Hi, I'm using Adobe DC. I want to password protect multiple documents all at once with the same password. When I get my next set of documents, I want to password protect all of them with the same password but a different password than the last batch. How do I do this? Help, please.
If you have Acrobat DC Pro, you can do it using an Action, via Tools - Action Wizard.
Create an Action, add an Encrypt command to it (under Protection), click on Specify Settings under it, select the policy and enter the password you want to use. Make sure to un-tick the "Prompt User" box. Then add a Save command and you're ready to go!
The next time you want to use it just edit the Action and change the password used in it.
Thank you! Apparently I was trying to make this too hard. Once I selected the files, the process ran and said completed, but I didn't know where to go from there. Now I see: completed means completed, nothing more to do!
Thank you again!
One more question: How do I add my new action to the Tools list on the right side of the screen?
You can add the Action Wizard itself. I'm not sure you can add an individual Action to it.
Thank you
