Hello,
I’m using PS CC 19.0 (as read under Help -> About Photoshop CC), Windows 10.
I’m trying to use Color Lookup for the first time and it seems that numerous options should be available. Indeed there are 20 or so available in 3DLUT, but none Abstract or Device Link. The only options are “Load Abstract Profile” and other which is greyed out. Same for Device Link. Clicking on the option opens a file navigation window for me to select a file. Not helpful without more information…
I’ve searched Adobe’s site for 30 minutes, and googled the issue but find nothing on how to “load” the profiles if that is what I need to do, or otherwise fix the problem. All I can find is information on exporting a profile.
I understand that ‘Sepia’ should be available in the Abstract, and that is what I’m looking for at the moment, but I’d like what should be available.
Two questions:
How do I fix the problem?
How am I supposed to figure this out without asking for help, or put another way what did I miss?
Thanks much for your help,
Dan
Hi I have found how to solve this issue::
You need to copy the files from
C:\Program Files (x86)\Common Files\Adobe\Color Profiles
and paste into the following location
C:\Windows\System32\spool\drivers\color
Update:
I’ve uninstalled, rebooted, and reinstalled 19.0 with the same result. I’ve also looked in program flies -> Adobe Photoshop CC 2018 -> Presets. I find 3DLUT, but nothing for Abstract or Device Link.
Dan
Like Dan I also have no colour presets under Abstract when using color lookup? I am windows 10 Pro 64 and PS CC 2018? I have already reset and reinstalled etc.
Where are color swatches or what ever files I need? Seems to want ICC profiles?
It is suspicious that no one is seeking to answer the original posters issue or fix it?
Surely all this needs is a link to a download and a paste in? Not rocket science Adobe?
Does Photoshop CC 2018 even come with these presets? If yes where are they and where should they be?
Me too. I had them in CS 6. Where are they in CC 2018??
It works. Thank you very much.
Thank you very much. It really works for me as well.
It worked for me too. Thanks very much.
Are these the files I need to copy and paste?
