Hello i am trying to install adobe photoshop
I am using windows 10..Not creative cloud installed cause it failed too..Creative cloud installer failed!(error code : 44)
Help me with this
here is the PDA log
02/27/18 19:18:38:364 | [INFO] | | ASU | OPM | OPM | | | 7272 | Build Version - 10.0.0.99
02/27/18 19:18:38:364 | [INFO] | | ASU | OPM | OPM | | | 7272 | Logging Level verbosity Set to 4
02/27/18 19:18:38:366 | [INFO] | | ASU | OPM | OPM | | | 7272 | Schema version and schema compatibility version are same or greater than current
02/27/18 19:18:38:896 | [INFO] | | ASU | OPM | OPM | | | 7272 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/27/18 19:18:38:897 | [INFO] | | ASU | OPM | OPM | | | 7272 | No Record found for the input fields in opm_getValueForKey
02/27/18 19:19:17:148 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 1556 | Build Version - 1.13.0.59
02/27/18 19:19:17:148 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 1556 | Logging Level verbosity Set to 4
02/27/18 19:19:17:164 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 1556 | Successfully fetched the optionXML content from MSI database ...
02/27/18 19:19:35:510 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8832 | Build Version - 1.13.0.59
02/27/18 19:19:35:510 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8832 | Logging Level verbosity Set to 4
02/27/18 19:19:35:510 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8832 | Executing immediate custom action for install mode.
02/27/18 19:19:35:511 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8832 | The CustomActionData string is : mode=install;sourceDir=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\;installDir=;origDB=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi;installLang=
02/27/18 19:19:35:511 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8832 | Successfully executed the immediate custom action for install mode .
02/27/18 19:19:49:380 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Build Version - 1.13.0.59
02/27/18 19:19:49:380 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Logging Level verbosity Set to 4
02/27/18 19:19:49:380 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Executing the deferred custom action.
02/27/18 19:19:49:385 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Obtained the following as CustomActionData
02/27/18 19:19:49:385 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | (mode=install;sourceDir=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\;installDir=;origDB=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi;installLang=)
02/27/18 19:19:49:386 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Original database path is : E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi
02/27/18 19:19:49:417 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | OptionXML saved at location :: C:\Users\megh\AppData\Local\Temp\{CC58AF9C-90CD-464D-9265-3A384B7E9126}\\{077B7F45-4AC2-45A7-9EFC-9E207264CA7C}
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Build Version - 1.13.0.59
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Logging Level verbosity Set to 4
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | CustomAction Parameters obtained...
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | optXMLPath :: C:\Users\megh\AppData\Local\Temp\{CC58AF9C-90CD-464D-9265-3A384B7E9126}\\{077B7F45-4AC2-45A7-9EFC-9E207264CA7C}
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | setupBasePath :: E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | installDirPath ::
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | installLang ::
02/27/18 19:19:49:474 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Initializing Custom Action Data from parameters
02/27/18 19:19:49:475 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Provisioning Tool path is (C:\Users\megh\AppData\Local\Temp\{CC58AF9C-90CD-464D-9265-3A384B7E9126}\\{8DAE399E-0342-4D7B-8929-AAD49BCE0889}).
02/27/18 19:19:49:476 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Starting to run the custom action for install mode
02/27/18 19:19:49:476 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | STEP 1: Starting to parse Option XML.
02/27/18 19:19:49:521 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Latest AAM version with the package is (4.3.0.256)...
02/27/18 19:19:49:544 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Install language fallback contains following languages :
02/27/18 19:19:49:544 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | (en_GB)
02/27/18 19:19:49:544 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Self-Update BootStrapper Relative Path doesn't exist.
02/27/18 19:19:49:544 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | No of updates found (0).
02/27/18 19:19:49:545 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | No of HD products found (7).
02/27/18 19:19:49:574 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get value for conflicting processes...
02/27/18 19:19:49:574 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to parse the conflictProcessInfo for HD media (CORE1.0)...
02/27/18 19:19:49:579 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get value for conflicting processes...
02/27/18 19:19:49:579 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to parse the conflictProcessInfo for HD media (COSY2.4.3)...
02/27/18 19:19:49:583 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get value for conflicting processes...
02/27/18 19:19:49:583 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to parse the conflictProcessInfo for HD media (COPS1.0)...
02/27/18 19:19:49:592 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get value for conflicting processes...
02/27/18 19:19:49:592 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to parse the conflictProcessInfo for HD media (CORG1.1)...
02/27/18 19:19:49:597 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get value for conflicting processes...
02/27/18 19:19:49:597 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to parse the conflictProcessInfo for HD media (COCM1.0)...
02/27/18 19:19:49:607 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Custom deployment path doesnt exist in options XML
02/27/18 19:19:49:607 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to find Royalty Bearing attribute info.
02/27/18 19:19:49:607 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Found the AppsPanel attribute info (true)
02/27/18 19:19:49:608 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Found the AdminPrivilege attribute info (true)
02/27/18 19:19:49:608 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Number of Medias found = 0
02/27/18 19:19:49:608 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Deployment Manager is running in Install Mode.
02/27/18 19:19:49:608 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | STEP 2: Starting to launch ASU AAM.
02/27/18 19:19:49:608 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Bootstrapper launch location is :: E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\ASU\Set-up.dat
02/27/18 19:19:50:627 | [INFO] | | ASU | OPM | OPM | | | 6660 | Build Version - 10.0.0.99
02/27/18 19:19:50:627 | [INFO] | | ASU | OPM | OPM | | | 6660 | Logging Level verbosity Set to 4
02/27/18 19:19:50:629 | [INFO] | | ASU | OPM | OPM | | | 6660 | Schema version and schema compatibility version are same or greater than current
02/27/18 19:19:51:139 | [INFO] | | ASU | OPM | OPM | | | 6660 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/27/18 19:19:51:140 | [INFO] | | ASU | OPM | OPM | | | 6660 | No Record found for the input fields in opm_getValueForKey
02/27/18 19:19:54:199 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Build Version - 1.13.0.59
02/27/18 19:19:54:199 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Logging Level verbosity Set to 4
02/27/18 19:19:54:199 | [FATAL] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | The Bootstrapper Process return code is (44).Stopping the installation process.
02/27/18 19:19:54:200 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | Failed to get/verify the UpdaterCore inventory base path (C:\Program Files\Common Files\Adobe\AAMUpdaterInventory\1.0\)
02/27/18 19:19:54:200 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | sendAnalytics : Unable to find deviceId.
02/27/18 19:19:54:714 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 5152 | The output of process received in execWithOutput :
Microsoft Windows [Version 10.0.16299.248]
02/27/18 19:19:54:718 | [INFO] | | ASU | DeploymentManager | | | | 5152 | Event Guid generated is: '46da3ec9-7666-4a79-bf5e-512d0ea2fc12'
02/27/18 19:19:54:734 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 5152 | GetIEProxyInfo - No default proxy present on the user machine
02/27/18 19:19:56:344 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 624 | HTTP Request Status code 200.
02/27/18 19:19:56:344 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 5152 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/27/18 19:19:56:345 | [INFO] | | ASU | DeploymentManager | | | | 5152 | Waiting for the async thread to get the task completed
02/27/18 19:19:56:345 | [INFO] | | ASU | DeploymentManager | | | | 1940 | Async thread is completed. Now exiting from function.
02/27/18 19:19:56:346 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 5152 | The install workflow is terminating.
02/27/18 19:19:57:727 | [INFO] | | ASU | MSIInvoker | AAMEEUtilities | | | 1556 | Process creation completed.
02/27/18 19:19:57:727 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 1556 | The return Code from Create Process (1603).
02/27/18 19:20:00:156 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 1556 | Setup exiting with return code (6)
03/01/18 17:35:05:390 | [INFO] | | ASU | OPM | OPM | | | 9932 | Build Version - 10.0.0.99
03/01/18 17:35:05:390 | [INFO] | | ASU | OPM | OPM | | | 9932 | Logging Level verbosity Set to 4
03/01/18 17:35:05:511 | [INFO] | | ASU | OPM | OPM | | | 9932 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:35:06:537 | [INFO] | | ASU | OPM | OPM | | | 9932 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:35:06:537 | [INFO] | | ASU | OPM | OPM | | | 9932 | No Record found for the input fields in opm_getValueForKey
03/01/18 17:37:39:859 | [INFO] | | ASU | OPM | OPM | | | 8020 | Build Version - 10.0.0.99
03/01/18 17:37:39:860 | [INFO] | | ASU | OPM | OPM | | | 8020 | Logging Level verbosity Set to 4
03/01/18 17:37:39:861 | [INFO] | | ASU | OPM | OPM | | | 8020 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:37:40:416 | [INFO] | | ASU | OPM | OPM | | | 8020 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:37:40:417 | [INFO] | | ASU | OPM | OPM | | | 8020 | No Record found for the input fields in opm_getValueForKey
03/01/18 17:39:15:897 | [INFO] | | ASU | OPM | OPM | | | 8740 | Build Version - 10.0.0.99
03/01/18 17:39:15:897 | [INFO] | | ASU | OPM | OPM | | | 8740 | Logging Level verbosity Set to 4
03/01/18 17:39:15:899 | [INFO] | | ASU | OPM | OPM | | | 8740 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:39:16:195 | [INFO] | | ASU | OPM | OPM | | | 8740 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:39:16:195 | [INFO] | | ASU | OPM | OPM | | | 8740 | No Record found for the input fields in opm_getValueForKey
03/01/18 17:45:26:419 | [INFO] | | ASU | OPM | OPM | | | 3468 | Build Version - 10.0.0.99
03/01/18 17:45:26:419 | [INFO] | | ASU | OPM | OPM | | | 3468 | Logging Level verbosity Set to 4
03/01/18 17:45:26:440 | [INFO] | | ASU | OPM | OPM | | | 3468 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:45:27:037 | [INFO] | | ASU | OPM | OPM | | | 3468 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:45:27:037 | [INFO] | | ASU | OPM | OPM | | | 3468 | No Record found for the input fields in opm_getValueForKey
03/01/18 17:46:17:169 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 6556 | Build Version - 1.13.0.59
03/01/18 17:46:17:169 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 6556 | Logging Level verbosity Set to 4
03/01/18 17:46:17:218 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 6556 | Successfully fetched the optionXML content from MSI database ...
03/01/18 17:46:36:699 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 9020 | Build Version - 1.13.0.59
03/01/18 17:46:36:699 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 9020 | Logging Level verbosity Set to 4
03/01/18 17:46:36:699 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 9020 | Executing immediate custom action for install mode.
03/01/18 17:46:36:700 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 9020 | The CustomActionData string is : mode=install;sourceDir=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\;installDir=;origDB=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi;installLang=
03/01/18 17:46:36:700 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 9020 | Successfully executed the immediate custom action for install mode .
03/01/18 17:47:08:806 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Build Version - 1.13.0.59
03/01/18 17:47:08:806 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Logging Level verbosity Set to 4
03/01/18 17:47:08:806 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Executing the deferred custom action.
03/01/18 17:47:08:812 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Obtained the following as CustomActionData
03/01/18 17:47:08:813 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | (mode=install;sourceDir=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\;installDir=;origDB=E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi;installLang=)
03/01/18 17:47:08:813 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Original database path is : E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\adobe_x86.msi
03/01/18 17:47:09:150 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | OptionXML saved at location :: C:\Users\megh\AppData\Local\Temp\{E345D8E1-6B66-4A87-860E-FADFCCE3D1B9}\\{969C9A23-751F-4A6C-8F46-B7CAC00DE31F}
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Build Version - 1.13.0.59
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Logging Level verbosity Set to 4
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | CustomAction Parameters obtained...
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | optXMLPath :: C:\Users\megh\AppData\Local\Temp\{E345D8E1-6B66-4A87-860E-FADFCCE3D1B9}\\{969C9A23-751F-4A6C-8F46-B7CAC00DE31F}
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | setupBasePath :: E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | installDirPath ::
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | installLang ::
03/01/18 17:47:09:362 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Initializing Custom Action Data from parameters
03/01/18 17:47:09:363 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Provisioning Tool path is (C:\Users\megh\AppData\Local\Temp\{E345D8E1-6B66-4A87-860E-FADFCCE3D1B9}\\{E391B462-FFEE-4F05-8183-17B6832EC3F6}).
03/01/18 17:47:09:365 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Starting to run the custom action for install mode
03/01/18 17:47:09:365 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | STEP 1: Starting to parse Option XML.
03/01/18 17:47:09:612 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Latest AAM version with the package is (4.3.0.256)...
03/01/18 17:47:09:632 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Install language fallback contains following languages :
03/01/18 17:47:09:632 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | (en_GB)
03/01/18 17:47:09:632 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Self-Update BootStrapper Relative Path doesn't exist.
03/01/18 17:47:09:632 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | No of updates found (0).
03/01/18 17:47:09:632 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | No of HD products found (7).
03/01/18 17:47:09:636 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get value for conflicting processes...
03/01/18 17:47:09:636 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to parse the conflictProcessInfo for HD media (CORE1.0)...
03/01/18 17:47:09:640 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get value for conflicting processes...
03/01/18 17:47:09:640 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to parse the conflictProcessInfo for HD media (COSY2.4.3)...
03/01/18 17:47:09:645 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get value for conflicting processes...
03/01/18 17:47:09:645 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to parse the conflictProcessInfo for HD media (COPS1.0)...
03/01/18 17:47:09:655 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get value for conflicting processes...
03/01/18 17:47:09:655 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to parse the conflictProcessInfo for HD media (CORG1.1)...
03/01/18 17:47:09:659 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get value for conflicting processes...
03/01/18 17:47:09:659 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to parse the conflictProcessInfo for HD media (COCM1.0)...
03/01/18 17:47:09:670 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Custom deployment path doesnt exist in options XML
03/01/18 17:47:09:670 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to find Royalty Bearing attribute info.
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Found the AppsPanel attribute info (true)
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Found the AdminPrivilege attribute info (true)
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Number of Medias found = 0
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Deployment Manager is running in Install Mode.
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | STEP 2: Starting to launch ASU AAM.
03/01/18 17:47:09:671 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Bootstrapper launch location is :: E:\Adobe_Photoshop_CC_2018_v19.1.0.38906x86\Build\ASU\Set-up.dat
03/01/18 17:47:14:237 | [INFO] | | ASU | OPM | OPM | | | 8240 | Build Version - 10.0.0.99
03/01/18 17:47:14:237 | [INFO] | | ASU | OPM | OPM | | | 8240 | Logging Level verbosity Set to 4
03/01/18 17:47:14:252 | [INFO] | | ASU | OPM | OPM | | | 8240 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:47:20:924 | [INFO] | | ASU | OPM | OPM | | | 8240 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:47:20:924 | [INFO] | | ASU | OPM | OPM | | | 8240 | No Record found for the input fields in opm_getValueForKey
03/01/18 17:47:28:616 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Build Version - 1.13.0.59
03/01/18 17:47:28:617 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Logging Level verbosity Set to 4
03/01/18 17:47:28:617 | [FATAL] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | The Bootstrapper Process return code is (44).Stopping the installation process.
03/01/18 17:47:28:686 | [ERROR] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | Failed to get/verify the UpdaterCore inventory base path (C:\Program Files\Common Files\Adobe\AAMUpdaterInventory\1.0\)
03/01/18 17:47:28:686 | [WARN] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | sendAnalytics : Unable to find deviceId.
03/01/18 17:47:29:810 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 8992 | The output of process received in execWithOutput :
03/01/18 17:47:29:853 | [INFO] | | ASU | DeploymentManager | | | | 8992 | Event Guid generated is: '7d9e77b0-bb3e-428d-9fdd-0c6aedac7308'
03/01/18 17:47:29:971 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 8992 | GetIEProxyInfo - No default proxy present on the user machine
03/01/18 17:47:32:250 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 7648 | HTTP Request Status code 200.
03/01/18 17:47:32:250 | [INFO] | | ASU | DeploymentManager | | | HTTPConnector | 8992 | The http request returned HTTP_Status:0 HttpCommunicator error:0
03/01/18 17:47:32:276 | [INFO] | | ASU | DeploymentManager | | | | 8992 | Waiting for the async thread to get the task completed
03/01/18 17:47:32:276 | [INFO] | | ASU | DeploymentManager | | | | 6868 | Async thread is completed. Now exiting from function.
03/01/18 17:47:32:277 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 8992 | The install workflow is terminating.
03/01/18 17:47:35:403 | [INFO] | | ASU | MSIInvoker | AAMEEUtilities | | | 6556 | Process creation completed.
03/01/18 17:47:35:403 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 6556 | The return Code from Create Process (1603).
03/01/18 17:48:11:704 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 6556 | Setup exiting with return code (6)
03/01/18 17:52:19:591 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Loading AdobePIM.dylib from: C:\Program Files\Common Files\Adobe\Adobe Desktop Common\Core\AdobePIM.dll
03/01/18 17:52:20:562 | [ERROR] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Failed to create the pimLibraryRef at path C:\Program Files\Adobe\Adobe Creative Cloud
03/01/18 17:52:20:562 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | DPI ratio being used DPIX: 1.000000,DPIY:1.000000
03/01/18 17:52:20:577 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Initializing localization resources.
03/01/18 17:52:20:577 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Locale : en-US
03/01/18 17:52:20:577 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Resource ID for Locale: 141
03/01/18 17:52:20:577 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Dictionary reading successful.
03/01/18 17:52:35:978 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Canceled uninstallation.
03/01/18 17:52:36:270 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | SelfDelete invoked for the uninstaller executable.
03/01/18 17:52:36:271 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Removed the AdobePIM.dll from D:\Winrar\Rar$EXa9392.30471\AdobePIM.dll.
03/01/18 17:52:36:952 | [INFO] | | ACC-Uninstaller | | Uninstaller | | | 2552 | Self delete called to delete uninstaller executable from D:\Winrar\Rar$EXa9392.30471\Creative Cloud Uninstaller.exe.
03/01/18 17:59:48:004 | [INFO] | | ASU | OPM | OPM | | | 8836 | Build Version - 10.0.0.99
03/01/18 17:59:48:004 | [INFO] | | ASU | OPM | OPM | | | 8836 | Logging Level verbosity Set to 4
03/01/18 17:59:48:082 | [INFO] | | ASU | OPM | OPM | | | 8836 | Schema version and schema compatibility version are same or greater than current
03/01/18 17:59:49:700 | [INFO] | | ASU | OPM | OPM | | | 8836 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
03/01/18 17:59:49:701 | [INFO] | | ASU | OPM | OPM | | | 8836 | No Record found for the input fields in opm_getValueForKey
Take a look here and see if it help
"Failed to install" error received when installing Adobe Creative Cloud desktop app
Nope did't work already tried!
I'm also running into this same issue. I tried what Ged Traynor responded with and still having the same issue.
Any help is greatly appreciated
...any fix on this? We are having constant issues, both using Cloud Packager and Client Packager.
Forum and links for help with the Packager
-http://forums.adobe.com/community/download_install_setup/creative_suite_enterprise_deployment
-and more information and Packager Links https://forums.adobe.com/thread/1586021
