Need help in "regular" Adobe Photoshop Lightroom
Participant ,
Mar 02, 2018 Mar 02, 2018
Sometimes when I send a photo to HDR (into Nik Software), and then when I'm done and hit "save", it goes back to the Lightroom, but it is hidden from the other versions I worked on.  I can't find it.  I called Adobe long ago about this, but I can't remember what they told me.  It might have been a setting.  When I open up an image in any other program and change it, then save it, the new version shows up at the bottom along with the other versions of the same picture.  But when I use the HDR, it's hiding somewhere.  Can anyone please help?
Thank you!
453
Try changing the sort order on the tool bar above the filmstrip. Use either capture time or filename.
Participant ,
Mar 03, 2018 Mar 03, 2018
I tried that it didn't work. Actually I remember when I talked to Adobe it was in some setting so I went up into the view setting I think it was and I clicked on file history. I'm pretty sure that's the name of the folder as I'm not at my computer but as soon as I clicked on file history all the pictures in the row at the bottom all opened up so I was able to see all the HDR versions! It's such a quirky thing and I don't know why it only does it WITH HDR but it seems like I figured it out because of sheer frustration!
Thank you so much
Sent on Samsung Galaxy 6.
Have a wonderful day!
Depending on your external editing preferences, the HDR image will be saved as a PSD or tiff image. When I have done that and have my sort order sets to file name, the tiff image appears with the selected images that were chosen to create the HDR image. Is there any chance you have of filter set to exclude certain file types? I know that's a remote possibility, but had to ask.
Participant ,
Mar 04, 2018 Mar 04, 2018
Hi Jim and thank you. I think I know what you're saying. But I did recall when I called Adobe a few years ago about this it was something I thought I changed in one of the the drop-downs, and I did change something in the drop-down I don't know if it was under View or where but whatever I clicked on it and all of a sudden the HDR images appeared in the tile bar below. Should I run into a problem again, I will refer to your email. Thank you kindly for your help. Sometimes there's quirky things in software where the answer is not always apparent.
Diane
If you are working with Drop Downs at, near, the top of the screen then you are working with the Filter Bar and that is why you aren't seeing the image returned to LR.
Click the None entry at the top of the filter bar.
Participant ,
Thanks. I was talking about the drop-down menus. Somehow I got the HDR images to show up now. Thank you.
What Drop Down menus? Do you mean the menu items at the top of the window, IE the normal menu items?
Participant ,
Yes
Great... BTW - have you tried making HDR photos directly in Lr? I've tested and compared results from each and the results from Lr are stellar.
Participant ,
No, I haven't. But I know it can be done. Sometimes I take single photos that are of buildings and apply one of the Nik software settings to it.
If it's not too complicated how do you make an HDR in Adobe LR? I absolutely love the look of HDR photos for certain pictures!
Thank you.
Diane
You highlight two or more bracketed images, and invoke the HDR command and let Lightroom do it's thing. It's on the same menu with calling for a panorama or Edit in Photoshop.
