Is there a way to check if a layer (ReadLayerDesc) is selected or not?
Engaged ,
Feb 21, 2018 Feb 21, 2018
I'm writing a filter plugin and I need a to return all the layers that are selected in a document. I am creating a pointer to a list of layers with 'gFilterRecord->documentInfo->layersDescriptor'  I was hoping there would be a descriptor to check if it's selected similar to: 'layersDescriptor->isVisible'
I can't seem to find anywhere other than a 'ReadChannelDesc' that contains a 'Selection' property. Can I add this or in some way return if it's selected in the layers tab?
SDK
1.7K
Adobe
Adobe Employee ,
Feb 26, 2018 Feb 26, 2018
I would look at the UI code for AutomationFilter on windows. It selects the active layer I believe.
Engaged ,
Mar 05, 2018 Mar 05, 2018
Thanks Tom, I'm wondering if there is a property I can check (iterate through each layer and check to see if it has a selection key) , you are correct that I can return the `Selected layer` and I do it like: `error = sPSActionDescriptor->GetInteger(result, keyItemIndex, &layerIndex);`
But I need to check to see if more than one layer is Selected.
Adobe Employee ,
Mar 06, 2018 Mar 06, 2018
Is this what you are looking for? Getting selected layers by script (object refs, not indices!)
Your filter will not run if multiple layers are selected...
Engaged ,
I still can't seem to get this to work:
Auto_Desc result(false);
Auto_Ref reference;
DescriptorTypeID typeID;
AFERROR(sPSActionReference->PutEnumerated(reference.get(), classDocument, typeOrdinal, enumTarget));
AFERROR(sPSActionControl->Get(&result, reference.get()));
sPSActionControl->StringIDToTypeID(ktargetLayers, &typeID);
PIActionList PIList;
sPSActionDescriptor->GetList(result.get(), typeID, &PIList);
uint32 listSize = 0;
sPSActionList->GetCount(PIList, &listSize);
When you say I can't get my Filter plugin to run do you mean I can't run it directly?
Because I am currently running a filter that will return the data I need though I was planning on passing a list of selected layers from the Hidden plugin to the filter and preform what I need to on the layers specified in the filter plugin.
Thanks for your reply.
Engaged ,
Mar 13, 2018 Mar 13, 2018
I've still been unable to get the selected layers, do you know if I am doing it wrong Tom?
Adobe Employee ,
Mar 14, 2018 Mar 14, 2018
All that looks correct. You are getting an error or listSize is remaining a 0?
Engaged ,
Mar 15, 2018 Mar 15, 2018
Yes It's remaining at 0; It seems that the GetList() is tossing an error:
`errMissingParameter` But I have no idea what param it could be missing...
Engaged ,
sPSActionReference->PutProperty(reference.get(), classProperty, keyLayerID);
sPSActionReference->PutEnumerated(reference.get(), classLayer, typeOrdinal, enumTarget);
sPSActionControl->Get(&result, reference.get());
I spent some time on it, I still can't access a list, the only thing I've accomplished is returning one selected layer with the above code, I'm not able to return a list...
Engaged ,
Even getting this error with "targetLayers" and all the docs say that's when I have to use...
error = sPSActionControl->StringIDToTypeID("targetLayers", &typeID);
error = sPSActionDescriptor->GetList(result.get(), typeID, &PIList);
