I have files in LR CC that have for example, files names DSC00323.ARW, DSC00323-2.ARW and DSC00323-3.ARW. How do I define a search to find all of the files with the -2 and -3? They are duplicated files that I want to remove.
Bob
Select All Photographs in the Catalog section, then use the LR filter bar, Text option, Filename option in first, left, box, Contains in second box then -2, (Comma) -3. And to narrow it down a little you can also use the Metadata filter at the same time, just click on that option in the top of the filter bar, to select only RAW files.
The only problem comes if you have files with dates in them that the date numbers are separated by the - character. But using the RAW file filter in the Metadata filter should limit that.
Open the 'Text' section of the Filter bar at top of Library Grid and set up as shown below to find all images with -2, then repeat for -3
I agree with JustShootMe's solution aside from one adjustment: your filename text search can include the dot that separates the main filename from the file extension since that will always follow the appended numeral when these duplicates are made.
This will exclude any unwanted occurrences of "-2" or of "-3" elsewhere in the filename, e.g. as part of date text.
So your search text can be " -2.,-3. " which stated in words, is "minus two dot comma minus three dot"
Alternatively you could search more particularly on " -2.arw,-3.arw ".
But using -2,-3 returns files with a 2 on the file name.
Have you tried with the dot?
In your screen shot you have ARW in the search field not -2, -3. Note that there is a space between the comma after 2 and the - (Minus sign) before 3.
On my system I do get images that have a date format in the file name (2007-2-23) but adding a . (DOT) then the File Extension of the types of files you are searching for stops that from happening.
All good now and many thanks.
