Hello,
after having syncronized my main archive there are at least two copies of the main Image being shown - irritating is, that this does not appear at all of the images in my archive and I can not find any reason for this. How can I remove the duplicates of the pictures - when I choose two copies and try to delete them, all Images including the master one are being removed…
Regards Thomas
There seems to be a bug (at least for some people) with the 'Synchronize Folder' option. This problem has been reported before (Can't delete duplicates without deleting them all I suggest you try the method described there (ignore the whole discussion about 'remove' versus 'delete'; you obviously should not delete the images from disk). And I suggest that you do not use 'Synchronize folder' for the time being. If you use a proper workflow, you shouldn't need it anyway.
