So yeah, i'm basically a noob at this that's why i'm asking for help. Recently, i've tried editing gifs using photoshop. I've finished 2 successful ones i think, but when i tried opening and editing the third gif this happened:
At first i thought there was a problem when i created the gif (selection whether 10fps, 16fps, or 33fps) but that's not the case since i tried doing it all over. Hoping this is a normal thing, i tried saving the gif and then it looked like this:
I don't really know what the hell's happening. A little help pls?
It looks like you need to create better fame composites. Step through the frames a check which layers are visible in each frame you have transparent area in you frames. You need to fill these areas using layers that are not empty in these areas..
