Hi
The last couple of days, Lightroom CC Classic stops working after a few operations. It doesn't freeze totally, I can still leaf trough pictures, change views and such, but it is impossible to flag photos as rejects, sync with CC, i.e. actually doing something useful. There are no error messages or other indications, it just stops working. After I restart the program, it works fine for a few more operations and then it stops working again. A few operations mean I can go trough less than 10 photos (often far less) before I have to restart LR. After restart, it does not start with the photo I was on when the program stopped working, but with the last one I was working on when doing a normal shutdown of LR. The few operations I get to do are saved, so I'm not missing any work, but it's a pain having to restart LR every couple of minutes as I have a few thousand photos to go trough after a recent trip...
What I have done so far (and other info):
Does anyone have a good tip on what I can do to fix the problem?
Regards
Roger
Make sure that you have turned off
Don't just say that you know these are not in use; sometimes these things get turned on accidentally, so you need to confirm that they have been turned off
Thank you!
Facial recognition was off, as well as address lookup from GPS, but not the sync. I didn't know that this function could cause such problems. I've done some testing now, and it seems to do the trick!
Roger
