Hello to all.
After a system reset and application reinstall I am experiencing a strange effect.
If I open a gray scale picture it is shown prperly, but in the color tab I have a gray scale that is not gray! Close to blak other colours are present.
The following image is a screenshot of what I mean. The grayscale image on the left is correct while the gray scale bar on the right is wrong. THe RGB bars represents the values obtained by clicking on the left zone of the scale.
BYW a similar effect is present in case of colour scale too.
Is there any settings that I have to do or any other suggestion to solve?
Thank you in advance.
Best regards
Marco
Without any info about your system nobody can tell you much. Such stuff typically relates to things like wrong monitor profiles or generally wrong configuration of your display settings.
Mylenium
Mylenium
Thank you for you answer Mylenium. I am using a Laptop with Windows 10 Home edition and the latest Photoshop releases.
I have tested my system without any color profiling, with predefined ones and with to one obtained by my profiling devices (Spyder 5+ DisplaCal software). Even if with different results the problem is always present.
As long as the image itself looks correct, I'd suspect a video driver glitch in the Color panel.
Update the driver, or disable GPU in preferences until an update fixes it.
mmm, I have disabled the GPU and now even the image presents the same bars.
Any other suggestion?
Update. I have removed all the profiles from the windows folder. Now the bars are disappeared, but the color are not calibrated.
This appen with and without the use of GPU, so the problem seems not related to GPU but probably to color profiling as indicated above.
If you have removed all the Dispcal monitor profiles, the Windows default is used. That's sRGB IEC61966-2.1.
Anyway, that confirms it is the monitor profile. So try to change some settings and make a new one. In particular, version 4 and/or table-based (LUT) profiles can be problematic in some circumstances. Make sure Dispcal is set to make version 2 and matrix-based profiles.
Thank you D Fosse, I have recalibrated the display using the software provided with Spider 5 and the problem is no more present. This software is normally not accurated as Dispcal. I'll tray to recalibrate again using the settings you suggest and I'll give you a feedback. Probably by today.
UPDATE. I am not able to find were to select version 2 instead of version 4 in Dispcal (I am using the GUI interface).
I don't use Dispcal - but those options would normally be under a "policies" heading, and they are only active when you set up a new target. It's a specific property of that particular profile, not a general preference.
If those options don't exist at all, it should be v2 and matrix by default, since those are the "safe" policies.
Probably it is as you say, I have not found the way to select version 4.
Anyway, the results it is still not good, while using the software provided by the vendor there are not any colored bamd in the gray scale.
I'll continue additional tests, even if I do not understand why in the past, vefore resetting my computer it was not present any problem, while now I do not obtain the good results with DisplayCal. I have the doubt that some system driver has been updated ad its behaviour is no more like in the past.
Thank you for your kind support.
