Show 13 replies
1. Re: Undefined errors on live site
Newsgroup_User Jan 20, 2009 6:18 PM (in response to Stuart Haiz)Your page is referring to variables that have not yet received a value -
$Department on line 3
$maxprice on line 11
and so on. Finding a snippet of code is not the solution. Fixing the use
of the variables before they have been given a value is the solution. Can
we see your code?
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"Sirius7" <webforumsuser@macromedia.com> wrote in message
news:gl5tmo$mg$1@forums.macromedia.com...
>I developed a site on my server here:
> http://www.designermagic.co.uk/hobarts/index.php & everything worked as
> planned. As soon as I uploaded to the client's site, (
> http://www.hobarts.co.uk) the top of the page was filled with errors like
> this:
> Notice: Undefined index: Department in
> E:\domains\h\hobarts.co.uk\user\htdocs\index.php on line 3
> Notice: Undefined index: maxprice in
> E:\domains\h\hobarts.co.uk\user\htdocs\index.php on line 11
> I did a Google search & found some code that fixed this issue, but I'm not
> the
> developer & don't know what it means. The code:
> $ebits = ini_get('error_reporting');
> error_reporting($ebits ^ E_NOTICE);
> seems to have disabled error messages so I can't find out why the Quick
> Search
> is not working on this site. Again, it works in my test site at my domain.
> (The
> Quick Search posts to a results page with an iframe.) Either the php is
> not
> being sent or there is another issue which I really can't solve without
> help
> please!
2. Re: Undefined errors on live site
Stuart Haiz Jan 21, 2009 12:47 AM (in response to Stuart Haiz)Hi Murray
Thanks. I realise the sense in what you are saying! Here's some of my code from the top of the file (minus the code 'fix').
<?php
/* RENT OPTION */
if($_GET['Department'] == 3){
$_GET['minprice'] = '';
$_GET['maxprice'] = '';
/* The Options Strings for prices */
$rent_minprice = '<label for="PriceMin">Price Min:<select name="minprice" id="MinPrice"><option value=""></option></select></label>';
/*Rent is disabled if selected so no value assigned - for use on results.php*/
$rent_maxprice = '<label for="PriceMax">Price Max:<select name="maxprice" id="MaxPrice"><option value="150" ' . (($_GET['maxprice'] == 150)?'selected':'') . '>£150pw</option><option value="250" ' . (($_GET['maxprice'] == 250)?'selected':'') . '>£250pw</option><option value="350" ' . (($_GET['maxprice'] == 350)?'selected':'') . '>£350pw</option><option value="450" ' . (($_GET['maxprice'] == 450)?'selected':'') . '>£450pw</option><option value="550" ' . (($_GET['maxprice'] == 550)?'selected':'') . '>£550pw</option><option value="">No Maximum</option></select></label>';
Then I have variables for $buy_minprice & $buy_maxprice.
The url for the iframe on the results page once the form is posted is:
" http://powering.expertagent.co.uk/customsearch.aspx?aid={f7863a23-aa92-45ed-aef6-b5cc6ac33 4c7}&showsearchfirst=false&dep=<?php echo $_GET['Department'];?>&minbeds=<?php echo $_GET['bedrooms'];?>&minprice=<?php echo $_GET['minprice'];?>&maxprice=<?php echo $_GET['maxprice'];?>&districts=<?php echo $_GET['districts'];?>®ions=583358345835¤cycode=GBP&sort=Desc&areas=<?php echo implode(',', $_GET['areas']);?>&types=<?php echo $_GET['types'];?>&commercialtypes=<?php echo $_GET['commercialtypes'];?>"
Thanks in advance. -
3. Re: Undefined errors on live site
Stuart Haiz Jan 21, 2009 4:30 AM (in response to Stuart Haiz)Hi Murray
This has been fixed now. It was solved with a .htaccess file to turn off error reporting on the live server. (Site is on shared hosting with errors on & no control over php.ini, so also going to be moving to new web host!)
Thanks for the advice. -
4. Re: Undefined errors on live site
Newsgroup_User Jan 21, 2009 4:39 AM (in response to Stuart Haiz)So, you solved it with a sledgehammer, not a finishing hammer? 8)
You could have just initialized all those variables at the top of the page
with -
$variable1 = $variable2 = $variable3 = '';
and that would do the trick....
news:gl74gf$fa3$1@forums.macromedia.com...
> Hi Murray
> error
> no
5. Re: Undefined errors on live site
Newsgroup_User Jan 21, 2009 4:44 AM (in response to Stuart Haiz).oO(Sirius7)
This doesn't solve the problem. Your script still has bugs.
Ignoring notices can lead to real problems - from nasty and hard-to-find
bugs to really big security holes. You definitely want to fix the issues
instead of just turning of the warnings.
Micha -
6. Re: Undefined errors on live site
Stuart Haiz Jan 21, 2009 5:22 AM (in response to Stuart Haiz)A web.config file has also been added to switch off custom errors.
Murray, $rent_minprice = $rent_maxprice = $buy_minprice = $buy_maxprice = ''; didn't solve the undefined index problem. Messages reappeared when I tried this. Seems the sledgehammer is my most understood tool at this stage...
Micha - I agree with the comment that you can't put your head in the sand. I'm the designer & am handing this over to a developer who knows what he is doing! -
7. Re: Undefined errors on live site
Newsgroup_User Jan 21, 2009 7:08 AM (in response to Stuart Haiz)> Murray, $rent_minprice = $rent_maxprice = $buy_minprice = $buy_maxprice =
> this.
Do the messages include any of these variable names? As I recall there were
several other variables that would need to be added to this list, like
$Department, and $maxprice. Add them and see what happens.
news:gl77hs$iuc$1@forums.macromedia.com...
> I'm
> doing!
8. Undefined errors on live site
Stuart Haiz Jan 21, 2009 8:28 AM (in response to Stuart Haiz)Correct. Department, minprice & maxprice are all names for my labels. I tried this too, without luck:
$rent_minprice = $rent_maxprice = $buy_minprice = $buy_maxprice = $Department = $minprice = $maxprice = '';
It returned this:
Notice: Undefined index: Department in E:\domains\h\hobarts.co.uk\user\htdocs\HIPs.php on line 6
Notice: Undefined index: maxprice in E:\domains\h\hobarts.co.uk\user\htdocs\HIPs.php on line 13
(plus a few more variants including the minprice.)
At the top of my code I have this, causing the messages:
This is followed by my variables like this:
$buy_minprice = '<label for="PriceMin">Price Min:<select name="minprice" id="MinPrice"><option ' . ( ($_GET['minprice'] == 0)?'selected':'') . ' value="0">No Minimum</option><option ' . ( ($_GET['minprice'] == 150000)?'selected':'') . ' value="150000">£150,000</option><option ' . ( ($_GET['minprice'] == 250000)?'selected':'') . ' value="250000">£250,000</option><option ' . ( ($_GET['minprice'] == 350000)?'selected':'') . ' value="350000">£350,000</option><option ' . ( ($_GET['minprice'] == 500000)?'selected':'') . ' value="500000">£500,000</option><option ' . ( ($_GET['minprice'] == 750000)?'selected':'') . ' value="750000">£750,000</option></select></label>';
Thanks Murray for your time looking at this. -
9. Re: Undefined errors on live site
Newsgroup_User Jan 21, 2009 8:30 AM (in response to Stuart Haiz).oO(Murray *ACE*)
>> this.
Shouldn't change anything, because the error message refers to undefined
array indexes, not variables. For example this line
will throw a notice if no such URL parameter was passed to the site. The
solution is to first check with isset() to see if the parameter exists,
e.g.
if (isset($_GET['Department']) && $_GET['Department'] == 3) {
Micha -
10. Re: Undefined errors on live site
Stuart Haiz Jan 21, 2009 8:41 AM (in response to Stuart Haiz)Micha
This clears the first message about the department, so I get the maxprice & minprice messages on their own now:
Notice: Undefined index: maxprice in E:\domains\h\hobarts.co.uk\user\htdocs\HIPs.php on line 13 -
11. Re: Undefined errors on live site
Newsgroup_User Jan 21, 2009 8:57 AM (in response to Stuart Haiz).oO(Sirius7)
>Micha
Same thing, same problem, same solution. Before accessing these
parameters use isset() to see if they exists. If not, use some default
value.
Additionally you should _not_ write to the $_GET array, but consider it
read-only. This means that you should check and load all URL parameters
you need into local variables. This also allows to easily define default
values if some parameter is missing, e.g.
$minPrice = isset($_GET['minprice']) ? $_GET['minprice'] : 0;
(This is short syntax for an if-then-else statement, called ternary
operator.)
This will always give you a defined value for the $minPrice variable
(either the user-submitted value or your own default) which you can
reliably work with. Same for max price and other parameters.
Micha -
12. Re: Undefined errors on live site
Stuart Haiz Jan 21, 2009 9:13 AM (in response to Stuart Haiz)Micha
Thank you for your help with this - & also for helping me to learn some important stuff here too. I'm going to try this on a test page this evening when I get home & hopefully, post some good news tomorrow.
Thanks again. -
13. Re: Undefined errors on live site
Newsgroup_User Jan 22, 2009 5:03 AM (in response to Stuart Haiz)D'oh. Right string, but wrong yoyo, as they say.
"Michael Fesser" <netizen@gmx.de> wrote in message
news:13gen4h8m04om5udjmisq93luc4tk484dd@4ax.com...
> .oO(Murray *ACE*)
>>> tried
>>> this.
>>were
> e.g.
> Micha
