Hi, I am trying to create a template for a t-shirt design. The template will have a graphic in the center with text above and below the graphic. Can someone provide me with instructions on how to create a template for the text so that no matter what name I change the text to it will all look the same and fit above the graphic? I hope that makes sense. Any assistance would be greatly appreciated.
There are many t-shirt template you can download on the web. Why not download some of the free ones and look at what other have done?
JJMack​ thanks! I am not looking to create a mockup. I am looking to create a template where I can change the text as needed without having to recreate each time for use.
A mockup is a template there are many you can download a look at then create the TEMPLATE MOCK you want where the logo and text are in separate areas. You may then be able to create a Photoshop script to help you populate your template to replace either text or logo or both.
Text will be very hard to automate because you will most likely have to change the Font and Font size do to accommodate variable size fonts letter spacing and the different amount of letters. Dealing with any possible text in a fixed size area is a very difficult task You will most likely need support some range of characters. Names are very had to deal with because name length vary so much. Text is hard to deal with text is very complex.
If this was to produce many pieces of finished artwork from a single template using Photoshop variables and a source spreadsheet containing the text, then a similar topic is covered here:
