Hello Captivate Experts,
I am not really new to Captivate, but am to this, "White Screen Problem with Animations" issue. I have Flash Player 10 installed and am using Captivate 4.
It first started with a simple form that I made in Flash to be installed into Captivate. Because of the way the slide was fading in, it didn't play the swf correctly. I had to add 10 frames to my Flash document at the front so it would play correctly. That was no big deal. Here's the big deal:
I created a simple intoduction swf for the first slide in the show, not even 30 frames long. I published it for Flash Player 10 in both Flash and Captivate, using AS3. When importing the swf, it plays fine in the import dialog thumbnail, but doesn't play at all when I preview it. I too get the dreaded white screen. However, like another user was explaining, the swf plays fine if I preview it in the edit mode. Additionally, I got the following errors from Flash Player 10 when previewing using "next 5 slides":
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at captivate.Veela_AS3::rdSwfLoader/UnloadSWF()
at captivate.Veela_AS3::rdSlide/hideSlide()
at captivate.Veela_AS3::rdMovie/doPlay()
at captivate.Veela_AS3::rdMovie/doGotoFrame()
at captivate.Veela_AS3::rdMovie/gotoFrame()
at captivate.Veela_AS3::rdMovie/checkPreviewCommands()
at captivate.Veela_AS3::rdMovie/movieonEnterFrame()
at captivate.Veela_AS3::CaptivateMainTimeline/onenterframe()
I tried publishing both the swf and preview files for Flash Player 9 with no help.
My captivate project is 105 or so slides. It has two FLVs, which play just fine, and just two swf animations: one simple checkbox form that plays fine and the intro slide that gives me the white screen. I published the whole thing (without the intro slide swf) to my server and tried to play it, launching the show from the "htm" file. All I got were Flash Player 10 errors and it wouldn't play. However, if I lauched just the swf, it played fine; without the playbar available of course.
Your help is greatly appreciated.
Dear Captivate Experts,
I have another problem with Captivate 4 (C4)... Intermittently, F12 yields nothing in my project. Using the menu selection yields nothing as well. Now it goes through the process of crunching everything from sounds to slides, but after everything is processed, no browser action. I say intermittently because it WAS working yesterday off and on. Today, it's just not working.
I created the slides in MS PPT 2007 and I first published the project using Adobe Presenter. When it couldn't hack the Flash CS4 form I had on one slide (played it wacky), I thought I'd give C4 a try. Well C4 handled the form fine, but I'm getting the White Screen when previewing on the first slide Flash swf and it freezes there, like it's waiting for the animation to end.
Could it be that when I imported the pptx file into C4 that C4 acquired some stuff from Adobe Presenter as well and is affecting how Captivate is working?
Thanks in advance for any help.
Hi there
I'm going to crawl way out here on this little limb and suggest that there isn't anything related to Presenter lurking about. I've played with it a bit and I it seems to me that it simply grabs things from PowerPont and builds a Flash animation from them. But it really doesn't insert anything specific to Presenter into the slides that I'm aware of.
My guess here is that it's the Flash Animation that may be gagging both Presenter and Captivate. What happens if you omit the slide containing the additional Flash content? Do things begin working in both Presenter and Captivate?
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Thank you for your reply.
When I developed the PPTX initially, I used Presenter and published it with, oh, a dozen or so PDF attachments, so the learner could look at the source materials for my discussion. Neat little feature. I also liked the Presenter screen better than the simplified captivate one. I tested it on my desktop and it played the Flash CS4 form wrong. Meaning, it didn't obey the [stop();] commands that I installed. Please allow me to explain: The form is a checkbox type, where the learner makes selections based upon his/her opinion and then clicks a button; the form reveals a change in the title and adds a red square, surrounding a group of checkboxes. Basically the form is two frames long in theory: first frame provides a title, checkboxes and button; second has a title change and adds a red box. Presenter played the form back and forth between the two frames very, very rapidly, as if I had not installed actionscript to stop the animation on the first frame. That's when I decided to try Captivate 4, to see whether the form would be treated differently, which it was: it played better, but I had to add a few frames in front of frame 1 for some reason. When loading the form, Captivate went straight to frame 2 in the form's animation sequence, and didn't obey my [stop();] actionscript that I had on frame 1. The workaround for me was to add a few frames in front of the stop(); actionscirpt to delay it a bit.
Now here is where I get to my point in disagreement with your hypothesis "that there isn't anything related to Presenter lurking about."
When I imported the PPTX file into Captivate 4, I did a default import (all slides selected). During the process of development, I decided to edit one slide in PowerPoint from within the Captivate environment; cool feature. After I was done editing, I saved it and a strange dialog appeared, alerting me to the fact that Captivate (or PowerPoint) could not find the PDF files that I had attached (originally in Presenter) and gave me three choices, Browse, Delete and ignore. The first time this happened, I browsed for the PDFs and found that it gagged Captivate to the point where it was telling me that I didn't have enough memory to create the preview swf, and other odd things (I have 4Gb of RAM and 1.5 Tb drive), like it wouldn't save the file (soft crash?). So the next time, I decided to delete instead. The result was that everything worked fine. However, when I tried to edit a single slide again, Captivate (or is it Powerpoint?) asked me for the location of the PDF attachments again. So whichever program is in charge during the edit (I imagine it is PowerPoint within a Captivate shell of some sort), that program is asking me for the PDF attachments, which I originally did in Presenter. So for some reason, when I imported the PPTX file into Captivate, included were pointers to the PDF files. Why would that happen?
Regards
Another funny thing happened to me today: Putting a simple text animation on a slide, I made a change in the options tab and clicked apply. I got the following dialog: "Cannot Load winswfgenerator.dll." Afterwards my editing stage went blank.
All throughout this project, I have had to continuously save my project, i.e. do something, save; do something else, save again. I have acquired a CTRL-S twitch in my left hand from years of dealing with development software that has bugs. Captivate has my old twitch back. I have been noticing that Captivate will only let me make a few edits before the edit stage will go blank and all I will see is the blank slide dimensions that show up in the middle of the slide. My next move is to close the program and restart it. In the process of closing (using the "x" at the top right or using the FILE menu exit item, it doesn't matter), I am prompted to either save my project or not. Pretty typical so far. I choose SAVE. The program looks like it is saving, but it doesn't. After the save button is pushed, the dialog box closes and one would expect to see the program close; well, it doesn't do that either. So I try to exit again, and again it prompts me to save my project. I could do that all day long. Furthermore, none of the saves are accomplished. The only way I can get the program to close is to select NO when prompted to save my file after selecting EXIT.
I always know when the above scenario will occur when the edit stage goes blank. I have had it happen when scrubbing through the audio on a slide numerous times.
Hi there
Where exactly is your project when you are making edits? Local PC or somewhere on a network? If you say somewhere on a network, try moving the project to your local PC and only making edits to it while there.
Cheers... Rick
My project is on my local drive. It's a 1.4 Tb drive.
Is the proposed solution to the infamous white screen only to manually select "Flash 8 or 9" from the publish options and then have to publish the movie file every time I want to verify it looks good?
You're basically saying the preview method is broken and not to use it. The publish method works if you happen to have the patience of a Saint and overrite your files every single time just to preview it? The program does not have a method for remembering the flash version. No publish settings?
When can we expect an update? I won't be able to use this program for now in it's current state.
Welcome to our community Vfire
Are you using Captivate 3?
I ask because Captivate 5 is the current version.
If you are still using Version 3, you may also preview using the browser. (F12) You may also downgrade your Flash Player/Plug In version.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
