APP terminates in iOS 11 when moved into background - no issues on iOS 10.3.3 and lower
dews Sep 25, 2017 3:01 AMWhilst debugging, I normally kill the APP manually - so I completely missed this new occurrence in iOS 11..
Within just a few seconds of being moved into the background, for example when the user clicks the Home Button - the APP is now being killed by iOS.
We've set background execution:
NativeApplication.nativeApplication.executeInBackground = true;
We are implementing the obligatory deactivate listener which calls:
this.stage.quality = StageQuality.LOW;
Starling.current.stop(true);
In the app.xml we have:
<key>UIBackgroundModes</key>
<array>
<string>remote-notification</string>
<string>fetch</string>
</array>
<key>UIRequiresPersistentWiFi</key>
<array>
string>YES</string>
</array>
iOS 10.3.3 and earlier this is not happening..
Odd thing is, I'm not seeing any Crash Logs being written? In the Console just before the APP is terminated I'm seeing the following - it appears to move into the background - and then exits voluntarily?
Any help much appreciated.
SpringBoard default 02:26:15.029377 -0700 SpringBoard Application process state changed for com.testing.app: <SBApplicationProcessState: 0x1c5423fe0; pid: 1601; taskState: Running; visibility: Background>
WiFiPicker default 02:26:15.132320 -0700 SpringBoard WIFI PICKER [com.testing.app]: isProcessLaunch: 0, isForegroundActivation: 0, isForegroundDeactivation: 1
CoreMedia default 02:26:15.132418 -0700 mediaserverd -CMSessionMgr- CMSessionMgrHandleApplicationStateChange: CMSession: Client com.testing.app with pid '1601' is now Background Running. Background entitlement: NO
SymptomEvaluator default 02:26:15.134983 -0700 symptomsd 1601 com.testing.app: BackgroundRunning (most elevated: BackgroundRunning)
SymptomEvaluator default 02:26:15.135115 -0700 symptomsd Entry, display name com.testing.app uuid 539F2752-06B3-3E36-BAB6-FADD517C6003 pid 1601 isFront 0
SymptomEvaluator default 02:26:15.135274 -0700 symptomsd Continue with bundle name com.testing.app, is front 0
SymptomEvaluator default 02:26:15.135380 -0700 symptomsd com.testing.app: Foreground: false
assertiond default 02:26:15.153614 -0700 assertiond [APP:1601] dump all assertions HWM:7 (deactivateAssertion): {
<BKProcessAssertion: 0x133f15de0; "FBSceneSnapshotAction:com.testing.app" (finishTask:180s); id:…C415CBDF7A65> [active]
<BKProcessAssertion: 0x133d279a0; "_UIRemoteKeyboard XPC disconnection" (finishTask:180s); id:…01ED14707EBD> [active]
<BKProcessAssertion: 0x133d4bfe0; "snapshot-task" (finishTask:180s); id:…9D6F567601C0> [active]
<BKProcessAssertion: 0x133e385d0; "Suspending" (suspend:10s); id:…B42D19D850CD> [active]
assertiond default 02:26:15.153705 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.155210 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.156675 -0700 assertiond [APP:1601] dump all assertions HWM:7 (deactivateAssertion): {
assertiond default 02:26:15.157056 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.157726 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.158503 -0700 assertiond [APP:1601] dump all assertions HWM:7 (deactivateAssertion): {
assertiond default 02:26:15.158873 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.159505 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.161390 -0700 assertiond Server invalidated <BKProcessAssertion: 0x133f15de0; "FBSceneSnapshotAction:com.testing.app" (finishTask:180s); id:…C415CBDF7A65>
assertiond default 02:26:15.161851 -0700 assertiond Process exited: <BKProcess: 0x133e136c0; APP; com.testing.app; pid: 1601; agency: Application; visibility: background; task: none; hostpid: 364>
assertiond default 02:26:15.162364 -0700 assertiond Client relinquished <BKProcessAssertion: 0x133f15de0; "FBSceneSnapshotAction:com.testing.app" (finishTask:180s); id:…C415CBDF7A65>
assertiond default 02:26:15.163203 -0700 assertiond [APP:1601] dump all assertions HWM:7 (CPUMON check): {
assertiond default 02:26:15.275851 -0700 assertiond Deleted job with label: UIKitApplication:com.testing.app[0x744a][73]
assertiond default 02:26:15.276065 -0700 assertiond [APP:1601] Deleted launchd job with label: UIKitApplication:com.testing.app[0x744a][73]
assertiond default 02:26:15.276488 -0700 assertiond Checking for deferred bootstrap request for com.testing.app
FrontBoard default 02:26:15.276676 -0700 SpringBoard <FBApplicationProcess: 0x110386740; APP (com.testing.app); pid: 1601> exited voluntarily.
FrontBoard default 02:26:15.277535 -0700 SpringBoard [FBProcessManager] Removing: <FBApplicationProcess: 0x110386740; APP (com.testing.app); pid: 1601>
SpringBoard default 02:26:15.277608 -0700 SpringBoard Process exited: <FBApplicationProcess: 0x110386740; APP (com.testing.app); pid: -1> -> <FBApplicationProcessExitContext: 0x1c522fd60; exitReason: voluntary; terminationReason: (none)>
WiFiPicker default 02:26:15.277724 -0700 SpringBoard WIFI PICKER [com.testing.app]: isProcessLaunch: 0, isForegroundActivation: 0, isForegroundDeactivation: 0
SpringBoard default 02:26:15.278008 -0700 SpringBoard Application process state changed for com.testing.app: (null)
CoreMedia default 02:26:15.278211 -0700 mediaserverd -CMSessionMgr- CMSessionMgrHandleApplicationStateChange: CMSession: Client com.testing.app with pid '1601' is now Terminated. Background entitlement: NO
SymptomEvaluator default 02:26:15.278609 -0700 symptomsd 1601 com.testing.app: Terminated (most elevated: Terminated)
SymptomEvaluator default 02:26:15.278960 -0700 symptomsd Entry, display name com.testing.app uuid (null) pid 1601 isFront 0
