When making any sort of change to any of my images, there is at best a lag, at worst, nothing happens at all. I cannot select pixels. Only half of my filters and actions produce any sort of result. I can copy a layer, but when I do, the layer preview in the layers panel appears blank, even if the copy is successfully made.
From time to time I can get an action to show up when I move on to making another edit, but that doesn't happen every time.
I'm on a iMac (Retina 5K, late 2015) with 1TB Fusion Drive available - running High Sierra version 10.13.3.
I have deleted all Photoshop preference files, uninstalled the app, reinstalled it and restarted the computer, checked and unchecked "Use Graphics Processor," and "Show Start Workspace When No Documents Are Open" - nothing seems to solve any of the problems.
I just upgraded to Photoshop CC from Photohshop 6 and am finding it (at least this version) to be absolutely unusable.
Use CC 2018 menu help>System Info copy and paste the info here. Some Mac user may be able to see something in there
Thanks! Just added it to the thread
I run that very version on a 2012 Macbook Pro.10.13.3 and your rig is much better than that.
First thing that comes to mind are multiple monitors. Are you using those?
As a troubleshooting step, disable the GPU under Photoshop > Preferences > Performance and see if things improve.
It's such a mystery! Not hooked up to any external monitors. I have quite a bit of RAM/memory as my computer is virtually new and has few programs other than the Adobe Suite even installed. I've tried closing all other programs while working. I have also already tried disabling the GPU - doesn't seem to change anything. Yesterday after some experimenting, I realized I can (sometimes) see my work if I add a new layer, then click into that new layer. As soon as I click the new layer the last edit I made appears. It's a temporary (and frustrating) workaround, but obviously, unacceptable for the long-term.
I honestly do not know enough about the 5k at this point to give you a useful answer, so let's try installing an earlier version (part of your membership) and see if it works. Let me know if that helps. Try the latest CC 2017 and move downward of that version does not work.
So from the Creative Cloud Desktop App:
Going back to 18.0 worked! Thanks for that - guess I'll wait it out on the old version until the next update... 🙂
System Info:
Adobe Photoshop Version: 19.1.1 20180206.r.254 2018/02/06: 1156206 x64
Number of Launches: 8
Operating System: Mac OS 10.13.3
System architecture: Intel CPU Family:6, Model:94, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3200 MHz
Built-in memory: 16384 MB
Free memory: 9631 MB
Memory available to Photoshop: 14274 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Disabled.
Touch Bar Property Feedback: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=1440, right=2560
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="AMD Radeon R9 M390 OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon R9 M390 OpenGL Engine"
glgpu[0].GLRendererID=16915458
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:30:00)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="AMD Radeon R9 M390 Compute Engine"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915456
clgpu[0].CLDriverVersion="1.2 (Dec 20 2017 17:28:06)"
clgpu[0].CLBandwidth=1.25342e+11
clgpu[0].CLCompute=855.868
nativegpu[0].NativeName="AMD Radeon R9 M390"
License Type: Subscription
Serial number: 96040256227058763477
GUIDBucket:
Application folder: /Applications/Adobe Photoshop CC 2018/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 951.8G, 829.0G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/Plug-ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2018/Plug-ins/
Installed components:
AdbePM.framework AdbePM 2.5.00.377243 1.578146
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeACE.framework AdobeACE 2.20.02.39705 79.589342
AdobeAGM.framework AdobeAGM 4.30.87.39705 79.589342
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
AdobeBIB.framework AdobeBIB 1.2.03.39705 79.589342
AdobeBIBUtils.framework AdobeBIBUtils 1.1.39705 79.589342
AdobeCoolType.framework AdobeCoolType 5.17.00.39705 79.589342
AdobeCrashReporter.framework AdobeCrashReporter 7.6.0
AdobeExtendScript.framework AdobeExtendScript 4.5.8.1 81.1150526
AdobeJP2K.framework AdobeJP2K 1.2.2.38423 79.266298
AdobeLinguistic.framework 22175
AdobeMPS.framework AdobeMPS 5.8.1.38423 79.582572
AdobeOwl.framework AdobeOwl 5.2.11
AdobePDFL.framework AdobePDFL 15.0.0.38423 79.226411
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.4.1.109.46827
AdobeScCore.framework AdobeScCore 4.5.8.1 81.1150526
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.38473 79.582907
AdobeSVGRE.framework AdobeSVGRE 6.0 79.588619
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.160451 79.160451
AdobeXMPFiles.framework AdobeXMPFiles 79.160451 79.160451
AdobeXMPScript.framework AdobeXMPScript 79.160451 79.160451
ahclient.framework ahclient 3.0.0.6
AIDE.framework AIDE 1.5.0.36540 79.574279
aif.framework aif 6.0.00.1 1.
amtlib.framework amtlib 10.0.0.221
boost_date_time.framework boost_date_time 11.1.0.0
boost_filesystem.framework boost_filesystem 11.1.0.0
boost_signals.framework boost_signals 11.1.0.0
boost_system.framework boost_system 11.1.0.0
boost_threads.framework boost_threads 11.1.0.0
Cg.framework NVIDIA Cg
CITThreading.framework
dvaaudiodevice.framework dvaaudiodevice 11.1.0.0
dvacore.framework dvacore 11.1.0.0
dvamarshal.framework dvamarshal 11.1.0.0
dvamediatypes.framework dvamediatypes 11.1.0.0
dvametadata.framework dvametadata 11.1.0.0
dvametadataapi.framework dvametadataapi 11.1.0.0
dvametadataUI.framework dvametadataUI 11.1.0.0
dvaplayer.framework dvaplayer 11.1.0.0
dvatransport.framework dvatransport 11.1.0.0
dvaui.framework dvaui 11.1.0.0
dvaunittesting.framework dvaunittesting 11.1.0.0
dynamiclink.framework dynamiclink 11.1.0.0
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
k2.framework k2 1
LogSession.framework LogSession 7.4.1.109.46827
manta.framework manta 2.0.00.1 1.
mediacoreif.framework mediacoreif 11.1.0.0
PlugPlugExternalObject.framework 8.5.0.87
PlugPlugOwl.framework PlugPlugOwl 8.5.0.87
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
WRServices.framework
Required plug-ins:
3D Studio 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Accented Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 19.1.1, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Average 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
Bas Relief 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
BMP 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Camera Raw 10.2 (894), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 10.2 (894), Copyright © 2018 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Chrome 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Cineon 19.1.1 © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
Clouds 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Collada DAE 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Color Halftone 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Colored Pencil 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
CompuServe GIF 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Conté Crayon 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Craquelure 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 19.1.1 © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Crosshatch 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crystallize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Cutout 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Dark Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
De-Interlace 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dicom 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
Difference Clouds 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Diffuse Glow 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Displace 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dry Brush 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Eazel Acquire 19.1.1 © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
Entropy 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Export Color Lookup Tables 19.1.1 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Extrude 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
FastCore Routines 19.1.1 © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
Fibers 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Film Grain 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Filter Gallery 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Flash 3D 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Fresco 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glass 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glowing Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Graphic Pen 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halftone Pattern 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halide Bottlenecks 19.1.1 © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
HDRMergeUI 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
HSB/HSL 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IFF Format 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IGES 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Ink Outlines 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
JPEG 2000 19.1.1 © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
Kurtosis 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Lens Blur 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
Lens Correction 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
Lens Flare 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Liquify 19.1.1, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
Matlab Operation 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Maximum 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mean 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Measurement Core 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
Median 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mezzotint 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Minimum 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
MMXCore Routines 19.1.1 © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
Mosaic Tiles 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Multiprocessor Support 19.1.1 © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
Neon Glow 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Note Paper 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
NTSC Colors 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
Ocean Ripple 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
OpenEXR 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Paint Daubs 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Palette Knife 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Patchwork 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Paths to Illustrator 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
PCX 19.1.1 © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
Photocopy 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “Photoshop3DEngine.plugin”
Photoshop Touch ©2013-2018 Adobe. All rights reserved. - from the file “PSDX.plugin”
Picture Package Filter 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Pinch 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Pixar 19.1.1 © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
Plaster 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Plastic Wrap 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PLY 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Pointillize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Polar Coordinates 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Portable Bit Map 19.1.1 © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
Poster Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PRC 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Radial Blur 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Radiance 19.1.1 © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
Range 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Render Color Lookup Grid 19.1.1 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Reticulation 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Ripple 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Rough Pastels 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Save for Web 19.1.1, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
ScriptingSupport 19.1.1, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
Shake Reduction 19.1.1, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
Shear 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Skewness 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Smart Blur 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Smudge Stick 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Solarize 19.1.1 © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
Spaces 19.1.1, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
Spatter 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Spherize 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Sponge 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Sprayed Strokes 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stained Glass 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stamp 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Standard Deviation 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
STL 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Sumi-e 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Summation 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Targa 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Texturizer 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Tiles 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Torn Edges 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Twirl 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
U3D 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Underpainting 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Vanishing Point 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
Variance 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Water Paper 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Watercolor 19.1.1, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Wave 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 19.1.1 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Wind 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 19.1.1 © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
ZigZag 19.1.1, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.Butler.backend 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
com.adobe.inapp.purchase 2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/purchase.html”
New Document 2.1.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_1_1_004/fnft.html”
Libraries 2.11.27 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html”
Start 2.1.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_1_1_076/index.html”
Noun Project 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.thenounproject.nounPanel/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 3.1.2 - from the file “/Applications/Adobe Photoshop CC 2018/Adobe Photoshop CC 2018.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Installed TWAIN devices: NONE
I'm not a mac user I do not see anything bad offhand in there. Make sure you have installed all of Apples updates for your model mac. Apple seems to control what devices drivers allowed to be installed on mac machines. The Problem may be related to your mac model and osx version you using. Hopefully someone with good Mac knowledge can help you.
Thanks for taking a look! I just ran the latest OS update a couple days ago, so I'm sure I'm up to date.
