17 Replies Latest reply on Jun 19, 2018 2:09 PM by Kukurykus
    There isn't enough room to display this document
    KerryAnnSanner Level 1
      Everything was going along fine, I closed out one file and tried to open another when I got this message.   Now I can't open any documents.   What did I do wrong?
        • 1. Re: There isn't enough room to display this document
          JJMack Most Valuable Participant
          Can you identify You OS and photoshop versions and if Windows 10 and CC 2018 19.1.x your Windows Display settings and a screen capture when you get that message.
          • 2. Re: There isn't enough room to display this document
            I’m working on a MAC OS 10.13.12 with Photoshop CC2018.   Attached is the screenshot of the  message.
            • 3. Re: There isn't enough room to display this document
              If you posting via e-mail you can not attach images.   Post from your Mac's web browser.  Some Mac user may have some idea of what is causing your problem.
              • 4. Re: There isn't enough room to display this document
                SG... Adobe Employee
                How are you opening the file? Also, does it make any difference if you turn off the Application Frame (Window> Application Frame w/o checkmark)?
                Can you go to Help> System Info... and copy the text in a reply, please? I have seen reports of this happening on Win OS, but not on macOS yet and we still don't know how to reproduce it in house.
                regards,
                steve
                1 person found this helpful
                • 5. Re: There isn't enough room to display this document
                  Sorry about that, attached is the screenshotScreen Shot 2018-02-20 at 3.40.20 PM.png
                  • 6. Re: There isn't enough room to display this document
                    I've tried to open the files in various ways (file/open...) plus dragging it into the Photoshop icon, etc, and I get the same response.  There isn't an  Application Frame in the Window dropdown menu.
                    Below is System Info:
                    Adobe Photoshop Version: 19.1.0 20180116.r.238 2018/01/16: 1153018  x64
                    Number of Launches: 146
                    Operating System: Mac OS 10.13.2
                    System architecture: Intel CPU Family:6, Model:44, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                    Physical processor count: 12
                    Logical processor count: 24
                    Processor speed: 2400 MHz
                    Built-in memory: 16384 MB
                    Free memory: 10041 MB
                    Memory available to Photoshop: 14893 MB
                    Memory used by Photoshop: 70 %
                    Alias Layers: Disabled.
                    Modifier Palette: Disabled.
                    Highbeam: Enabled.
                    Touch Bar Property Feedback: Enabled.
                    Image tile size: 1024K
                    Image cache levels: 4
                    Font Preview: Medium
                    TextComposer: Latin
                    Display: 1
                    Main Display
                    Display Bounds: top=0, left=0, bottom=720, right=1280
                    OpenGL Drawing: Enabled.
                    OpenGL Allow Old GPUs: Not Detected.
                    OpenGL Drawing Mode: Advanced
                    OpenGL Allow Normal Mode: True.
                    OpenGL Allow Advanced Mode: True.
                    AIFCoreInitialized=1
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=1
                    NumNativeGPUs=0
                    glgpu[0].GLVersion="2.1"
                    glgpu[0].IsIntegratedGLGPU=0
                    glgpu[0].GLMemoryMB=1024
                    glgpu[0].GLName="ATI Radeon HD 5770 OpenGL Engine"
                    glgpu[0].GLVendor="ATI Technologies Inc."
                    glgpu[0].GLVendorID=4098
                    glgpu[0].GLRectTextureSize=16384
                    glgpu[0].GLRenderer="ATI Radeon HD 5770 OpenGL Engine"
                    glgpu[0].GLRendererID=16915202
                    glgpu[0].HasGLNPOTSupport=1
                    glgpu[0].CanCompileProgramGLSL=1
                    glgpu[0].GLFrameBufferOK=1
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[4096 ]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[3072]
                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[3072]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                    clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:19:43)"
                    clgpu[0].CLDeviceVersion="1.2 "
                    clgpu[0].IsIntegratedCLGPU=0
                    clgpu[0].CLMemoryMB=1024
                    clgpu[0].CLName="ATI Radeon HD 5770"
                    clgpu[0].CLVendor="AMD"
                    clgpu[0].CLVendorID=16915200
                    clgpu[0].CLDriverVersion="1.2 (Nov  9 2017 18:48:37)"
                    clgpu[0].CLBandwidth=5.38586e+10
                    clgpu[0].CLCompute=126.49
                    License Type: Subscription
                    Serial number: 90970692094325976655
                    GUIDBucket:
                    Application folder: /Applications/Adobe Photoshop CC 2018/
                    Photoshop scratch has async I/O enabled
                    Scratch volume(s):
                      Startup, 930.7G, 774.0G free
                    Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-ins/
                    Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-ins/
                    Installed components:
                       AdbePM.framework   AdbePM   2.5.00.377243   1.578146
                       adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
                       AdobeACE.framework   AdobeACE   2.20.02.39705   79.589342
                       AdobeAGM.framework   AdobeAGM   4.30.87.39705   79.589342
                       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                       AdobeBIB.framework   AdobeBIB   1.2.03.39705   79.589342
                       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.39705   79.589342
                       AdobeCoolType.framework   AdobeCoolType   5.17.00.39705   79.589342
                       AdobeCrashReporter.framework   AdobeCrashReporter   7.6.0
                       AdobeExtendScript.framework   AdobeExtendScript   4.5.8.1   81.1150526
                       AdobeJP2K.framework   AdobeJP2K   1.2.2.38423   79.266298
                       AdobeLinguistic.framework      22175
                       AdobeMPS.framework   AdobeMPS   5.8.1.38423   79.582572
                       AdobeOwl.framework   AdobeOwl   5.2.11
                       AdobePDFL.framework   AdobePDFL   15.0.0.38423   79.226411
                       AdobePDFSettings.framework   AdobePDFSettings   1.4
                       AdobePIP.framework   AdobePIP   7.4.1.109.46827
                       AdobeScCore.framework   AdobeScCore   4.5.8.1   81.1150526
                       AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.38473   79.582907
                       AdobeSVGRE.framework   AdobeSVGRE   6.0   79.588619
                       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                       AdobeXMP.framework   AdobeXMPCore   79.160451   79.160451
                       AdobeXMPFiles.framework   AdobeXMPFiles   79.160451   79.160451
                       AdobeXMPScript.framework   AdobeXMPScript   79.160451   79.160451
                       ahclient.framework   ahclient   3.0.0.6
                       AIDE.framework   AIDE   1.5.0.36540   79.574279
                       aif.framework   aif   6.0.00.1   1.
                       amtlib.framework   amtlib   10.0.0.221
                       boost_date_time.framework   boost_date_time   11.1.0.0
                       boost_filesystem.framework   boost_filesystem   11.1.0.0
                       boost_signals.framework   boost_signals   11.1.0.0
                       boost_system.framework   boost_system   11.1.0.0
                       boost_threads.framework   boost_threads   11.1.0.0
                       Cg.framework   NVIDIA Cg
                       CITThreading.framework
                       dvaaudiodevice.framework   dvaaudiodevice   11.1.0.0
                       dvacore.framework   dvacore   11.1.0.0
                       dvamarshal.framework   dvamarshal   11.1.0.0
                       dvamediatypes.framework   dvamediatypes   11.1.0.0
                       dvametadata.framework   dvametadata   11.1.0.0
                       dvametadataapi.framework   dvametadataapi   11.1.0.0
                       dvametadataUI.framework   dvametadataUI   11.1.0.0
                       dvaplayer.framework   dvaplayer   11.1.0.0
                       dvatransport.framework   dvatransport   11.1.0.0
                       dvaui.framework   dvaui   11.1.0.0
                       dvaunittesting.framework   dvaunittesting   11.1.0.0
                       dynamiclink.framework   dynamiclink   11.1.0.0
                       ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                       ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                       ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                       k2.framework   k2   1
                       LogSession.framework   LogSession   7.4.1.109.46827
                       manta.framework   manta   2.0.00.1   1.
                       mediacoreif.framework   mediacoreif   11.1.0.0
                       PlugPlugExternalObject.framework      8.5.0.87
                       PlugPlugOwl.framework   PlugPlugOwl   8.5.0.87
                       UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
                       WRServices.framework
                    Required plug-ins:
                       3D Studio 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Accented Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Adaptive Wide Angle 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
                       Angled Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Average 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
                       Bas Relief 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       BMP 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Camera Raw 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                       Camera Raw Filter 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                       Chalk & Charcoal 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Chrome 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Cineon 19.1.0  © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
                       Clouds 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
                       Collada DAE 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Color Halftone 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Colored Pencil 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       CompuServe GIF 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Conté Crayon 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Craquelure 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Crop and Straighten Photos 19.1.0  © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
                       Crop and Straighten Photos Filter 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Crosshatch 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Crystallize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Cutout 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Dark Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       De-Interlace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Dicom 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
                       Difference Clouds 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
                       Diffuse Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Displace 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Dry Brush 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Eazel Acquire 19.1.0  © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
                       Entropy 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Export Color Lookup Tables 19.1.0  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
                       Extrude 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       FastCore Routines 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
                       Fibers 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Film Grain 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Filter Gallery 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Flash 3D 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Fresco 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Glowing Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Google Earth 4 KMZ 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Graphic Pen 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Halftone Pattern 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Halide Bottlenecks 19.1.0  © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
                       HDRMergeUI 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
                       HSB/HSL 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       IFF Format 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       IGES 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Ink Outlines 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       JPEG 2000 19.1.0  © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
                       Kurtosis 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Lens Blur 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
                       Lens Correction 19.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
                       Lens Flare 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Liquify 19.1, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
                       Matlab Operation 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
                       Maximum 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Mean 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Measurement Core 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
                       Median 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Mezzotint 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Minimum 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       MMXCore Routines 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
                       Mosaic Tiles 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Multiprocessor Support 19.1.0  © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
                       Neon Glow 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Note Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       NTSC Colors 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
                       Ocean Ripple 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       OpenEXR 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Paint Daubs 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Palette Knife 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Patchwork 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Paths to Illustrator 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       PCX 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
                       Photocopy 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Photoshop 3D Engine 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “Photoshop3DEngine.plugin”
                       Photoshop Touch ©2013-2018 Adobe. All rights reserved. - from the file “PSDX.plugin”
                       Picture Package Filter 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
                       Pinch 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Pixar 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
                       Plaster 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Plastic Wrap 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       PLY 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Pointillize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Polar Coordinates 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Portable Bit Map 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
                       Poster Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       PRC 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Radial Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Radiance 19.1.0  © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
                       Range 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Render Color Lookup Grid 19.1.0  © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
                       Reticulation 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Ripple 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Rough Pastels 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Save for Web 19.1, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
                       ScriptingSupport 19.1.0, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
                       Shake Reduction 19.1, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
                       Shear 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Skewness 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Smart Blur 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Smudge Stick 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Solarize 19.1.0  © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
                       Spaces 19.1.0, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
                       Spatter 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Spherize 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Sponge 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Sprayed Strokes 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Stained Glass 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Stamp 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Standard Deviation 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       STL 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Sumi-e 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Summation 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Targa 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Texturizer 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Tiles 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Torn Edges 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Twirl 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       U3D 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Underpainting 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Vanishing Point 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
                       Variance 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
                       Virtual Reality Modeling Language | VRML 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Water Paper 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Watercolor 19.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
                       Wave 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Wavefront|OBJ 19.1.0  © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
                       Wind 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                       Wireless Bitmap 19.1.0  © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
                       ZigZag 19.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
                    Optional and third party plug-ins: NONE
                    Duplicate and Disabled plug-ins: NONE
                    Plug-ins that failed to load: NONE
                    Extensions:
                       com.adobe.Butler.backend  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
                       com.adobe.inapp.purchase  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html ”
                       New Document  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.fnft/fnft.html”
                       Libraries  2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
                       Start  2.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html”
                       Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
                       Export As  3.1.2 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
                    Installed TWAIN devices: NONE
                    • 7. Re: There isn't enough room to display this document
                      From your screen capture it looks like you have the layers palette covering the whole display so there is no room for an image window left. Switch to an Adobe provided workspace.
                      • 9. Re: There isn't enough room to display this document
                        I figured it out!   Thanks so much!!!!
                        • 10. Re: There isn't enough room to display this document
                          I do not ise a Mac to me it look lip Photoshop menu bar is in Apple's Mac Desktop menu bar so you can use menu Window>Workspace>Name or in the tool option bar the icon on the right side with a pulldown to select a workspace
                          • 11. Re: There isn't enough room to display this document
                            sheilak23182003
                            I have a similar problem, but where do I go from here, as nothing is working ....
                            • 12. Re: There isn't enough room to display this document
                              The original post fixed it by resizing the Layers panel down so it wasn't taking up all of the application frame space.
                              Can you go to Window> Workspace> Essentials and see what happens? Are there any panels spanning the screen?
                              regards,
                              steve
                              • 14. Re: There isn't enough room to display this document
                                Mohit Goyal Adobe Employee (Admin)
                                Hi All,
                                This issue should be fixed in the Photoshop CC 2018 (19.1.4) release which is now available. Checkout the list of fixed issues here: Fixed issues in Adobe Photoshop CC
                                Please update Photoshop CC 2018 via the Creative Cloud desktop app and let us know if you continue to have any trouble.
                                Update Creative Cloud apps
                                Mohit
                                • 15. Re: There isn't enough room to display this document
                                  Kukurykus Adobe Community Professional
                                  After 3 months if finally works again!
                                  • 16. Re: There isn't enough room to display this document
                                    vern9ine
                                    Just had the same issue of: Could not complete your request There isn't enough room to display this document. on a Macbook Pro and Sierra with the 19.1.5 photoshop version. Unchecked the Application Frame Space and the files opened. Yeah! Seems there is still a bug in the system though ;-(
