I am trying to Optimize or reduce a fillable PDF form with images, but every time a warning pop up come with "the pdf document contained image mask that were not downsampled".
I am using Acrobat Pro DC Version 2018.009.20044.
Please Need Help.
Do you feel this is stopping the size reduction you want?
It does not reduced at all.
What does AUDIT SPACE USAGE show as the main users of space? And the pictures on this page? Are they black/one colour, or normal multicolour?
I make this form for reports.
This is for one report only.
Hi Lionelr,
You may try flattening transparency and then save pdf as optimized pdf as the following thread suggests and see if that works:
“the PDF document contained image masks that were not downsampled."
You may also visit the following forum threads which discuss the similar issue:
I am unable to create a reduced size PDF
How can I reduce the size images on a PDF?
Shivam
