Trying to do some perspective drawing - using edit->transform->perspective to distort architectural drawings into place. When I do small distortions it seems to work fine, but larger distrortions cause straight diagonal lines to start curving - see attached example:
photoshopDistortionProblems.png - Google Drive
Is there a way to stop that happening? It makes it way harder to do old-fashioned perspective stuff like this ConceptArt.org: Art Forums,​ so much of it involves having diagonal construction lines, and obviously if they're curving it's impossible to figure out what on earth is going on!
Paste the image into the thread. I'm not logging in anywhere just to view an image of unknown origin.
To follow Dag's sage advice, choose this:
haha, sorry - was looking for that, couldn't see it 🙂 thanks
With Google Drive there is no need to log in. It's just a link to an image.
Here it is:
I can reproduce that - try using Perspective warp instead
Dave
He did - see his example on the left.
I can reproduce this as well, and in my mind this is a rather ugly bug. I tried the same transformation in other software, and it transforms correctly in those.
I read that he had used Transform Perspective in both cases. The right image had just transformed further.
Perspective Warp does not seem to suffer this issue
I've raised a bug report here, you may wish to add your own comments :
Photoshop Transform Perspective issue | Photoshop Family Customer Community
Dave
yup, that's correct davescm - they're both using "transform perspective", but when you go beyond a certain point it starts curving. I actually do quite a bit of perspective drawing in photoshop, using that tool a lot, and haven't noticed this before - not sure if that's because it only occurs with extreme distortions or because it's a recent bug/"feature" though 🙂 Thanks for adding the bug, think it probably qualifies as one...
