This error appears after the first image is placed onto the mockup.
The message state that »Edit Contents« cannot be run, most likely because the selected Layer is not a Smart Object.
Please post a screenshot at error-time including the Layers Panel.
You are right! For some reason it moves the selection to the layer under the SO. When I run the script if it's not selected the SO the script replies that the selected layer is not SO, therefore I can't run the script if it's on any other layer. Weird!
That does not seem to make sense as the Script includes no step to change the selected Layer in the containing document.
You could reselect the originally selected Layer with
myDocument.activeLayer = theLayer;
Please provide the image and the code you use at current.
Feb 19, 2018 Feb 19, 2018
I think I figured the issue out – setting back the HistoryState can result in changing the Layer selection.
Inserting
after the HistoryState-line should address that.
Feb 20, 2018 Feb 20, 2018
I found that I must save the psd with the SO selected, otherwise the script resets the file and then the selected layer may be different, that's why I got the error. Tried several times with different mockups and it works great. Thanks again for your cooperation regarding this script
If that is workable for you so much the better.
Good to read it worked out for you.
The only "problem" I've got now is with the saved name because it contains both the PNG and the Mockup names. I tried to modify the line //save jpg; few times but I've got different results and not the one I want. The jpg file must take the mockup name only. Would you be able to help with this as I've got everything else but not this? Thanks
Without testing I guess you would have to change
myDocument.saveAs((new File(thePath+"/"+theFiles.name.match(/(.*)\.[^\.]+$/)[1]+"_"+basename+".jpg")),jpgopts ,true);
to
myDocument.saveAs((new File(thePath+"/"+theFiles.name.match(/(.*)\.[^\.]+$/)[1]+".jpg")),jpgopts ,true);
