Hi there,
We have developed a plugin using Angular 2, which uses Typescript packaged by Webpack.
On previous versions of indesign, when opening the chrome devtools, we could see a "webpack" folder, with the original .ts files for debugging.
But since I updated Indesign to 2018, I can only debug the final .js files. The webpack folder is nowhere to be seen.
Does anyone have encountered this? Any workarounds? Ideas?
Thank you very much!
Marc
This doesn't look like a scripting problem, more like an SDK thing. Maybe head over there.
P.
Hi Marc and Peter,
maybe better ask here:
Extensions / Add-ons Development
Or a moderator should move this thread to Extensions / Add-ons Development.
Marc, see into Extensions / Add-ons Development if that'll fit your needs.
The SDK forum is here in case: InDesign SDK
Uwe
I can see the "webpack://" folder under "Sources" in the Chrome DevTools .. If you select the "." Directory you can see all the files, not only the compiled ones (mail, polyfill, styles etc.)
