When I try to copy a A4 page, it looks like this and when its done its still look like this on the paper
Can you please explain what it is you're trying to do in more detail, also what version of Photoshop and Operating System you have.
The more info you supply the easier it is for someone to help, also a bigger screenshot would be better including the layers panel
Why would you copy a 4 page in Photoshop? You mean scan a page or what? Like Ged said, some more details could not harm...
Photoshop CC 2018
Sorry, i try to print it out.
But i have shoosen a a4
It says that its to big in photoshop so ts going to cutt
No mystery here. The printer needs an empty margin on the A4 paper you're printing on, for paper transport and other mechanical reasons. So, the A4 document will be cropped by the same amount, or reduced in size.
A very few A4 printers can print borderless to the full paper size, but in that case you have to enable that function in the printer driver.
Why not import the Photoshop file in InDesign and print it from InDesign? A Layout software has no problem to handle A 4.
It's not as if Photoshop has any problems handling A4 either
The way I understand the OP, she wants to print an A4 page 1:1, at full size. And for that she will either need to print borderless, if the printer can do that, or use a large format (A3) printer and cut.
No, those sizes won't mean anything to you Americans A4 is 210 mm wide and 297 mm high, and no, I don't know how many fractional inches that translates to...
I know it's humour, Dag, but enter "A4 paper size" into Google and we get 8.3" x11.7" But we call it A4 and set the printer to A4, no "metric" or "customary" knowledge needed.
You can also get a 500 sheet package from Amazon if you are in the US and need it for some reason.
yes thats the sice 210x297. But as you said, the size on photoshop is to big. so it gets an ugly white border.
What to do
Read post #5 again!
Can your printer print borderless? That's the question. The printer, not Photoshop.
